用以下这段Lisp程序就可以快速地将图中的坐标标注在图中指定的位置. Gc`PO
lK=Is
v+
(DEFUN C:zb() IRm}?hHf
(command "dimzin" "0") nD
BWm`kN
(command "layer" "new" "zb_1" "") T(?w}i
(setvar "clayer" "zb_1" ) ]i.N'O<p
(command "color" 1) M=liG+d
(command "style" "zb" "complex.shx" "0" "0.75" "0" "n" "n" "n") .Q!d[vL
(command "osnap" "int") ?K[Y"*y2
(command "osnap" "end") 1]Xx{j<
(command "osmode" 1) z1Ieva]
(SETQ P1 (GETPOINT"Pick the zb point:")) u>fMO9X}2
(command "osmode" 0) Ra|P5
(SETQ P2 (GETPOINT P1)) 'cpm 4mT
(SETQ X1 (LIST (CAR P2)(+ (CADR P2) 2))) HXKM<E{j
(SETQ Y1 (LIST (CAR P2)(- (CADR P2) 7))) \
T#|<=
(SETQ X2 (LIST (+ (CAR P2) 6)(CADR X1))) g D6S%O
(SETQ Y2 (LIST (+ (CAR P2) 6)(CADR Y1))) B<SE|~\2
(SETQ XX (RTOS (CAR P1) 2 3)) $WIVCp
(SETQ YY (RTOS (CADR P1) 2 3)) ih0a#PB8
(SETQ L1 (STRLEN XX)) ~ps,U
(SETQ L2 (STRLEN YY)) y<FC7
(IF (>= L1 L2)(SETQ L (* L1 5))(SETQ L (* L2 5))) R BHDfm'~7
(COMMAND"LINE" P1 P2"") (Ut8pa+yX
(command "layer" "new" "zb_2" "") !YAX.e
(setvar "clayer" "zb_2" ) }9"''Z
(IF (>= (CAR P2)(CAR P1)) ,6{z
(PROGN $vu*# .w
(SETQ P3 (LIST (+ (CAR P2) ( * L 0.85))(CADR P2))) yk8b>.Y\A
(setq p4 (list (+ (car p3) 5)(cadr p2))) %@vF%
(COMMAND"LINE" P2 P3"") n\((#<&
(setq p5 (list (+ (car p3) 2.5)(- (cadr p3) 2.5))) Qf( A
(COMMAND"TEXT" X2 5 0 YY) >g{&Qx`&
(COMMAND"TEXT" Y2 5 0 XX) 66pjWS
{X
(COMMAND"TEXT" X1 5 0 "N") kku<0<(N
(COMMAND"TEXT" Y1 5 0 "E") >; MJm
) }"T Q\v$
(PROGN vd lss|
(SETQ P3 (LIST (- (CAR P2) ( * L 0.85))(CADR P2))) @bA5uY!
(setq p4 (list (- (car p3) 5)(cadr p2))) J]TqH`MA
(SETQ XX1 (LIST (+ (CAR P3) 1)(+ (CADR P3) 2))) \:J=tAC
(SETQ YY1 (LIST (+(CAR P3) 1)(- (CADR P3) 7))) X+]>pA
(SETQ X22 (LIST (+ (CAR P3) 6)(CADR XX1))) OWewV@VXR
(SETQ Y22 (LIST (+ (CAR P3) 6)(CADR YY1))) Wz'!stcp
(COMMAND"LINE" P2 P3"") Kz42AC
(setq p5 (list (- (car p3) 8)(- (cadr p3) 2.5))) ;-VZV p}Y
(COMMAND"TEXT" X22 5 0 YY) V gMgeja
(COMMAND"TEXT" Y22 5 0 XX) P5?VrZy
(COMMAND"TEXT" XX1 5 0 "N") .3C::~:
(COMMAND"TEXT" YY1 5 0 "E") Qa_V
) ar<8wq<4G
) csW\Q][
) @KL&vm(F$
(DEFUN C:zb3() CO`)XB6W
(command "dimzin" "0") Hnt*,C.0
(command "layer" "new" "zb_1" "") 7G_<+rn
(setvar "clayer" "zb_1" ) vT EqT
(command "color" 1) -E?:W`!
