DEM离散元软件(yade) ,KM-DCwcG
|^uU &O;.
YADE离散元软件,目前只能运行于LINUX操作系统,在在0.80版之后列入DEBIAN的软件库,很容易安装;在Fedora系统或者Scientific Linux系统中也容易安装。 K`BNSdEN>
o@p(8=x
Yade is an extensible open-source framework for discrete numerical models, focused on Discrete Element Method. The computation parts are written in c++ using flexible object model, allowing independent implementation of new alogrithms and interfaces. Python is used for rapid and concise scene construction, simulation control, postprocessing and debugging. j@j%)CCM
U c6]]Bbc
Yade is located at which contains this documentation and wiki. Development is kindly hosted at launchpad; it is used for source code, bug tracking, planning, package and source downloads and more. \[nvdvJv
SO~]aFoYt
如果想尝试一下这款软件,其官方文件也指出了: QNGICG-
Getting started: $& 0hpg
Before you start moving around in Yade, you should have some prior knowledge. R(i2TAaaU
Basics of command line in your Linux system are necessary for running yade. Look on the web for tutorials. qtqTLl@u
Python language; we recommend the official Python tutorial. Reading further documents on the topis, such as Dive into Python will certainly not hurt either. Vy+%sG
q"
You are advised to try all commands described yourself. Don’t be afraid to experiment. e:h(,
-T
s8y
此软件也以与PFC3D软件进行了比较,功能也很强了,但是这个YADE是FREE的。 oj8_e xx
下面附上一张YADE实现的模型图片。 _fVC\18T
下面附上当前的最新版本: r`; "
1X5*V!u
nE~HcxE/
N@o Ng}D&:
