  • 3378阅读
flac3d600本构模型二次开发即UDM官网简明教程 [复制链接]
离线龙biscuit
只看楼主 倒序阅读 使用道具 楼主  发表于: 2018-12-12
老规矩,先贴上教程地址:
User-Defined Constitutive Models in FLAC3D
不想点击上面链接的可以下载下面的附件:
flac3d二次开发简明教程.pdf (606 K) 下载次数:195
里面感觉很有用的话:
  • At this point, it is important to understand something about how FLAC3D implements mixed-discretization in hexahedral zones. Each such zone is actually two overlays of five tetrahedra covering the hexahedron volume, called subzones. The constitutive relations are called on each tetrahedra separately. Properties and state variables are stored for the zone as a whole. Normally, state variables are assumed to be based on volume-averaged quantities over the entire zone. The constitutive model can access both the total number of subzones and which subzone is being calculated.
  • In the [size=; font-size: inherit,inherit]run() function, we use a working value [size=; font-size: inherit,inherit]s->working_[0] to store the averaged shear failure state value in the zone weighted by the subzone volumes (in the subzones, the shear failure state is assumed 1 if shear failed; 0 if not). We update the cohesion to the value of residual cohesion once the volume averaged shear failure value is greater than 0.5. Related variables need to be updated correspondingly.
    f2d449-flac3dUDM.pdf (128 K) 下载次数:82
  • 当然,还有手册(http://bbs.yantuchina.com/read.php?tid=316649&fpage=2 )可以参考,这儿介绍的并没有太详细。但好在简单明了。
另外,还有别的简单介绍:
Scripting FISH in FLAC3D
Dynamic Analysis in FLAC3D
邮箱:blzhu@buaa.edu.cn ,欢迎交流!
离线malu1988
只看该作者 1楼 发表于: 2018-12-28
楼主辛苦
离线杜岳洋
只看该作者 2楼 发表于: 2019-01-08
只看该作者 3楼 发表于: 2019-04-20
dragon哥哥好棒
