USE OF KEYLOK USB DONGLE
IMPORTANT INSTALLATION NOTE
1). If the RES2DINV and RES3DINV software are already installed in your computer, you will need
to replace the RES2DINV.EXE and RES3DINV.EXE files with the latest USB versions in the CD.
You need to copy the RES2DINV.EXE and RES3DINV.EXE files from the Win_Updates folder/subdirectory
to the appropriate folders in you computer (usually C:\RES2DINV and C:\RES3DINV).
2). If the RES2DINV and RES3DINV software have not yet been installed, run the SETUP.EXE files
found in the RES2DINV and RES3DINV folders in the CD.
3). First, make sure that the USB dongle is not attached to the computer. You will now need to
install the software driver for the Keylok dongle by running the INSTALL.EXE program in the
KEYLOK_SYSTEM_DRIVER folder in the CD. Please note that in Windows NT/2000/XP you must have
Administrator privileges in order to install the driver.For computers that do not have a
parallel port, you must type in the '/B' option on the INSTALL.EXE command line in the Run
box. This is to avoid installing the driver for the parallel port as well.
4). After installing the driver, switch off the computer and attach the USB dongle. It is
recommended that you attach the USB dongle to the first USB port on the computer. Some
older computer systems have trouble detecting it on the second USB port. Now switch on the
computer. Windows will display a message saying that it has found a new hardware and it
should then automatically copy the driver for the dongle.
5). Try running the RES2DINV and RES3DINV program, and they should be able to detect the dongle.