(command "style" "zb" "complex.shx" "0" "0.75" "0" "n" "n" "n") R)66qRf
(command "osnap" "int") 7_2D4CI
(command "osnap" "end") 0]SWyC
(command "osmode" 1) vIJ5iLF
(SETQ P1 (GETPOINT"Pick the zb point:")) f/J/tt
(command "osmode" 0) >Y08/OAI.2
(SETQ P2 (GETPOINT P1)) a5#G48'X
(SETQ X1 (LIST (CAR P2)(+ (CADR P2) 1))) `*vO8v
(SETQ Y1 (LIST (CAR P2)(- (CADR P2) 4))) \B4H0f
(SETQ X2 (LIST (+ (CAR P2) 5)(CADR X1))) fc3 nQp7
(SETQ Y2 (LIST (+ (CAR P2) 5)(CADR Y1))) }%Mdf6LS64
(SETQ XX (RTOS (CAR P1) 2 3)) 1]:,Xa+|S
(SETQ YY (RTOS (CADR P1) 2 3)) UAF$bR
(SETQ L1 (STRLEN XX)) A6=Z2i0w>X
(SETQ L2 (STRLEN YY)) 'l^Bb#)"
(IF (>= L1 L2)(SETQ L (* L1 2.4))(SETQ L (* L2 2.4))) Y|LL]@Lv
(COMMAND"LINE" P1 P2"") }eVDe(7_
(command "layer" "new" "zb_2" "") 8s6[-F5
(setvar "clayer" "zb_2" ) "j_iq"J
(IF (>= (CAR P2)(CAR P1)) IRQtA
Z V$
(PROGN 3`reXms*{
(SETQ P3 (LIST (+ (CAR P2) L)(CADR P2))) ~k&b
(setq p4 (list (+ (car p3) 3)(cadr p2))) U*a#{C7"
(COMMAND"LINE" P2 P3"") ltuV2.$
(COMMAND"TEXT" X2 2.5 0 YY) f DXK<v)
(COMMAND"TEXT" Y2 2.5 0 XX) ysOf=~1
(COMMAND"TEXT" X1 2.5 0 "N=") XDCm
(COMMAND"TEXT" Y1 2.5 0 "E=") *Vl#]81~
) Trs~KcsD
(PROGN W~mo*EJ'^
(SETQ P3 (LIST (- (CAR P2) L)(CADR P2))) w0g@ <(
(setq p4 (list (- (car p3) 3)(cadr p2))) c)#7T<>*'
(SETQ XX1 (LIST (CAR P3)(+ (CADR P3) 1))) @FIL4sb
(SETQ YY1 (LIST (CAR P3)(- (CADR P3) 4)))
#tKks:eL
(SETQ X22 (LIST (+ (CAR P3) 4)(CADR XX1))) _5 SvZ;4
(SETQ Y22 (LIST (+ (CAR P3) 4)(CADR YY1))) &$|~",
(COMMAND"LINE" P2 P3"") :Ob4WU
(COMMAND"TEXT" X22 2.5 0 YY) *}C%z(
(COMMAND"TEXT" Y22 2.5 0 XX) I+
|uyc
(COMMAND"TEXT" XX1 2.5 0 "N=") :0y-n.-{
(COMMAND"TEXT" YY1 2.5 0 "E=") iqR6z\p&
) fC'u-m?!Q'
) 4|_xz;i
) {oY"CZ2
(DEFUN C:zb2() TI3xt-/
(command "dimzin" "0") PJZ;wqTD_
(command "layer" "new" "zb_1" "") &qWg$_Yh
(setvar "clayer" "zb_1" ) $Zyuhji^
(command "color" 1) R7rM$|n=o
(command "style" "zb" "complex.shx" "0" "0.75" "0" "n" "n" "n") RCTqV.L
(command "osnap" "int") 'G65zz
(command "osnap" "end") kKF=%J?X
(command "osmode" 1) RTVU3fw
(SETQ P1 (GETPOINT"Pick the zb point:")) R^`}DlHX
(command "osmode" 0) g"n>v
c7
(SETQ P2 (GETPOINT P1)) uH$hMg
(SETQ X1 (LIST (CAR P2)(+ (CADR P2) 1))) Z]Xa:[
(SETQ Y1 (LIST (CAR P2)(- (CADR P2) 2))) ?x",VA
(SETQ X2 (LIST (+ (CAR P2) 2.5)(CADR X1))) |rJN
