  • 10650阅读
  • 14回复
地震工程模拟计算平台——OpenSees [复制链接]
离线hxx.star
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-11-29
OpenSees的全称是Open System for Earthquake Engineering Simulation(地震 jU7[z$GX
工程模拟的开放体系)。它是由美国国家自然科学基金(NSF)资助、西部大学联 11YJ W-V
盟“太平洋地震工程研究中心”(Pacific Earthquake Engineering Research Center, ux)*B}/xh
简称PEER)主导、加州大学伯克利分校为主研发而成的、用于结构和岩土方面地 ~59lkr8
震反应模拟的一个较为全面且不断发展的开放的程序软件体系。 c9fz x
OpenSees程序自1999年正式推出以来,已广泛用于太平洋地震工程研究中心 -l57!s~V
和美国其它一些大学和科研机构的科研项目中,较好的模拟了包括钢筋混凝土结 GT)7VFrL
构、桥梁、岩土工程在内众多的实际工程和振动台试验项目,证明其具有较 V){Io_"
好的非线性数值模拟精度。该程序正在引起世界各国结构工程领域众多研究人员 -` ViuDX=
的关注和重视,而在国内也开始有少数学校开展了一些初步的学习和相关的研究 *bf 5A9
工作。 ){w{#
uJ -$i
The Open System for Earthquake Engineering Simulation 1xd6p
The Open System for Earthquake Engineering Simulation (OpenSees) is a software framework for simulating the seismic response of structural and geotechnical systems. OpenSees has been developed as the computational platform for research in performance-based earthquake engineering at the Pacific Earthquake Engineering Research Center. OpenSees is also the simulation component for the NEESit since 2004. \ *[Ht!y
L r"cO|F
Capabilities Q|h$D~
OpenSees has advanced capabilities for modeling and analyzing the nonlinear response of systems using a wide range of material models, elements, and solution algorithms. The software is designed for parallel computing to allow scalable simulations on high-end computers or for parameter studies. '(3 QyCD
6,q_ M(;c
Modeling %p )"_q!ge
OpenSees providing beam-column elements and continuum elements for structural and geotechnical models. A wide range of uniaxial materials and section models are available for beam-columns. #<b\BqYG
|~ fI=1;;x
Analysis +5*bU1}O
Nonlinear analysis requires a wide range of algorithms and solution methods. OpenSees provides nonlinear static and dynamic methods, equation solvers, and methods for handling constraints. CO@G%1#
*cXq=/s
Development Process c.Sd~k:3
OpenSees is open-source. This website provides information about the software architecture, access to the source code, and the development process. The open-source movement allows earthquake engineering researchers and users to build upon each others accomplishments using OpenSees as community-based software. [(x*!,=
M9R'ONYAa
?SFQx \/
离线docmao
只看该作者 1楼 发表于: 2009-12-01
回 楼主(hxx.star) 的帖子
我也在学习它的c++原代码,基本上算掌握了。但还没有真正改造过它的原代码。 L$_%T
实际上用TCL建模仍有很大的局限性,从面向科研的角度看,还是要掌握c++原代码。 Gl'G;F$Y-
继续学习中........
离线ahu861011
只看该作者 2楼 发表于: 2010-04-30
opensees学习交流群:108677474,欢迎大家加入
离线liupf616
只看该作者 3楼 发表于: 2010-05-05
英文的,呵呵还是很有用的
离线chenlingkun
只看该作者 4楼 发表于: 2010-06-17
要学习!!!!!!!!!
离线xmzk
只看该作者 5楼 发表于: 2010-06-17
Re:
好东西 !!谢谢了
离线weiping
只看该作者 6楼 发表于: 2010-06-17
唉,只会Fortran
离线caihuiteng
只看该作者 7楼 发表于: 2010-06-17
什么是TCL建模,而且请问一下,在岩土方面是基于什么原理模拟的呢?
离线香格里拉
只看该作者 8楼 发表于: 2010-06-20
有人有着软件没有?上传共享一下撒
请相信只要用心、努力,就没有什么是不可以的!!!
离线dcq54
只看该作者 9楼 发表于: 2010-07-28
还以为是软件,不厚道
别对我说蛋是为人民服务的,这个太恶心了。。。
离线ricozhou1231
只看该作者 10楼 发表于: 2010-07-31
用于结构和岩土方面地震反应模拟的一个较为全面且不断发展的开放的程序软件体系,有原代码可以使用??
离线gaohouzhi
只看该作者 11楼 发表于: 2011-04-16
回 1楼(docmao) 的帖子
大侠,听说您把源代码搞懂了,很佩服,能给点经验吗?我的qq: 745606860.恳请加大侠为好友
