  • 242529阅读
  • 35回复
【转帖】部分术语中英对照 [复制链接]
离线qyxmcad
只看该作者 12楼 发表于: 2008-11-02
〖GBJ125-89〗给水排水设计基本术语标准
Standard for basic terms used in design of water supply and sewerage engineering
〖GBJ126-89〗工业设备及管道绝热工程施工及验收规范
Code for construction and acceptance of heat insulation in industrial equipment and pipe work
〖GBJ127-89〗架空索道工程技术规范
Technical code for aerial rope-way engineering
〖GBJ128-90〗立式圆筒形钢制焊接油罐施工及验收规范
Code for construction and acceptance of stand cylindrical steel welded oil storage tank
〖GBJ129-90〗砌体基本力学性能试验方法标准
Standard for test methods of basic mechanical properties of masonry
〖GBJ130-90〗钢筋混凝土升板结构技术规范
Technical code for reinforced concrete lift-slab structure
〖GBJ131-90〗自动化仪表安装工程质量检验评定标准
Standard for quality inspection and assessment of installation works for automatic instruments
〖GBJ132-90〗工程结构设计基本术语和通用符号
Standard for basic terms and general symbols used in structural design of engineering
〖GBJ133-90〗民用建筑照明设计标准
Standard for design of artificial lighting in civil buildings
〖GBJ134-90〗人防工程施工及验收规范
Code for construction and acceptance of civil air defense works
〖GBJ135-90〗高耸结构设计规范
Code for design of high-rise structures
〖GBJ136-90〗电镀废水治理设计规范
Code for design of disposal of electroplating waste water
〖GBJ137-90〗城市用地分类与规划建设用地标准
Standard for classification of urban land and for planning of constructional land
〖GBJ138-90〗水位观测标准
Standard for observation of water level
〖GBJ139-90〗内河通航标准
Standard for navigation of in-land river
〖GBJ140-90〗建筑灭火器配置设计规范
Code for design of extinguisher disposition in buildings
〖GBJ141-90〗给水排水构筑物施工及验收规范
Code for construction and acceptance of constructional structures of water supply and sewerage
〖GBJ142-90〗中、短波广播发射台与电缆载波通信系统的防护间距标准
Standard for protective specing between medium, short wave broadcast transmitting station and electric cable carrier telecommunication systems
〖GBJ143-90〗架空电力线路、变电所对电视差转台、转播台无线电干扰防护间距标准
Standard for protective spacing of radio interference from over-head electric lines,sub-stations to television transposer station and retransmitting station
〖GBJ144-90〗工业厂房可靠性鉴定标准
Standard for reliability evaluation of industrial factory buildings
〖GBJ145-90〗土的分类标准
Standard for classification of soils
〖GBJ146-90〗粉煤灰混凝土应用技术规程
Technical code for application of fly ash concrete
〖GBJ147-90〗电气装置安装工程 高压电器施工及验收规范
Erection works of electrical installations Code for construction and acceptance of high voltage appliance
〖GBJ148-90〗电气装置安装工程 电力变压器,油浸电抗器,互感器施工及验收规范
Erection works of electrical installations Code for construction and acceptance of electric power transformer,oily reactance and mutual inductance
〖GBJ149-90〗电气装置安装工程 母线施工及验收规范
Erection works of electrical installations Code for construction and acceptance of bus-bar device
〖GB50150-91〗电气装置安装工程 电气设备交接试验标准
Erection works of electrical installations Standard for hand-over test of electric equipment
〖GB50151-92〗低倍数泡沫灭火系统设计规范
Code for design of low expansion foam extinguishing systems
〖GB50152-92〗混凝土结构试验方法标准
Standard for test methods of concrete structures
〖GB50153-92〗工程结构可靠度设计统一标准
Unified standard for reliability design of engineering structures
〖GB50154-92〗地下及覆土火药炸药仓库设计安全规范
Code for safety design of underground and earth powder and explosive warhorse
〖GB50155-92〗采暖通风与空气调节术语标准
Standard for terminology of heating ventilation and air-conditioning
〖GB50156-2002〗汽车加油站设计与施工规范
Code for design and construction of automobile gasoline and gas filling station
〖GB50157-2003〗地下铁道设计规范
Code for design of under-ground railway
〖GB50158-92〗港口工程结构可靠度设计统一标准
Unified standard for reliability design of port engineering
〖GB50159-92〗河流悬移质泥沙测验规范
Code for measurement of suspended sediment in open channels
〖GB50160-92〗石油化工企业设计防火规范
Code for fire protection design of petrochemical enterprises
〖GB50161-92〗烟花爆竹工厂设计安全规范
Code for safety design of fire-works and firecrackers plants
〖GB50162-92〗道路工程制图标准
Standard for road engineering drawing
〖GB50163-92〗卤代烷1301灭火系统设计规范
Code for design of halon 1301 fire extinguishing systems
〖GB50164-92〗混凝土质量控制标准
Standard for quality control of concrete
〖GB50165-92〗古建筑木结构维护与加固技术规范
Technical code for maintenance and strengthening of ancient timber buildings
〖GB50166-92〗火灾自动报警系统施工及验收规范
Code for construction and acceptance of automatic fire alarm systems
〖GB50167-92〗工程摄影测量标准
Code for engineering photogrmmetry
〖GB50168-92〗电气装置安装工程 电缆线路施工及验收规范
Erection works of electrical installations Code for construction and acceptance of cable levels
〖GB50169-92〗电气装置安装工程 接地装置施工及验收规范
Erection works of electrical installations Code for construction and acceptance of earthed devices
〖GB50170-92〗电气装置安装工程 旋转电机施工及验收规范
Erection works of electrical installations Code of construction and acceptance of rotating electrical machines
〖GB50171-92〗电气装置安装工程 盘、柜及二次回路结线施工及验收规范
Erection works of electrical installations Code for construction and acceptance of switchboard outfit,complete cubicle and secondary circuit
〖GB50172-92〗电气装置安装工程 蓄电池施工及验收规范
Erection works of electrical installations Code for construction and acceptance of battery
〖GB50173-92〗电气装置安装工程 35kV及以下架空电力线路施工及验收规范
Erection works of electrical installations Code for construction and acceptance of 35kV and under over-head power levels
〖GB50174-93〗电子计算机机房设计规范
Code for design of electric computer room
〖GB50175-93〗露天煤矿工程施工及验收规范
Code for construction and acceptance of open pit coal-mine engineering
〖GB50176-93〗民用建筑热工设计规范
Code for thermal design of civil buildings
〖GB50177-93〗氢氧站设计规范
Code for design of hydrogen and oxygen stations
〖GB50178-93〗建筑气候区划标准
Standard for climatic region-alization for building and civil engineering
〖GB50179-93〗河流流量测验规范
Code for measurement of fluid flow in open channels
〖GB50180-93〗城市居住区规划设计规范
Code for planning design of urban residential area
〖GB50181-93〗蓄滞洪区建筑工程技术规范
Technical code for constructional engineering in flood detention basin
〖GB50182-93〗电气装置安装工程 电梯电气装置施工及验收规范
Erection works of electrical installations Code for construction and acceptance of electrical apparatus of elevators
〖GB/T50183-93〗原油和天然气工程设计防火规范
Code for fire protection design of crude oil and natural gas works
〖GB50184-93〗工业金属管道工程质量检验评定标准
Standard for quality inspection and assessment of industrial metal pipeline engineering
〖GB50185-93〗工业设备及管道绝热工程质量检验评定标准
Standard for quality inspection and assessment of heat insulation engineering of industrial equipment and pipelines
〖GB50186-93〗港口工程基本术语标准
Standard for basic terms of port engineering
〖GB50187-93〗工业企业总平面设计规范
Code for design of general plan for industrial enterprises
〖GB50188-93〗村镇规划标准
Standard for planning of rural village and town
〖GB50189-93〗旅游旅馆建筑热工与空气调节节能设计标准
Standard for design of air-conditioning and energy conservation in tourism hotel buildings
〖GB50190-93〗多层厂房楼盖抗微振设计规范
Code for design of anti-microvibration of multistory factory floor
〖GB50191-93〗构筑物抗震设计规范
Code for design of earthquake-resistant of structural constructions
〖GB50192-93〗河港工程设计规范
Code for design of river port engineering
〖GB50193-93〗二氧化碳灭火系统设计规范
Code for design of carbon dioxide fire extinguishing systems
〖GB50194-93〗建设工程施工现场供用电安全规范
Code for safety of power supply and consumption in engineering construction site
〖GB50195-94〗发生炉煤气站设计规范
Code for design of producer gas stations
〖GB50196-93〗高倍数、中倍数泡沫灭火系统设计规范
Code for design of high and medium expansion foam fire extinguishing systems
〖GB50197-94〗露天煤矿工程设计规范
Code for design of open pit coal mine engineering
〖GB50198-94〗民用闭路监视电视系统工程技术规范
Technical code for civil closed circuit monitoring TV system engineering
生命不息,奋斗不止!
