  • 2057阅读
win8 64 系统如何安装plaxis,谢谢指点。 [复制链接]
离线wz_2026
只看楼主 倒序阅读 使用道具 楼主  发表于: 2014-08-30
离线asdfhoho
只看该作者 1楼 发表于: 2014-09-01
there is a ".txt"file in the "crack" folder. you can follow these steps:
a) Install (setup.exe in Setup directory).
b) When asked for the registration disk, point to USERDEF.PUF in crack directory
c) Choose setup type "personal computer installation". Install also the hardlock drivers when asked.
d) Install the update to v8.2 (setup.exe in plaxis_8.2_update directory)
e) copy batch.exe, geo.exe, plaxout.exe, hlvdd.dll into installdirectory (overwrite existing files)
f) It might be necessary to delete the original hlvdd.dll in .../windows/system32 (for XP) respectively .../winnt/system32 (for W2K) and/or copy hlvdd.dll from crack directory therein too
离线wz_2026
只看该作者 2楼 发表于: 2014-09-06
谢谢
内容来自[短消息]
离线wz_2026
只看该作者 3楼 发表于: 2014-09-06
还是没安装上去,不过还是很谢谢你。
