登录注册
UID:36348
UID:37061
UID:4799
UID:8427
UID:1084
引用第7楼mano于2007-10-01 10:02发表的 : #kAk d-QY6 Do not worry about that, you can use Duncan-Chang Model, because the response for frozen soil may not have plasticity. You can set up the high Young's Modulus or you can set the frozen soil as linear elastic material.I did have a sample for frozen soil, if you need, I can send that to you!Good luck,
引用第7楼mano于2007-10-01 10:02发表的 : &8hW~G>(m Do not worry about that, you can use Duncan-Chang Model, because the response for frozen soil may not have plasticity. You can set up the high Young's Modulus or you can set the frozen soil as linear elastic material.I did have a sample for frozen soil, if you need, I can send that to you!Good luck,
UID:44255
UID:145054
UID:151164