离线qyxmcad
只看该作者 13楼 发表于: 2008-11-02
〖GB50199-94〗水利水电工程结构可靠度设计统一标准
Unified standard for reliability design of hydraulic engineering structures
〖GB50200-94〗有线电视系统工程技术规范
Technical code for CATV system
〖GB50201-94〗防洪标准
Standard for flood control
〖GBJ201-83〗土方与爆破工程施工及验收规范
Code for construction and acceptance of earthwork and blasting engineering
〖GB50202-2003〗建筑地基基础工程施工质量验收规范
Code for construction and acceptance quality of building foundation
〖GB50203-2002〗砌体工程施工及验收规范
Code for construction and acceptance of masonry structure engineering
〖GB50204-2002〗混凝土结构工程施工及验收规范
Code for construction and acceptance of concrete structure engineering
〖GB50205-2001〗钢结构工程施工及验收规范
Code for construction and acceptance of steel structure engineering
〖GB50206-2002〗木结构工程施工及验收规范
Code for construction and acceptance of timber structure engineering
〖GB50207-2002〗屋面工程技术规范
Technical code for roof engineering
〖GB50208-2002〗地下防水工程施工及验收规范
Code for construction and acceptance of underground water proof engineering
〖GB50209-2002〗建筑地面工程施工及验收规范
Code for construction and acceptance of ground and floor engineering
〖GB50210-2001〗建筑装修工程质量验收规范
Code for construction quality acceptance of building decoration
〖GBJ211-87〗工业炉砌筑工程施工及验收规范
Code for construction and acceptance of brick works for industrial furnaces
〖GBJ50212-2002〗建筑防腐蚀工程施工及验收规范
Code for construction and acceptance of building corrosion pre-vention works
〖GBJ213-90〗矿山井巷工程施工及验收规范
Code for construction and acceptance of mining pit engineering
〖GB50214-2001〗组合钢模板技术规范
Technical code for assembly steel formworks
〖GB50215-94〗煤炭工业矿井设计规范
Code for the colliery design of coal mining industry
〖GB50216-94〗铁路工程结构可靠度设计统一标准
Unified standard for reliability design of railway engineering structures
〖GB50217-94〗电力工程电缆设计规范
Code for design of cables of electric works
〖GB50218-94〗工程岩体分级标准
Standard for classification of engineering rock masses
〖GB50219-95〗水喷雾灭火系统设计规范
Code for design of water spray fire extinguishing systems
〖GB50220-95〗城市道路交通规划设计规范
Code for planning design of transport on urban road
〖GB50222-95〗建筑内部装修设计防火规范
Code for fire prevention de-sign of interior decoration of buildings
〖GB50223-95〗建筑抗震设防分类标准
Code for classification of seismic protection of buildings
〖GB50224-95〗建筑防腐蚀工程质量检验评定标准
Standard for quality inspection and addressment of anti-corrosion engineering of buildings
〖GB50225-95〗人民防空工程设计规范
Code for design of civil air de-fence works
〖GB50226-95〗铁路旅客车站建筑设计规范
Code for desgn of railway passenger station buildings
〖GB50227-95〗并联电容器装置设计规范
Code for design of installation of shunt capacitors
〖GB/T50228-96〗工程测量基本术语标准
Standard for foundational terminology of engineering survey
〖GB50229-96〗火力发电厂与变电所设计防火规范
Code for fire protection design of power plant and substation
〖GB50231-98〗机械设备安装工程施工及验收规范
Code for construction and acceptance of mechanical equipment installation engineering
〖GB50233-90〗110-500KV架空电力线路施工及验收规范
Code for construction and acceptance of 110-500kV over-head electrical power trans-mission line
〖GB50235-97〗工业金属管道工程施工及验收规范
Code for construction and acceptance of industrial metallic pipeline engineering
〖GB50236-98〗现场设备、工业管道焊接工程施工及验收规范
Code for construction and acceptance of welding works of on-site equipment and in-dustrial pipeline
〖GB50242-2002〗建筑给水排水及采暖工程施工质量验收规范
Code for acceptance of construction quality of water supply drainage and heating works
〖GB50243-2002〗通风与空调工程施工及验收规范
Code for construction and acceptance of ventilation and air-conditioning works
〖GB50251-2003〗输气管道工程设计规范
Code for design of trans-mission pipeline engineering
〖GB50252-94〗工业安装工程质量检测评定统一标准
Unified standard for quality inspection and assessment of industrial erection engineering
〖GB50253-2003〗输油管道工程设计规范
Code for design of oil trans-mission pipeline engineering
〖GB50254-96〗电气装置安装工程 低压电器施工及验收规范
Electric equipment installation engineering Code for construction and acceptance of low-voltage apparatus
〖GB50255-96〗电气装置安装工程 电力变流设备施工及验收规范
Electric equipment installation engineering Code for construction and acceptance of power convertor equipment
〖GB50256-96〗电气装置安装工程 起重机电气装置施工及验收规范
Electric equipment installation engineering Code for construction and acceptance of electric device of crane
〖GB50257-96〗电气装置安装工程 爆炸和火灾危险环境电气装置施工及验收规范
Electric equipment installation engineering Code for construction and acceptance of electric device within explosion and fire hazard atmospheres
〖GB50260-96〗电力设施抗震设计规范
Code for design of seismic of electrical installations
〖GB50261-96〗自动喷水灭火系统施工及验收规范
Code for construction and acceptance of automatic sprinkler fire extinguishing sys-tems
〖GB/T50262-97〗铁路工程基本术语标准
Standard for fundamental terms of railway engineering
〖GB50263-97〗气体灭火系统施工及验收规范
Code for installation and acceptance of gas fire extinguishing systems
〖GB50264-97〗工业设备及管道绝热工程设计规范
Code for design of heat insulation engineering of industrial equipment and pipe lines
〖GB/T50265-97〗泵站设计规范
Code for design of pumping stations
〖GB/T50266-99〗工程岩体试验方法标准
Standard for test methods of engineering rock masses
〖GB50267-97〗核电厂抗震设计规范
Code for seismic design of un-clear power plants
〖GB50268-97〗给水排水管道工程施工及验收规范
Code for construction and acceptance of water supply and sewerage pipeline engineering
〖GB/T50269-97〗地基动力持性测试规范
Code for measurement method of dynamic properties of subsoil
〖GB50270-1998〗连续输送设备安装工程施工及验收规范
Code for construction and acceptance of continuous conveyer equipment installation engineering
〖GB50271-1998〗金属切削机床安装工程施工及验收规范
Code for construction and acceptance of metal-cutting machine installation engineer-ing
〖GB50272-1998〗锻压设备安装工程施工及验收规范
Code for construction and acceptance of forging-press equipment installation engineering
〖GB50273-1998〗工业锅炉安装工程施工及验收规范
Code for construction and acceptance of industrial boiler installation engineering
〖GB50274-1998〗制冷设备空气分离设备安装工程施工及验收规范
Code for construction and acceptance of refrigeration and air separating equipment installation engineering
〖GB50275-1998〗压缩机、风机、泵安装工程施工及验收规范
Code for construction and acceptance of compressor,fan and pump installation engineering
〖GB50276-1998〗破碎粉磨设备安装工程施工及验收规范
Code for construction and acceptance of crusher and mill equipment installation engineering
〖GB50277-1998〗铸造设备安装工程施工及验收规范
Code for construction and acceptance of casting equipment installation engineering
〖GB50278-1998〗起重设备安装工程施工及验收规范
Code for construction and acceptance of crane installation engineering
〖GB/T50279-1998〗岩土工程基本术语标准
Standard for fundamental terms of geotechnical engineering
〖GB/T50280-1998〗城市规划基本术语标准
Standard for basic terminology of urban planning
〖GB50281-1998〗泡沫灭火系统施工及验收规范
Code for construction and acceptance of foam fire extinguishing systems
〖GB50282-98〗城市给水工程规划规范
Code for planning of urban water supply engineering
〖GB/T50283-1999〗公路工程结构可靠度设计统一标准
Unified standard of reliability design of highway engineering structures
〖GB50284-98〗飞机库设计防火规范
Code for fire protection design of aircraft hangar
〖GB50285-98〗调幅收音台和调频电视转播台与公路防护间距标准
Standard for protection distance from highway to AM,FM and TV rebroadcast stations
〖GB50286-98〗堤防工程设计规范
Code for design of levee projects
〖GB50287-1999〗水利水电工程地质勘察规范
Code for geological investigation of water resources and hydropower engineering
〖GB50288-1999〗灌溉与排水工程设计规范
Code for design of irrigation and drainage
〖GB50289-98〗城市工程管线综合规划规范
Code for comprehensive planning of urban engineering pipeline
〖GB50290-98〗土工合成材料应用技术规范
Technical code for application of geosynthetics
〖GB/T50291-1999〗房地产估价规范
Code for appraisal of real estate
生命不息,奋斗不止!