(SETQ Y2 (LIST (+ (CAR P2) 2.5)(CADR Y1))) X$==J St
(SETQ XX (RTOS (CAR P1) 2 3)) yI8O#
(SETQ YY (RTOS (CADR P1) 2 3)) vVtkB$]L
(SETQ L1 (STRLEN XX)) x=rMjz-`_
(SETQ L2 (STRLEN YY)) `Zuo`GP*1
(IF (>= L1 L2)(SETQ L (* L1 1))(SETQ L (* L2 1))) {G=> WAXo
(COMMAND"LINE" P1 P2"") f
] *w1
(command "layer" "new" "zb_2" "") 4wKCzPy
(setvar "clayer" "zb_2" ) W=
NX$=il
(IF (>= (CAR P2)(CAR P1)) ds(X[7XGW
(PROGN I*U7YqDC9
(SETQ P3 (LIST (+ (CAR P2) L)(CADR P2))) DA=LR
(setq p4 (list (+ (car p3) 3)(cadr p2))) M#2<|VUW,
(COMMAND"LINE" P2 P3"") :@&e~QP(
(COMMAND"TEXT" X2 1.25 0 YY) x3'ANw6E
(COMMAND"TEXT" Y2 1.25 0 XX) "n3n-Y#'
(COMMAND"TEXT" X1 1.25 0 "N=") =UO7!vr;[
(COMMAND"TEXT" Y1 1.25 0 "E=") I SZEP8w
) 0o 7o;eN
(PROGN c%G~HOE=B
(setq l (* l 1.1)) nZj&Ma7R
(SETQ P3 (LIST (- (CAR P2) L)(CADR P2))) 3U?gw!M>
(setq p4 (list (- (car p3) 3)(cadr p2))) dW/(#KP/+
(SETQ XX1 (LIST (CAR P3)(+ (CADR P3) 1))) =S54p(>
(SETQ YY1 (LIST (CAR P3)(- (CADR P3) 2))) 9ox5,7ZQ
(SETQ X22 (LIST (+ (CAR P3) 2.5)(CADR XX1))) Wx/PD=Sf&
(SETQ Y22 (LIST (+ (CAR P3) 2.5)(CADR YY1))) LCRZ<?O[|
(COMMAND"LINE" P2 P3"") Jtxwt[
(COMMAND"TEXT" X22 1.25 0 YY) Yvu!Q
(COMMAND"TEXT" Y22 1.25 0 XX) P'6eK?
(COMMAND"TEXT" XX1 1.25 0 "N=") ZVj/lOP X
(COMMAND"TEXT" YY1 1.25 0 "E=") J!,<NlP0K
) &i,xod6$
) Vn-y<*np
) }Q?,O
(DEFUN C:zb5() 0a??8?Q1G
(setq cc 1) |BGQ|7DyG
(setq cc (getint "输入点编号<1>:")) j ,'$i[F'
(repeat 1000 Ph'P<h:V
(command "style" "zb" "complex.shx" "0" "0.75" "0" "n" "n" "n") c1?_L(
(command "dimzin" "0") cf#2Wg)
(command "layer" "new" "zb_1" "") J?~El&
(setvar "clayer" "zb_1" ) *1fq :--
(command "color" 1) l#_(suo64
(command "osnap" "int") 1>1&NQ#}
(command "osnap" "end") 6;g"`l51
(command "osmode" 1) V(|@6ww
(SETQ P1 (GETPOINT"Pick the zb point:")) YzqUOMAt"V
(command "osmode" 0) w NlC2is
(SETQ P2 (GETPOINT P1)) ]CD
(SETQ X1 (LIST (CAR P2)(+ (CADR P2) 2))) |#);^z_
(SETQ Y1 (LIST (CAR P2)(- (CADR P2) 7))) WKib$(%f6
(SETQ X2 (LIST (+ (CAR P2) 6)(CADR X1))) #MbkU])
(SETQ Y2 (LIST (+ (CAR P2) 6)(CADR Y1))) P5Y:c@u2
(SETQ XX (RTOS (CAR P1) 2 3)) )DS|mM)
(SETQ YY (RTOS (CADR P1) 2 3)) [;`B
(SETQ L1 (STRLEN XX)) 3?F*|E_
(SETQ L2 (STRLEN YY)) `;yfSoY
(IF (>= L1 L2)(SETQ L (* L1 5))(SETQ L (* L2 5))) pPSmSWD?
