  • 5061阅读
plaxis的莫尔库仑模型中的Eref怎么取值? [复制链接]
离线wangst_451
只看楼主 倒序阅读 使用道具 楼主  发表于: 2007-07-21
plaxis的莫尔库仑模型中的Eref怎么取值?和试验数据Es有什么关系?
离线mano
只看该作者 1楼 发表于: 2007-08-12
Es:  Es is obtained by consolidation test or by empirical relationship with site test(such as cone
penetration test) , actually Es is assumed as constrained modulus (Eoed). In this case, the strain
is not zero only in compression direction.  By Hook's law, strains in the other two directions=0,
E=Eoed * (1+v) *(1-2v)/(1-v)
When using Mohr-Coulomb model in PLAXIS, Eref (the parameter in input window) is referred to Eref(50) that means the modulus of soil  E. It is independent of stress level.
Here, finally, Eref=Es * (1+v) *(1-2v)/(1-v)
But remember, all these are for drained condition. You should use effective Poisson's ratio.
For undrained condition, you may get  Eu value from test or some empirical equations(Eu=a*Su), you should change Eu to E(effective value):
E=2*Eu*(1+v)/3
[ 此贴被mano在2007-08-13 10:15重新编辑 ]
1条评分
geofem 鲜花 +1 - 2007-08-12
离线geofem
只看该作者 2楼 发表于: 2007-08-12
对于国内的Es,都是固结试验的值,应该可以理解为有效应力状态的模量.
ZSOIL2D/3D QQ群:68722113
岩土工程数值分析开发平台,共享、开放、合作、提高。