离线qyxmcad
只看该作者 14楼 发表于: 2008-11-02
〖GB50292-1999〗民用建筑可靠性鉴定标准
Standard for reliability evaluation of civil buildings
〖GB50293-1999〗城市电力规划规范
Code for planning of urban electric power
〖GB/T50294-1999〗核电厂总平面及运输设计规范
Code for design of general plan and transportation of nuclear power plants
〖GB50295-1999〗水泥工厂设计规范
Code for design of cement plants
〖GB50296-1999〗供水管井技术规范
Technical standard for water supply well
〖GB50297-1999〗电力工程基本术语标准
Standard for basic terms of electric power engineering
〖GB50298-1999〗风景名胜区规划规范
Code for planning of scenic area
〖GB50299-1999〗地下铁道工程施工及验收规范
Code for construction and acceptance of subway engineering
〖GB50300-2001〗建筑安装工程质量检验评定统一标准
Unified standard for quality inspection and assessment of building constructional erection works
〖GBJ301-88〗建筑工程质量检验评定标准
Standard for quality inspection and assessment of building construction
〖GBJ302-88〗建筑采暖卫生与煤气工程质量检验评定标准
Standard for quality inspection and assessment of building heating,sanitary and gas engineering
〖GB50303-2002〗建筑电气安装工程质量检验评定标准
Standard for quality inspection and assessment of erection works for building electrical installations
〖GB50307-1999〗地下铁道、轻轨交通岩土工程勘察规范
Code for geotechnical engineering investigation of sub-way and light rail transit
〖GB50308-1999〗地下铁道、轻轨交通工程测量规范
Code for engineering surveying of subway and light rail transit
〖GB50309-92〗工业炉砌筑工程质量检验评定标准
Standard for quality inspection and assessment of brick works for industrial furnaces
〖GB50310-2002〗电梯安装工程质量检验评定标准
Standard for quality inspection and assessment of erection works of elevators
〖GB/T50311-2000〗建筑与建筑群综合布线系统工程设计规范
Code for engineering design of generic cabling system for building and campus
〖GB/T50312-2000〗建筑与建筑群综合布线系统工程验收规范
Code for engineering acceptance of generic cabling sys-tem for building and campus
〖GB50313-2000〗消防通信指挥系统设计规范
Code for design of fire communication and command sys-tem
〖GB/T50314-2000〗智能建筑设计标准
Standard for design of intelligent buildings
〖GB/T50315-2000〗砌体工程检测技术标准
Technical standard for site testing of masonry engineering
〖GB50316-2000〗工业金属管道设计规范
Code for design of industrial metallic pipeline engineering
〖GB50317-2000〗猪屠宰与分割车间设计规范
Code for design of workshop for pig slaughter and segmentation
〖GB50318-2000〗城市排水工程规划规范
Code for planning of urban sewerage engineering
〖GB50319-2000〗建设工程监理规范
Code for construction project management
〖GB50320-2001〗粮食平房仓设计规范
Code for design of grain storehouses
〖GB50322-2001〗粮食钢板筒仓设计规范
Code for design of steel silos
〖GB/T50323-2001〗城市建设档案著录规范
Code for urban construction archives description
〖GB50324-2001 〗冻土工程地质勘察规范
Code for engineering geological investigation of frozen ground
〖GB50325-2001〗民用建筑工程室内环境污染控制规范
Code for indoor environmental pollution control of civil building engineering
〖GB/T50326-2001 〗建设工程项目管理规范
The code of construction project management by enterprises of construction industry
〖GB50327-2001〗住宅装饰装修工程施工规范
Code for construction of decoration of housings
〖GB/T50328-2001〗建设工程文件归档整理规范
Code for construction project document
〖GB/T50329-2002〗木结构试验方法标准
Standard for methods testing of timber structures
〖GB50330-2002 〗建筑边坡工程技术规范
Technical code for building slope engineering
〖GB/T50331-2002〗城市居民生活用水量标准
The standard of water quantity for city's residential use
〖GB50332-2002〗给水排水工程管道结构设计规范
Structural design code for pipelines of water supply and waste water engineering
〖GB50333-2002〗医院洁净手术部建筑技术规范
Architectural technical code for hospital clean operating department
〖GB50334-2002〗城市污水处理厂工程质量验收规范
Quality acceptance code for municipal sewage treatment plant engineering
〖GB50335-2002〗污水再生利用工程设计规范
Code for design of wastewater reclamation and reuse
〖GB50336-2002 〗建筑中水设计规范
Code of design for building reclaimed water system
〖GB50338-2003〗固定消防炮灭火系统设计规范
Code of design for fixed fire monitor extinguishing systems
〖GB50339-2003〗智能建筑工程质量验收规范
Code for acceptance of quality of intelligent building systems
〖GB50340-2003〗老年人居住建筑设计标准
Code for design of residential building for the aged
〖GB50341-2003〗立式圆筒形钢制焊接油罐设计规范
〖GB50343-2004〗建筑物电子信息系统防雷技术规范
〖GB/T50344-2004〗建筑结构检测技术标准
〖GB50345-2004〗屋面工程技术规范
〖GB50500-2003〗建设工程质量清单计价规范
Code of valuation with bill quantity of construction works
混凝土拱坝设计规范  Design specification for concrete aech dam SL282–2003  中国建筑工业出版社
水工建筑物抗震设计规范  Specifications for seismic design of hydraulic structures DL 5073-97
生命不息,奋斗不止!
离线qyxmcad
只看该作者 15楼 发表于: 2008-11-02
序号    分类    名词(中)    名词(英)
1    1. 综合类    大地工程(岩土工程)    geotechnical engineering
2    1. 综合类    反分析法    back analysis method
3    1. 综合类    基础工程    foundation engineering
4    1. 综合类    临界状态土力学    critical state soil mechanics
5    1. 综合类    数值岩土力学    numerical geomechanics
6    1. 综合类    土    soil, earth
7    1. 综合类    土动力学    soil dynamics
8    1. 综合类    土力学    soil mechanics
9    1. 综合类    岩土工程    geotechnical engineering
10    1. 综合类    应力路径    stress path
11    1. 综合类    应力路径法    stress path method
12    2. 工程地质及勘察    变质岩    metamorphic rock
13    2. 工程地质及勘察    标准冻深    standard frost penetration
14    2. 工程地质及勘察    冰川沉积    glacial deposit
15    2. 工程地质及勘察    冰积层(台)    glacial deposit
16    2. 工程地质及勘察    残积土    eluvial soil, residual soil
17    2. 工程地质及勘察    层理    beding
18    2. 工程地质及勘察    长石    feldspar
19    2. 工程地质及勘察    沉积岩    sedimentary rock
20    2. 工程地质及勘察    承压水    confined water
21    2. 工程地质及勘察    次生矿物    secondary mineral
22    2. 工程地质及勘察    地质年代    geological age
23    2. 工程地质及勘察    地质图    geological map
24    2. 工程地质及勘察    地下水    groundwater
25    2. 工程地质及勘察    断层    fault
26    2. 工程地质及勘察    断裂构造    fracture structure
27    2. 工程地质及勘察    工程地质勘察    engineering geological exploration
28    2. 工程地质及勘察    海积层(台)    marine deposit
29    2. 工程地质及勘察    海相沉积    marine deposit
30    2. 工程地质及勘察    花岗岩    granite
31    2. 工程地质及勘察    滑坡    landslide
32    2. 工程地质及勘察    化石    fossil
33    2. 工程地质及勘察    化学沉积岩    chemical sedimentary rock
34    2. 工程地质及勘察    阶地    terrace
35    2. 工程地质及勘察    节理    joint
36    2. 工程地质及勘察    解理    cleavage
37    2. 工程地质及勘察    喀斯特    karst
38    2. 工程地质及勘察    矿物硬度    hardness of minerals
39    2. 工程地质及勘察    砾岩    conglomerate
40    2. 工程地质及勘察    流滑    flow slide
41    2. 工程地质及勘察    陆相沉积    continental sedimentation
42    2. 工程地质及勘察    泥石流    mud flow, debris flow
43    2. 工程地质及勘察    年粘土矿物    clay minerals
44    2. 工程地质及勘察    凝灰岩    tuff
45    2. 工程地质及勘察    牛轭湖    ox-bow lake
46    2. 工程地质及勘察    浅成岩    hypabyssal rock
47    2. 工程地质及勘察    潜水    ground water
48    2. 工程地质及勘察    侵入岩    intrusive rock
49    2. 工程地质及勘察    取土器    geotome
50    2. 工程地质及勘察    砂岩    sandstone
51    2. 工程地质及勘察    砂嘴    spit, sand spit
52    2. 工程地质及勘察    山岩压力    rock pressure
53    2. 工程地质及勘察    深成岩    plutionic rock
54    2. 工程地质及勘察    石灰岩    limestone
55    2. 工程地质及勘察    石英    quartz
56    2. 工程地质及勘察    松散堆积物    rickle
57    2. 工程地质及勘察    围限地下水(台)    confined ground water
58    2. 工程地质及勘察    泻湖    lagoon
59    2. 工程地质及勘察    岩爆    rock burst
60    2. 工程地质及勘察    岩层产状    attitude of rock
61    2. 工程地质及勘察    岩浆岩    magmatic rock, igneous rock
62    2. 工程地质及勘察    岩脉    dike, dgke
63    2. 工程地质及勘察    岩石风化程度    degree of rock weathering
64    2. 工程地质及勘察    岩石构造    structure of rock
65    2. 工程地质及勘察    岩石结构    texture of rock
66    2. 工程地质及勘察    岩体    rock mass
67    2. 工程地质及勘察    页岩    shale
68    2. 工程地质及勘察    原生矿物    primary mineral
69    2. 工程地质及勘察    云母    mica
70    2. 工程地质及勘察    造岩矿物    rock-forming mineral
71    2. 工程地质及勘察    褶皱    fold, folding
72    2. 工程地质及勘察    钻孔柱状图    bore hole columnar section
73    3. 土的分类    饱和土    saturated soil
74    3. 土的分类    超固结土    overconsolidated soil
75    3. 土的分类    冲填土    dredger fill
76    3. 土的分类    充重塑土
77    3. 土的分类    冻土    frozen soil, tjaele
78    3. 土的分类    非饱和土    unsaturated soil
79    3. 土的分类    分散性土    dispersive soil
80    3. 土的分类    粉土    silt, mo
81    3. 土的分类    粉质粘土    silty clay
82    3. 土的分类    高岭石    kaolinite
83    3. 土的分类    过压密土(台)    overconsolidated soil
84    3. 土的分类    红粘土    red clay, adamic earth
85    3. 土的分类    黄土    loess
86    3. 土的分类    蒙脱石    montmorillonite
87    3. 土的分类    泥炭    peat, bog muck
88    3. 土的分类    年粘土    clay
89    3. 土的分类    年粘性土    cohesive soil, clayey soil
90    3. 土的分类    膨胀土    expansive soil, swelling soil
91    3. 土的分类    欠固结粘土    underconsolidated soil
92    3. 土的分类    区域性土    zonal soil
93    3. 土的分类    人工填土    fill, artificial soil
94    3. 土的分类    软粘土    soft clay, mildclay, mickle
95    3. 土的分类    砂土    sand
96    3. 土的分类    湿陷性黄土    collapsible loess, slumping loess
97    3. 土的分类    素填土    plain fill
98    3. 土的分类    塑性图    plasticity chart
99    3. 土的分类    碎石土    stone, break stone, broken stone, channery, chat, crushed stone, deritus
100    3. 土的分类    未压密土(台)    underconsolidated clay
101    3. 土的分类    无粘性土    cohesionless soil, frictional soil, non-cohesive soil
102    3. 土的分类    岩石    rock
103    3. 土的分类    伊利土    illite
104    3. 土的分类    有机质土    organic soil
105    3. 土的分类    淤泥    muck, gyttja, mire, slush
106    3. 土的分类    淤泥质土    mucky soil
107    3. 土的分类    原状土    undisturbed soil
108    3. 土的分类    杂填土    miscellaneous fill
109    3. 土的分类    正常固结土    normally consolidated soil
110    3. 土的分类    正常压密土(台)    normally consolidated soil
111    3. 土的分类    自重湿陷性黄土    self weight collapse loess
112    4. 土的物理性质    阿太堡界限    Atterberg limits
113    4. 土的物理性质    饱和度    degree of saturation
114    4. 土的物理性质    饱和密度    saturated density
115    4. 土的物理性质    饱和重度    saturated unit weight
116    4. 土的物理性质    比重    specific gravity
117    4. 土的物理性质    稠度    consistency
118    4. 土的物理性质    不均匀系数    coefficient of uniformity, uniformity coefficient
119    4. 土的物理性质    触变    thixotropy
120    4. 土的物理性质    单粒结构    single-grained structure
121    4. 土的物理性质    蜂窝结构    honeycomb structure
122    4. 土的物理性质    干重度    dry unit weight
123    4. 土的物理性质    干密度    dry density
124    4. 土的物理性质    塑性指数    plasticity index
125    4. 土的物理性质    含水量    water content, moisture content
126    4. 土的物理性质    活性指数
127    4. 土的物理性质    级配    gradation, grading
128    4. 土的物理性质    结合水    bound water, combined water, held water
129    4. 土的物理性质    界限含水量    Atterberg limits
130    4. 土的物理性质    颗粒级配    particle size distribution of soils, mechanical composition of soil
131    4. 土的物理性质    可塑性    plasticity
132    4. 土的物理性质    孔隙比    void ratio
133    4. 土的物理性质    孔隙率    porosity
134    4. 土的物理性质    粒度    granularity, grainness, grainage
135    4. 土的物理性质    粒组    fraction, size fraction
136    4. 土的物理性质    毛细管水    capillary water
137    4. 土的物理性质    密度    density
138    4. 土的物理性质    密实度    compactionness
139    4. 土的物理性质    年粘性土的灵敏度    sensitivity of cohesive soil
140    4. 土的物理性质    平均粒径    mean diameter, average grain diameter
141    4. 土的物理性质    曲率系数    coefficient of curvature
142    4. 土的物理性质    三相图    block diagram, skeletal diagram, three phase diagram
143    4. 土的物理性质    三相土    tri-phase soil
144    4. 土的物理性质    湿陷起始应力    initial collapse pressure
145    4. 土的物理性质    湿陷系数    coefficient of collapsibility
生命不息,奋斗不止!