(COMMAND"LINE" P1 P2"") A~_*vcz
(command "layer" "new" "zb_2" "") fD<9k
(setvar "clayer" "zb_2" ) 59;p|
(IF (>= (CAR P2)(CAR P1)) )aov]Ns
(PROGN roDE?7x1
(SETQ P3 (LIST (+ (CAR P2) ( * L 0.85))(CADR P2))) '%.:97
(setq p4 (list (+ (car p3) 7)(cadr p2))) );o2eV
(command"circle" p4 7"") 5\MCk "R!
(COMMAND"LINE" P2 P3"") B8){
(setq bb 2.5) x{_:B
DY
(IF (<= cc 9 )(setq bb 5)) 50#iC@1
(setq p5 (list (+ (car p3) bb)(- (cadr p3) 2.5))) ?6;9r[ p
(COMMAND"TEXT" X2 5 0 YY) 04`2MNfxG
(COMMAND"TEXT" Y2 5 0 XX) N8!V%i?
(COMMAND"TEXT" X1 5 0 "N") q#RUL!WF7U
(COMMAND"TEXT" Y1 5 0 "E") N?Byp&rqI<
(IF (>= cc 10)(command "style" "zb" "complex.shx" "0" "0.9" "0" "n" "n" "n")) Id6H~;
(IF (>= cc 100)(command "style" "zb" "complex.shx" "0" "0.65" "0" "n" "n" "n")) I8R#EM%C#
(IF (>= cc 1000)(command "style" "zb" "complex.shx" "0" "0.5" "0" "n" "n" "n")) jlvh'y`
(command"text" p5 6 0 cc) CatbEXO
) (gY3?&Ok*
(PROGN >yr:L{{D}G
(SETQ P3 (LIST (- (CAR P2) ( * L 0.85))(CADR P2))) !6Sr*a*5
(setq p4 (list (- (car p3) 7)(cadr p2))) PE $sF]/
(SETQ XX1 (LIST (+ (CAR P3) 1)(+ (CADR P3) 2))) d??;r:
(SETQ YY1 (LIST (+(CAR P3) 1)(- (CADR P3) 7))) #NU@7Q[4
(SETQ X22 (LIST (+ (CAR P3) 6)(CADR XX1))) *$K_Tii
(SETQ Y22 (LIST (+ (CAR P3) 6)(CADR YY1))) wKxw|Fpn
(COMMAND"LINE" P2 P3"") 2a=3->D&
(command"circle" p4 7) .
V5Pr}"y
(setq bb 12) g=)B+SY'
(IF (<= cc 9 )(setq bb 8)) rC`pTN
(setq p5 (list (- (car p3) bb)(- (cadr p3) 2.5))) ?A4zIJ\
(COMMAND"TEXT" X22 5 0 YY) ,%)O/{p_
(COMMAND"TEXT" Y22 5 0 XX) sIUhk7Cd8
(COMMAND"TEXT" XX1 5 0 "N") Blw AD
(COMMAND"TEXT" YY1 5 0 "E") uX82q.u_y
(IF (>= cc 10)(command "style" "zb" "complex.shx" "0" "0.9" "0" "n" "n" "n")) H(L.k;B
(IF (>= cc 100)(command "style" "zb" "complex.shx" "0" "0.65" "0" "n" "n" "n")) dY=]ES}`
(IF (>= cc 1000)(command "style" "zb" "complex.shx" "0" "0.5" "0" "n" "n" "n")) ~quof>
(command"text" p5 6 0 cc) 6pJFrWe{
) ;Gc,-BDFw
) cs+;ijp
(setq cc (+ cc 1)) @477|LO
s2Z'_rT
) P 2-^j)