离线qyxmcad
只看该作者 16楼 发表于: 2008-11-02
146    4. 土的物理性质    缩限    shrinkage limit
147    4. 土的物理性质    土的构造    soil texture
148    4. 土的物理性质    土的结构    soil structure
149    4. 土的物理性质    土粒相对密度    specific density of solid particles
150    4. 土的物理性质    土中气    air in soil
151    4. 土的物理性质    土中水    water in soil
152    4. 土的物理性质    团粒    aggregate, cumularpharolith
153    4. 土的物理性质    限定粒径    constrained diameter
154    4. 土的物理性质    相对密度    relative density, density index
155    4. 土的物理性质    相对压密度    relative compaction, compacting factor, percent compaction, coefficient of compaction
156    4. 土的物理性质    絮状结构    flocculent structure
157    4. 土的物理性质    压密系数    coefficient of consolidation
158    4. 土的物理性质    压缩性    compressibility
159    4. 土的物理性质    液限    liquid limit
160    4. 土的物理性质    液性指数    liquidity index
161    4. 土的物理性质    游离水(台)    free water
162    4. 土的物理性质    有效粒径    effective diameter, effective grain size, effective size
163    4. 土的物理性质    有效密度    effective density
164    4. 土的物理性质    有效重度    effective unit weight
165    4. 土的物理性质    重力密度    unit weight
166    4. 土的物理性质    自由水    free water, gravitational water, groundwater, phreatic water
167    4. 土的物理性质    组构    fabric
168    4. 土的物理性质    最大干密度    maximum dry density
169    4. 土的物理性质    最优含水量    optimum water content
170    5. 渗透性和渗流    达西定律    Darcy's law
171    5. 渗透性和渗流    管涌    piping
172    5. 渗透性和渗流    浸润线    phreatic line
173    5. 渗透性和渗流    临界水力梯度    critical hydraulic gradient
174    5. 渗透性和渗流    流函数    flow function
175    5. 渗透性和渗流    流土    flowing soil
176    5. 渗透性和渗流    流网     flow net
177    5. 渗透性和渗流    砂沸    sand boiling
178    5. 渗透性和渗流    渗流    seepage
179    5. 渗透性和渗流    渗流量    seepage discharge
180    5. 渗透性和渗流    渗流速度    seepage velocity
181    5. 渗透性和渗流    渗透力    seepage force
182    5. 渗透性和渗流    渗透破坏    seepage failure
183    5. 渗透性和渗流    渗透系数    coefficient of permeability
184    5. 渗透性和渗流    渗透性    permeability
185    5. 渗透性和渗流    势函数    potential function
186    5. 渗透性和渗流    水力梯度    hydraulic gradient
187    6. 地基应力和变形    变形    deformation
188    6. 地基应力和变形    变形模量    modulus of deformation
189    6. 地基应力和变形    泊松比    Poisson's ratio
190    6. 地基应力和变形    布西涅斯克解    Boussinnesq's solution
191    6. 地基应力和变形    残余变形    residual deformation
192    6. 地基应力和变形    残余孔隙水压力    residual pore water pressure
193    6. 地基应力和变形    超静孔隙水压力    excess pore water pressure
194    6. 地基应力和变形    沉降    settlement
195    6. 地基应力和变形    沉降比    settlement ratio
196    6. 地基应力和变形    次固结沉降    secondary consolidation settlement
197    6. 地基应力和变形    次固结系数    coefficient of secondary consolidation
198    6. 地基应力和变形    地基沉降的弹性力学公式    elastic formula for settlement calculation
199    6. 地基应力和变形    分层总和法    layerwise summation method
200    6. 地基应力和变形    负孔隙水压力    negative pore water pressure
201    6. 地基应力和变形    附加应力    superimposed stress
202    6. 地基应力和变形    割线模量    secant modulus
203    6. 地基应力和变形    固结沉降    consolidation settlement
204    6. 地基应力和变形    规范沉降计算法    settlement calculation by specification
205    6. 地基应力和变形    回弹变形    rebound deformation
206    6. 地基应力和变形    回弹模量    modulus of resilience
207    6. 地基应力和变形    回弹系数    coefficient of resilience
208    6. 地基应力和变形    回弹指数    swelling index
209    6. 地基应力和变形    建筑物的地基变形允许值    allowable settlement of building
210    6. 地基应力和变形    剪胀    dilatation
211    6. 地基应力和变形    角点法    corner-points method
212    6. 地基应力和变形    孔隙气压力    pore air pressure
213    6. 地基应力和变形    孔隙水压力    pore water pressure
214    6. 地基应力和变形    孔隙压力系数A    pore pressure parameter A
215    6. 地基应力和变形    孔隙压力系数B    pore pressure parameter B
216    6. 地基应力和变形    明德林解    Mindlin's solution
217    6. 地基应力和变形    纽马克感应图    Newmark chart
218    6. 地基应力和变形    切线模量    tangent modulus
219    6. 地基应力和变形    蠕变    creep
220    6. 地基应力和变形    三向变形条件下的固结沉降    three-dimensional consolidation settlement
221    6. 地基应力和变形    瞬时沉降    immediate settlement
222    6. 地基应力和变形    塑性变形    plastic deformation
223    6. 地基应力和变形    谈弹性变形    elastic deformation
224    6. 地基应力和变形    谈弹性模量    elastic modulus
225    6. 地基应力和变形    谈弹性平衡状态    state of elastic equilibrium
226    6. 地基应力和变形    体积变形模量    volumetric deformation modulus
227    6. 地基应力和变形    先期固结压力    preconsolidation pressure
228    6. 地基应力和变形    压缩层
229    6. 地基应力和变形    压缩模量    modulus of compressibility
230    6. 地基应力和变形    压缩系数    coefficient of compressibility
231    6. 地基应力和变形    压缩性    compressibility
232    6. 地基应力和变形    压缩指数    compression index
233    6. 地基应力和变形    有效应力    effective stress
234    6. 地基应力和变形    自重应力    self-weight stress
235    6. 地基应力和变形    总应力    total stress approach of shear strength
236    6. 地基应力和变形    最终沉降    final settlement
237    7. 固结    巴隆固结理论    Barron's consolidation theory
238    7. 固结    比奥固结理论    Biot's consolidation theory
239    7. 固结    超固结比    over-consolidation ratio
240    7. 固结    超静孔隙水压力    excess pore water pressure
241    7. 固结    次固结    secondary consolidation
242    7. 固结    次压缩(台)    secondary consolidation
243    7. 固结    单向度压密(台)    one-dimensional consolidation
244    7. 固结    多维固结    multi-dimensional consolidation
245    7. 固结    固结    consolidation
246    7. 固结    固结度    degree of consolidation
247    7. 固结    固结理论    theory of consolidation
248    7. 固结    固结曲线    consolidation curve
249    7. 固结    固结速率    rate of consolidation
250    7. 固结    固结系数    coefficient of consolidation
251    7. 固结    固结压力    consolidation pressure
252    7. 固结    回弹曲线    rebound curve
253    7. 固结    井径比    drain spacing ratio
254    7. 固结    井阻    well resistance
255    7. 固结    曼代尔-克雷尔效应    Mandel-Cryer effect
256    7. 固结    潜变(台)    creep
257    7. 固结    砂井    sand drain
258    7. 固结    砂井地基平均固结度    average degree of consolidation of sand-drained ground
259    7. 固结    时间对数拟合法    logarithm of time fitting method
260    7. 固结    时间因子    time factor
261    7. 固结    太沙基固结理论    Terzaghi's consolidation theory
262    7. 固结    太沙基-伦杜列克扩散方程    Terzaghi-Rendulic diffusion equation
263    7. 固结    先期固结压力    preconsolidation pressure
264    7. 固结    压密(台)    consolidation
265    7. 固结    压密度(台)    degree of consolidation
266    7. 固结    压缩曲线    compression curve
267    7. 固结    一维固结    one dimensional consolidation
268    7. 固结    有效应力原理    principle of effective stress
269    7. 固结    预压密压力(台)    preconsolidation pressure
270    7. 固结    原始压缩曲线    virgin compression curve
271    7. 固结    再压缩曲线    recompression curve
272    7. 固结    主固结    primary consolidation
273    7. 固结    主压密(台)    primary consolidation
274    7. 固结    准固结压力    pseudo-consolidation pressure
275    7. 固结    K0固结    consolidation under K0 condition
276    8. 抗剪强度    安息角(台)    angle of repose
277    8. 抗剪强度    不排水抗剪强度    undrained shear strength
278    8. 抗剪强度    残余内摩擦角    residual angle of internal friction
279    8. 抗剪强度    残余强度    residual strength
280    8. 抗剪强度    长期强度    long-term strength
281    8. 抗剪强度    单轴抗拉强度    uniaxial tension test
282    8. 抗剪强度    动强度    dynamic strength of soils
283    8. 抗剪强度    峰值强度    peak strength
284    8. 抗剪强度    伏斯列夫参数    Hvorslev parameter
285    8. 抗剪强度    剪切应变速率    shear strain rate
286    8. 抗剪强度    抗剪强度    shear strength
287    8. 抗剪强度    抗剪强度参数    shear strength parameter
288    8. 抗剪强度    抗剪强度有效应力法    effective stress approach of shear strength
289    8. 抗剪强度    抗剪强度总应力法    total stress approach of shear strength
290    8. 抗剪强度    库仑方程    Coulomb's equation
291    8. 抗剪强度    摩尔包线    Mohr's envelope
292    8. 抗剪强度    摩尔-库仑理论    Mohr-Coulomb theory
293    8. 抗剪强度    内摩擦角    angle of internal friction
生命不息,奋斗不止!
离线qyxmcad
只看该作者 17楼 发表于: 2008-11-02
294    8. 抗剪强度    年粘聚力    cohesion
295    8. 抗剪强度    破裂角    angle of rupture
296    8. 抗剪强度    破坏准则    failure criterion
297    8. 抗剪强度    十字板抗剪强度    vane strength
298    8. 抗剪强度    无侧限抗压强度    unconfined compression strength
299    8. 抗剪强度    有效内摩擦角    effective angle of internal friction
300    8. 抗剪强度    有效粘聚力    effective cohesion intercept
301    8. 抗剪强度    有效应力破坏包线    effective stress failure envelope
302    8. 抗剪强度    有效应力强度参数    effective stress strength parameter
303    8. 抗剪强度    有效应力原理    principle of effective stress
304    8. 抗剪强度    真内摩擦角    true angle internal friction
305    8. 抗剪强度    真粘聚力    true cohesion
306    8. 抗剪强度    总应力破坏包线    total stress failure envelope
307    8. 抗剪强度    总应力强度参数    total stress strength parameter
308    9. 本构模型    本构模型    constitutive model
309    9. 本构模型    边界面模型    boundary surface model
310    9. 本构模型    层向各向同性体模型    cross anisotropic model
311    9. 本构模型    超弹性模型    hyperelastic model
312    9. 本构模型    德鲁克-普拉格准则    Drucker-Prager criterion
313    9. 本构模型    邓肯-张模型    Duncan-Chang model
314    9. 本构模型    动剪切强度
315    9. 本构模型    非线性弹性模量    nonlinear elastic model
316    9. 本构模型    盖帽模型    cap model
317    9. 本构模型    刚塑性模型    rigid plastic model
318    9. 本构模型    割线模量    secant modulus
319    9. 本构模型    广义冯•米赛斯屈服准则    extended von Mises yield criterion
320    9. 本构模型    广义特雷斯卡屈服准则    extended Tresca yield criterion
321    9. 本构模型    加工软化    work softening
322    9. 本构模型    加工硬化    work hardening
323    9. 本构模型    加工硬化定律    strain hardening law
324    9. 本构模型    剑桥模型    Cambridge model
325    9. 本构模型    柯西弹性模型    Cauchy elastic model
326    9. 本构模型    拉特-邓肯模型    Lade-Duncan model
327    9. 本构模型    拉特屈服准则    Lade yield criterion
328    9. 本构模型    理想弹塑性模型    ideal elastoplastic model
329    9. 本构模型    临界状态弹塑性模型    critical state elastoplastic model
330    9. 本构模型    流变学模型    rheological model
331    9. 本构模型    流动规则    flow rule
332    9. 本构模型    摩尔-库仑屈服准则    Mohr-Coulomb yield criterion
333    9. 本构模型    内蕴时间塑性模型    endochronic plastic model
334    9. 本构模型    内蕴时间塑性理论    endochronic theory
335    9. 本构模型    年粘弹性模型    viscoelastic model
336    9. 本构模型    切线模量    tangent modulus
337    9. 本构模型    清华弹塑性模型    Tsinghua elastoplastic model
338    9. 本构模型    屈服面    yield surface
339    9. 本构模型    沈珠江三重屈服面模型    Shen Zhujiang three yield surface method
340    9. 本构模型    双参数地基模型
341    9. 本构模型    双剪应力屈服模型    twin shear stress yield criterion
342    9. 本构模型    双曲线模型    hyperbolic model
343    9. 本构模型    松岗元-中井屈服准则    Matsuoka-Nakai yield criterion
344    9. 本构模型    塑性形变理论
345    9. 本构模型    谈弹塑性模量矩阵    elastoplastic modulus matrix
346    9. 本构模型    谈弹塑性模型    elastoplastic modulus
347    9. 本构模型    谈弹塑性增量理论    incremental elastoplastic theory
348    9. 本构模型    谈弹性半空间地基模型    elastic half-space foundation model
349    9. 本构模型    谈弹性变形    elastic deformation
350    9. 本构模型    谈弹性模量    elastic modulus
351    9. 本构模型    谈弹性模型    elastic model
352    9. 本构模型    魏汝龙-Khosla-Wu模型    Wei Rulong-Khosla-Wu model
353    9. 本构模型    文克尔地基模型    Winkler foundation model
354    9. 本构模型    修正剑桥模型    modified Cambridge model
355    9. 本构模型    准弹性模型    hypoelastic model
356    10. 地基承载力    冲剪破坏    punching shear failure
357    10. 地基承载力    次层(台)    substratum
358    10. 地基承载力    地基    subgrade, ground, foundation soil
359    10. 地基承载力    地基承载力    bearing capacity of foundation soil
360    10. 地基承载力    地基极限承载力    ultimate bearing capacity of foundation soil
361    10. 地基承载力    地基允许承载力    allowable bearing capacity of foundation soil
362    10. 地基承载力    地基稳定性    stability of foundation soil
363    10. 地基承载力    汉森地基承载力公式    Hansen's ultimate bearing capacity formula
364    10. 地基承载力    极限平衡状态    state of limit equilibrium
365    10. 地基承载力    加州承载比(美国)    California Bearing Ratio
366    10. 地基承载力    局部剪切破坏    local shear failure
367    10. 地基承载力    临塑荷载    critical edge pressure
368    10. 地基承载力    梅耶霍夫极限承载力公式    Meyerhof's ultimate bearing capacity formula
369    10. 地基承载力    普朗特承载力理论    Prandel bearing capacity theory
370    10. 地基承载力    斯肯普顿极限承载力公式    Skempton's ultimate bearing capacity formula
371    10. 地基承载力    太沙基承载力理论    Terzaghi bearing capacity theory
372    10. 地基承载力    魏锡克极限承载力公式    Vesic's ultimate bearing capacity formula
373    10. 地基承载力    整体剪切破坏    general shear failure
374    11. 土压力    被动土压力    passive earth pressure
375    11. 土压力    被动土压力系数    coefficient of passive earth pressure
376    11. 土压力    极限平衡状态    state of limit equilibrium
377    11. 土压力    静止土压力    earth pressue at rest
378    11. 土压力    静止土压力系数    coefficient of earth pressur at rest
379    11. 土压力    库仑土压力理论    Coulomb's earth pressure theory
380    11. 土压力    库尔曼图解法    Culmannn construction
381    11. 土压力    朗肯土压力理论    Rankine's earth pressure theory
382    11. 土压力    朗肯状态    Rankine state
383    11. 土压力    谈弹性平衡状态    state of elastic equilibrium
384    11. 土压力    土压力    earth pressure
385    11. 土压力    主动土压力    active earth pressure
386    11. 土压力    主动土压力系数    coefficient of active earth pressure
387    12. 土坡稳定分析    安息角(台)    angle of repose
388    12. 土坡稳定分析    毕肖普法    Bishop method
389    12. 土坡稳定分析    边坡稳定安全系数    safety factor of slope
390    12. 土坡稳定分析    不平衡推理传递法    unbalanced thrust transmission method
391    12. 土坡稳定分析    费伦纽斯条分法    Fellenius method of slices
392    12. 土坡稳定分析    库尔曼法    Culmann method
393    12. 土坡稳定分析    摩擦圆法    friction circle method
394    12. 土坡稳定分析    摩根斯坦-普拉斯法    Morgenstern-Price method
395    12. 土坡稳定分析    铅直边坡的临界高度    critical height of vertical slope
396    12. 土坡稳定分析    瑞典圆弧滑动法    Swedish circle method
397    12. 土坡稳定分析    斯宾赛法    Spencer method
398    12. 土坡稳定分析    泰勒法    Taylor method
399    12. 土坡稳定分析    条分法    slice method
400    12. 土坡稳定分析    土坡    slope
401    12. 土坡稳定分析    土坡稳定分析    slope stability analysis
402    12. 土坡稳定分析    土坡稳定极限分析法    limit analysis method of slope stability
403    12. 土坡稳定分析    土坡稳定极限平衡法    limit equilibrium method of slope stability
404    12. 土坡稳定分析    休止角    angle of repose
405    12. 土坡稳定分析    扬布普遍条分法    Janbu general slice method
406    12. 土坡稳定分析    圆弧分析法    circular arc analysis
407    13. 土的动力性质    比阻尼容量    specific gravity capacity
408    13. 土的动力性质    波的弥散特性    dispersion of waves
409    13. 土的动力性质    波速法    wave velocity method
410    13. 土的动力性质    材料阻尼    material damping
411    13. 土的动力性质    初始液化    initial liquefaction
412    13. 土的动力性质    地基固有周期    natural period of soil site
413    13. 土的动力性质    动剪切模量    dynamic shear modulus of soils
414    13. 土的动力性质    动力布西涅斯克解    dynamic solution of Boussinesq
415    13. 土的动力性质    动力放大因素    dynamic magnification factor
416    13. 土的动力性质    动力性质    dynamic properties of soils
417    13. 土的动力性质    动强度    dynamic strength of soils
418    13. 土的动力性质    骨架波    akeleton waves in soils
419    13. 土的动力性质    几何阻尼    geometric damping
420    13. 土的动力性质    抗液化强度    liquefaction stress
421    13. 土的动力性质    孔隙流体波    fluid wave in soil
422    13. 土的动力性质    损耗角    loss angle
423    13. 土的动力性质    往返活动性    reciprocating activity
424    13. 土的动力性质    无量纲频率    dimensionless frequency
425    13. 土的动力性质    液化    liquefaction
426    13. 土的动力性质    液化势评价    evaluation of liquefaction potential
427    13. 土的动力性质    液化应力比    stress ratio of liquefaction
428    13. 土的动力性质    应力波    stress waves in soils
429    13. 土的动力性质    振陷    dynamic settlement
430    13. 土的动力性质    阻尼    damping of soil
431    13. 土的动力性质    阻尼比    damping ratio
432    14. 挡土墙    挡土墙    retaining wall
433    14. 挡土墙    挡土墙排水设施
434    14. 挡土墙    挡土墙稳定性    stability of retaining wall
435    14. 挡土墙    垛式挡土墙
436    14. 挡土墙    扶垛式挡土墙    counterfort retaining wall
437    14. 挡土墙    后垛墙(台)    counterfort retaining wall
438    14. 挡土墙    基础墙    foundation wall
439    14. 挡土墙    加筋土挡墙    reinforced earth bulkhead
440    14. 挡土墙    锚定板挡土墙    anchored plate retaining wall
441    14. 挡土墙    锚定式板桩墙    anchored sheet pile wall
442    14. 挡土墙    锚杆式挡土墙    anchor rod retaining wall
443    14. 挡土墙    悬壁式板桩墙    cantilever sheet pile wall
444    14. 挡土墙    悬壁式挡土墙    cantilever sheet pile wall
生命不息,奋斗不止!
离线qyxmcad
只看该作者 18楼 发表于: 2008-11-02
445    14. 挡土墙    重力式挡土墙    gravity retaining wall
446    15. 板桩结构物    板桩    sheet pile
447    15. 板桩结构物    板桩结构    sheet pile structure
448    15. 板桩结构物    钢板桩    steel sheet pile
449    15. 板桩结构物    钢筋混凝土板桩    reinforced concrete sheet pile
450    15. 板桩结构物    钢桩    steel pile
451    15. 板桩结构物    灌注桩    cast-in-place pile
452    15. 板桩结构物    拉杆    tie rod
453    15. 板桩结构物    锚定式板桩墙    anchored sheet pile wall
454    15. 板桩结构物    锚固技术    anchoring
455    15. 板桩结构物    锚座    Anchorage
456    15. 板桩结构物    木板桩    wooden sheet pile
457    15. 板桩结构物    木桩    timber piles
458    15. 板桩结构物    悬壁式板桩墙    cantilever sheet pile wall
459    16. 基坑开挖与降水    板桩围护    sheet pile-braced cuts
460    16. 基坑开挖与降水    电渗法    electro-osmotic drainage
461    16. 基坑开挖与降水    管涌    piping
462    16. 基坑开挖与降水    基底隆起    heave of base
463    16. 基坑开挖与降水    基坑降水    dewatering
464    16. 基坑开挖与降水    基坑失稳    instability (failure) of foundation pit
465    16. 基坑开挖与降水    基坑围护    bracing of foundation pit
466    16. 基坑开挖与降水    减压井    relief well
467    16. 基坑开挖与降水    降低地下水位法    dewatering method
468    16. 基坑开挖与降水    井点系统    well point system
469    16. 基坑开挖与降水    喷射井点    eductor well point
470    16. 基坑开挖与降水    铅直边坡的临界高度    critical height of vertical slope
471    16. 基坑开挖与降水    砂沸    sand boiling
472    16. 基坑开挖与降水    深井点    deep well point
473    16. 基坑开挖与降水    真空井点    vacuum well point
474    16. 基坑开挖与降水    支撑围护    braced cuts
475    17. 浅基础    杯形基础
476    17. 浅基础    补偿性基础    compensated foundation
477    17. 浅基础    持力层    bearing stratum
478    17. 浅基础    次层(台)    substratum
479    17. 浅基础    单独基础    individual footing
480    17. 浅基础    倒梁法    inverted beam method
481    17. 浅基础    刚性角    pressure distribution angle of masonary foundation
482    17. 浅基础    刚性基础    rigid foundation
483    17. 浅基础    高杯口基础
484    17. 浅基础    基础埋置深度    embeded depth of foundation
485    17. 浅基础    基床系数    coefficient of subgrade reaction
486    17. 浅基础    基底附加应力    net foundation pressure
487    17. 浅基础    交叉条形基础    cross strip footing
488    17. 浅基础    接触压力    contact pressure
489    17. 浅基础    静定分析法(浅基础)    static analysis (shallow foundation)
490    17. 浅基础    壳体基础    shell foundation
491    17. 浅基础    扩展基础    spread footing
492    17. 浅基础    片筏基础    mat foundation
493    17. 浅基础    浅基础    shallow foundation
494    17. 浅基础    墙下条形基础
495    17. 浅基础    热摩奇金法    Zemochkin's method
496    17. 浅基础    柔性基础    flexible foundation
497    17. 浅基础    上部结构-基础-土共同作用分析    structure- foundation-soil interaction analysis
498    17. 浅基础    谈弹性地基梁(板)分析    analysis of beams and slabs on elastic foundation
499    17. 浅基础    条形基础    strip footing
500    17. 浅基础    下卧层    substratum
501    17. 浅基础    箱形基础    box foundation
502    17. 浅基础    柱下条形基础
503    18. 深基础    贝诺托灌注桩    Benoto cast-in-place pile
504    18. 深基础    波动方程分析    Wave equation analysis
505    18. 深基础    场铸桩(台)    cast-in-place pile
506    18. 深基础    沉管灌注桩    diving casting cast-in-place pile
507    18. 深基础    沉井基础    open-end caisson foundation
508    18. 深基础    沉箱基础    box caisson foundation
509    18. 深基础    成孔灌注同步桩    synchronous pile
510    18. 深基础    承台    pile caps
511    18. 深基础    充盈系数    fullness coefficient
512    18. 深基础    单桩承载力    bearing capacity of single pile
513    18. 深基础    单桩横向极限承载力    ultimate lateral resistance of single pile
514    18. 深基础    单桩竖向抗拔极限承载力    vertical ultimate uplift resistance of single pile
515    18. 深基础    单桩竖向抗压容许承载力    vertical ultimate carrying capacity of single pile
516    18. 深基础    单桩竖向抗压极限承载力    vertical allowable load capacity of single pile
517    18. 深基础    低桩承台    low pile cap
518    18. 深基础    地下连续墙    diaphgram wall
519    18. 深基础    点承桩(台)    end-bearing pile
520    18. 深基础    动力打桩公式    dynamic pile driving formula
521    18. 深基础    端承桩    end-bearing pile
522    18. 深基础    法兰基灌注桩    Franki pile
523    18. 深基础    负摩擦力    negative skin friction of pile
524    18. 深基础    钢筋混凝土预制桩    precast reinforced concrete piles
525    18. 深基础    钢桩    steel pile
526    18. 深基础    高桩承台    high-rise pile cap
527    18. 深基础    灌注桩    cast-in-place pile
528    18. 深基础    横向载荷桩    laterally loaded vertical piles
529    18. 深基础    护壁泥浆    slurry coat method
530    18. 深基础    回转钻孔灌注桩    rotatory boring cast-in-place pile
531    18. 深基础    机挖异形灌注桩
532    18. 深基础    静力压桩    silent piling
533    18. 深基础    抗拔桩    uplift pile
534    18. 深基础    抗滑桩    anti-slide pile
535    18. 深基础    摩擦桩    friction pile
536    18. 深基础    木桩    timber piles
537    18. 深基础    嵌岩灌注桩    piles set into rock
538    18. 深基础    群桩    pile groups
539    18. 深基础    群桩效率系数    efficiency factor of pile groups
540    18. 深基础    群桩效应    efficiency of pile groups
541    18. 深基础    群桩竖向极限承载力    vertical ultimate load capacity of pile groups
542    18. 深基础    深基础    deep foundation
543    18. 深基础    竖直群桩横向极限承载力
544    18. 深基础    无桩靴夯扩灌注桩    rammed bulb ile
545    18. 深基础    旋转挤压灌注桩
546    18. 深基础    桩    piles
547    18. 深基础    桩基动测技术    dynamic pile test
548    18. 深基础    钻孔墩基础    drilled-pier foundation
549    18. 深基础    钻孔扩底灌注桩    under-reamed bored pile
550    18. 深基础    钻孔压注桩    starsol enbesol pile
551    18. 深基础    最后贯入度    final set
552    19. 地基处理    表层压密法    surface compaction
553    19. 地基处理    超载预压    surcharge preloading
554    19. 地基处理    袋装砂井    sand wick
555    19. 地基处理    地工织物    geofabric, geotextile
556    19. 地基处理    地基处理    ground treatment, foundation treatment
557    19. 地基处理    电动化学灌浆    electrochemical grouting
558    19. 地基处理    电渗法    electro-osmotic drainage
559    19. 地基处理    顶升纠偏法
560    19. 地基处理    定喷    directional jet grouting
561    19. 地基处理    冻土地基处理    frozen foundation improvement
562    19. 地基处理    短桩处理    treatment with short pile
563    19. 地基处理    堆载预压法    preloading
564    19. 地基处理    粉体喷射深层搅拌法    powder deep mixing method
565    19. 地基处理    复合地基    composite foundation
566    19. 地基处理    干振成孔灌注桩    vibratory bored pile
567    19. 地基处理    高压喷射注浆法    jet grounting
568    19. 地基处理    灌浆材料    injection material
569    19. 地基处理    灌浆法    grouting
570    19. 地基处理    硅化法    silicification
571    19. 地基处理    夯实桩    compacting pile
572    19. 地基处理    化学灌浆    chemical grouting
573    19. 地基处理    换填法    cushion
574    19. 地基处理    灰土桩    lime soil pile
575    19. 地基处理    基础加压纠偏法
576    19. 地基处理    挤密灌浆    compaction grouting
577    19. 地基处理    挤密桩    compaction pile, compacted column
578    19. 地基处理    挤淤法    displacement method
579    19. 地基处理    加筋法    reinforcement method
580    19. 地基处理    加筋土    reinforced earth
581    19. 地基处理    碱液法    soda solution grouting
582    19. 地基处理    浆液深层搅拌法    grout deep mixing method
583    19. 地基处理    降低地下水位法    dewatering method
584    19. 地基处理    纠偏技术
585    19. 地基处理    坑式托换    pit underpinning
586    19. 地基处理    冷热处理法    freezing and heating
587    19. 地基处理    锚固技术    anchoring
588    19. 地基处理    锚杆静压桩托换    anchor pile underpinning
589    19. 地基处理    排水固结法    consolidation
590    19. 地基处理    膨胀土地基处理    expansive foundation treatment
591    19. 地基处理    劈裂灌浆    fracture grouting
592    19. 地基处理    浅层处理    shallow treatment
生命不息,奋斗不止!
离线qyxmcad
只看该作者 19楼 发表于: 2008-11-02
593    19. 地基处理    强夯法    dynamic compaction
594    19. 地基处理    人工地基    artificial foundation
595    19. 地基处理    容许灌浆压力    allowable grouting pressure
596    19. 地基处理    褥垫    pillow
597    19. 地基处理    软土地基    soft clay ground
598    19. 地基处理    砂井    sand drain
599    19. 地基处理    砂井地基平均固结度    average degree of consolidation of sand-drained ground
600    19. 地基处理    砂桩    sand column
601    19. 地基处理    山区地基处理    foundation treatment in mountain area
602    19. 地基处理    深层搅拌法    deep mixing method
603    19. 地基处理    渗入性灌浆    seep-in grouting
604    19. 地基处理    湿陷性黄土地基处理    collapsible loess treatment
605    19. 地基处理    石灰系深层搅拌法    lime deep mixing method
606    19. 地基处理    石灰桩    lime column, limepile
607    19. 地基处理    树根桩    root pile
608    19. 地基处理    水泥土水泥掺合比    cement mixing ratio
609    19. 地基处理    水泥系深层搅拌法    cement deep mixing method
610    19. 地基处理    水平旋喷    horizontal jet grouting
611    19. 地基处理    塑料排水带    plastic drain
612    19. 地基处理    碎石桩    gravel pile, stone pillar
613    19. 地基处理    掏土纠偏法
614    19. 地基处理    天然地基    natural foundation
615    19. 地基处理    土工聚合物    Geopolymer
616    19. 地基处理    土工织物    geofabric, geotextile
617    19. 地基处理    土桩    earth pile
618    19. 地基处理    托换技术    underpinning technique
619    19. 地基处理    外掺剂    additive
620    19. 地基处理    旋喷    jet grouting
621    19. 地基处理    药液灌浆    chemical grouting
622    19. 地基处理    预浸水法    presoaking
623    19. 地基处理    预压法    preloading
624    19. 地基处理    真空预压    vacuum preloading
625    19. 地基处理    振冲法    vibroflotation method
626    19. 地基处理    振冲密实法    vibro-compaction
627    19. 地基处理    振冲碎石桩    vibro replacement stone column
628    19. 地基处理    振冲置换法    vibro-replacement
629    19. 地基处理    振密、挤密法    vibro-densification, compacting
630    19. 地基处理    置换率(复合地基)    replacement ratio
631    19. 地基处理    重锤夯实法    tamping
632    19. 地基处理    桩式托换    pile underpinning
633    19. 地基处理    桩土应力比    stress ratio
634    20. 动力机器基础    比阻尼容量    specific gravity capacity
635    20. 动力机器基础    等效集总参数法    constant strain rate consolidation test
636    20. 动力机器基础    地基固有周期    natural period of soil site
637    20. 动力机器基础    动基床反力法    dynamic subgrade reaction method
638    20. 动力机器基础    动力放大因素    dynamic magnification factor
639    20. 动力机器基础    隔振    isolation
640    20. 动力机器基础    基础振动    foundation vibration
641    20. 动力机器基础    基础振动半空间理论    elastic half-space theory of foundation vibration
642    20. 动力机器基础    基础振动容许振幅    allowable amplitude of foundation vibration
643    20. 动力机器基础    基础自振频率    natural frequency of foundation
644    20. 动力机器基础    集总参数法    lumped parameter method
645    20. 动力机器基础    吸收系数    absorption coefficient
646    20. 动力机器基础    质量-弹簧-阻尼器系统    mass-spring-dushpot system
647    21. 地基基础抗震    地基固有周期    natural period of soil site
648    21. 地基基础抗震    地震    earthquake, seism, temblor
649    21. 地基基础抗震    地震持续时间    duration of earthquake
650    21. 地基基础抗震    地震等效均匀剪应力    equivalent even shear stress of earthquake
651    21. 地基基础抗震    地震反应谱    earthquake response spectrum
652    21. 地基基础抗震    地震烈度    earthquake intensity
653    21. 地基基础抗震    地震震级    earthquake magnitude
654    21. 地基基础抗震    地震卓越周期    seismic predominant period
655    21. 地基基础抗震    地震最大加速度    maximum acceleration of earthquake
656    21. 地基基础抗震    动力放大因数    dynamic magnification factor
657    21. 地基基础抗震    对数递减率    logrithmic decrement
658    21. 地基基础抗震    刚性系数    coefficient of rigidity
659    21. 地基基础抗震    吸收系数    absorption coefficient
660    22. 室内土工试验    比重试验    specific gravity test
661    22. 室内土工试验    变水头渗透试验    falling head permeability test
662    22. 室内土工试验    不固结不排水试验    unconsolidated-undrained triaxial test
663    22. 室内土工试验    常规固结试验    routine consolidation test
664    22. 室内土工试验    常水头渗透试验    constant head permeability test
665    22. 室内土工试验    单剪仪    simple shear apparatus
666    22. 室内土工试验    单轴拉伸试验    uniaxial tensile test
667    22. 室内土工试验    等速加荷固结试验    constant loading rate consolidatin test
668    22. 室内土工试验    等梯度固结试验    constant gradient consolidation test
669    22. 室内土工试验    等应变速率固结试验    equivalent lumped parameter method
670    22. 室内土工试验    反复直剪强度试验    repeated direct shear test
671    22. 室内土工试验    反压饱和法    back pressure saturation method
672    22. 室内土工试验    高压固结试验    high pressure consolidation test
673    22. 室内土工试验    各向不等压固结不排水试验    consoidated anisotropically undrained test
674    22. 室内土工试验    各向不等压固结排水试验    consolidated anisotropically drained test
675    22. 室内土工试验    共振柱试验    resonant column test
676    22. 室内土工试验    固结不排水试验    consolidated undrained triaxial test
677    22. 室内土工试验    固结快剪试验    consolidated quick direct shear test
678    22. 室内土工试验    固结排水试验    consolidated drained triaxial test
679    22. 室内土工试验    固结试验    consolidation test
680    22. 室内土工试验    含水量试验    water content test
681    22. 室内土工试验    环剪试验    ring shear test
682    22. 室内土工试验    黄土湿陷试验    loess collapsibility test
683    22. 室内土工试验    击实试验
684    22. 室内土工试验    界限含水量试验    Atterberg limits test
685    22. 室内土工试验    卡萨格兰德法    Casagrande's method
686    22. 室内土工试验    颗粒分析试验    grain size analysis test
687    22. 室内土工试验    孔隙水压力消散试验    pore pressure dissipation test
688    22. 室内土工试验    快剪试验    quick direct shear test
689    22. 室内土工试验    快速固结试验    fast consolidation test
690    22. 室内土工试验    离心模型试验    centrifugal model test
691    22. 室内土工试验    连续加荷固结试验    continual loading test
692    22. 室内土工试验    慢剪试验    consolidated drained direct shear test
693    22. 室内土工试验    毛细管上升高度试验    capillary rise test
694    22. 室内土工试验    密度试验    density test
695    22. 室内土工试验    扭剪仪    torsion shear apparatus
696    22. 室内土工试验    膨胀率试验    swelling rate test
697    22. 室内土工试验    平面应变仪    plane strain apparatus
698    22. 室内土工试验    三轴伸长试验    triaxial extension test
699    22. 室内土工试验    三轴压缩试验    triaxial compression test
700    22. 室内土工试验    砂的相对密实度试验    sand relative density test
701    22. 室内土工试验    筛分析    sieve analysis
702    22. 室内土工试验    渗透试验    permeability test
703    22. 室内土工试验    湿化试验    slaking test
704    22. 室内土工试验    收缩试验    shrinkage test
705    22. 室内土工试验    塑限试验    plastic limit test
706    22. 室内土工试验    缩限试验    shrinkage limit test
707    22. 室内土工试验    土工模型试验    geotechnical model test
708    22. 室内土工试验    土工织物试验    geotextile test
709    22. 室内土工试验    无侧限抗压强度试验    unconfined compression strength test
710    22. 室内土工试验    无粘性土天然坡角试验    angle of repose of cohesionless soils test
711    22. 室内土工试验    压密不排水三轴压缩试验    consolidated undrained triaxial compression test
712    22. 室内土工试验    压密排水三轴压缩试验    consolidated drained triaxial compressure test
713    22. 室内土工试验    压密试验    consolidation test
714    22. 室内土工试验    液塑限联合测定法    liquid-plastic limit combined method
715    22. 室内土工试验    液限试验    liquid limit test
716    22. 室内土工试验    应变控制式三轴压缩仪    strain control triaxial compression apparatus
717    22. 室内土工试验    应力控制式三轴压缩仪    stress control triaxial compression apparatus
718    22. 室内土工试验    有机质含量试验    organic matter content test
719    22. 室内土工试验    真三轴仪    true triaxial apparatus
720    22. 室内土工试验    振动单剪试验    dynamic simple shear test
721    22. 室内土工试验    直剪仪    direct shear apparatus
722    22. 室内土工试验    直接剪切试验    direct shear test
723    22. 室内土工试验    直接单剪试验    direct simple shear test
724    22. 室内土工试验    自振柱试验    free vibration column test
725    22. 室内土工试验    K0固结不排水试验    K0 consolidated undrained test
726    22. 室内土工试验    K0固结排水试验    K0 consolidated drained test
727    23. 原位测试    标准贯入试验    standard penetration test
728    23. 原位测试    表面波试验    surface wave test
729    23. 原位测试    超声波试验    ultrasonic wave test
730    23. 原位测试    承载比试验    Californian Bearing Ratio Test
731    23. 原位测试    单桩横向载荷试验    lateral load test of pile
732    23. 原位测试    单桩竖向静载荷试验    static load test of pile
733    23. 原位测试    动力触探试验    dynamic penetration test
734    23. 原位测试    静力触探试验    static cone penetration test
735    23. 原位测试    静力载荷试验    plate loading test
736    23. 原位测试    跨孔试验    cross-hole test
737    23. 原位测试    块体共振试验    block resonant test
738    23. 原位测试    螺旋板载荷试验    screw plate test
739    23. 原位测试    旁压试验    pressurementer test
740    23. 原位测试    轻便触探试验    light sounding test
741    23. 原位测试    深层沉降观测    deep settlement measurement
生命不息,奋斗不止!
离线qyxmcad
只看该作者 20楼 发表于: 2008-11-02
742    23. 原位测试    十字板剪切试验    vane shear test
743    23. 原位测试    无损检测    nondestructive testing
744    23. 原位测试    下孔法试验    down-hole test
745    23. 原位测试    现场渗透试验    field permeability test
746    23. 原位测试    原位孔隙水压力量测    in situ pore water pressure measurement
747    23. 原位测试    原位试验    in-situ soil test
748    23. 原位测试    最后贯入度    final set
力学词汇
力学 mechanics
牛顿力学 Newtonian mechanics
经典力学 classical mechanics
静力学 statics
运动学 kinematics
动力学 dynamics
动理学 kinetics
宏观力学 macroscopic mechanics,macromechanics
细观力学 mesomechanics
微观力学 microscopic mechanics,micromechanics
一般力学 general mechanics
固体力学 solid mechanics
流体力学 fluid mechanics
理论力学 theoretical mechanics
应用力学 applied mechanics
工程力学 engineering mechanics
实验力学 experimental mechanics
计算力学 computational mechanics
理性力学 rational mechanics
物理力学 physical mechanics
地球动力学 geodynamics
力 force
作用点 point of action
作用线 line of action
力系 system of forces
力系的简化 reduction of force system
等效力系 equivalent force system
刚体 rigid body
力的可传性 transmissibility of force
平行四边形定则 parallelogram rule
力三角形 force triangle
力多边形 force polygon
零力系 null-force system
平衡 equilibrium
力的平衡 equilibrium of forces
平衡条件 equilibrium condition
平衡位置 equilibrium position
平衡态 equilibrium state
分析力学 analytical mechanics
拉格朗日乘子 Lagrange multiplier
拉格朗日[量] Lagrangian
拉格朗日括号 Lagrange bracket
循环坐标 cyclic coordinate
循环积分 cyclic integral
哈密顿[量] Hamiltonian
哈密顿函数 Hamiltonian function
正则方程 canonical equation
正则摄动 canonical perturbation
正则变换 canonical transformation
正则变量 canonical variable
哈密顿原理 Hamilton principle
作用量积分 action integral
哈密顿--雅可比方程 Hamilton-Jacobi equation
作用--角度变量 action-angle variables
阿佩尔方程 Appell equation
劳斯方程 Routh equation
拉格朗日函数 Lagrangian function
诺特定理 Noether theorem
泊松括号 poisson bracket
边界积分法 boundary integral method
并矢 dyad
运动稳定性 stability of motion
轨道稳定性 orbital stability
李雅普诺夫函数 Lyapunov function
渐近稳定性 asymptotic stability
结构稳定性 structural stability
久期不稳定性 secular instability
弗洛凯定理 Floquet theorem
倾覆力矩 capsizing moment
自由振动 free vibration
固有振动 natural vibration
暂态 transient state
环境振动 ambient vibration
反共振 anti-resonance
衰减 attenuation
库仑阻尼 Coulomb damping
同相分量 in-phase component
非同相分量 out-of -phase component
超调量 overshoot
参量[激励]振动 parametric vibration
模糊振动 fuzzy vibration
临界转速 critical speed of rotation
阻尼器 damper
半峰宽度 half-peak width
集总参量系统 lumped parameter system
相平面法 phase plane method
相轨迹 phase trajectory
等倾线法 isocline method
跳跃现象 jump phenomenon
负阻尼 negative damping
达芬方程 Duffing equation
希尔方程 Hill equation
KBM方法 KBM method, Krylov-Bogoliu-bov-Mitropol'skii method
马蒂厄方程 Mathieu equation
平均法 averaging method
组合音调 combination tone
解谐 detuning
耗散函数 dissipative function
硬激励 hard excitation
硬弹簧 hard spring, hardening spring
谐波平衡法 harmonic balance method
久期项 secular term
自激振动 self-excited vibration
分界线 separatrix
亚谐波 subharmonic
软弹簧 soft spring ,softening spring
软激励 soft excitation
邓克利公式 Dunkerley formula
瑞利定理 Rayleigh theorem
分布参量系统 distributed parameter system
优势频率 dominant frequency
模态分析 modal analysis
固有模态 natural mode of vibration
同步 synchronization
超谐波 ultraharmonic
范德波尔方程 van der pol equation
频谱 frequency spectrum
基频 fundamental frequency
生命不息,奋斗不止!
离线qyxmcad
只看该作者 21楼 发表于: 2008-11-02
WKB方法 WKB method, Wentzel-Kramers-Brillouin method
缓冲器 buffer
风激振动 aeolian vibration
嗡鸣 buzz
倒谱 cepstrum
颤动 chatter
蛇行 hunting
阻抗匹配 impedance matching
机械导纳 mechanical admittance
机械效率 mechanical efficiency
机械阻抗 mechanical impedance
随机振动 stochastic vibration, random vibration
隔振 vibration isolation
减振 vibration reduction
应力过冲 stress overshoot
喘振 surge
摆振 shimmy
起伏运动 phugoid motion
起伏振荡 phugoid oscillation
驰振 galloping
陀螺动力学 gyrodynamics
陀螺摆 gyropendulum
陀螺平台 gyroplatform
陀螺力矩 gyroscoopic torque
陀螺稳定器 gyrostabilizer
陀螺体 gyrostat
惯性导航 inertial guidance
姿态角 attitude angle
方位角 azimuthal angle
舒勒周期 Schuler period
机器人动力学 robot dynamics
多体系统 multibody system
多刚体系统 multi-rigid-body system
机动性 maneuverability
凯恩方法 Kane method
转子[系统]动力学 rotor dynamics
转子[一支承一基础]系统 rotor-support-foundation system
静平衡 static balancing
动平衡 dynamic balancing
静不平衡 static unbalance
动不平衡 dynamic unbalance
现场平衡 field balancing
不平衡 unbalance
不平衡量 unbalance
互耦力 cross force
挠性转子 flexible rotor
分频进动 fractional frequency precession
半频进动 half frequency precession
油膜振荡 oil whip
转子临界转速 rotor critical speed
自动定心 self-alignment
亚临界转速 subcritical speed
涡动 whirl
弹性力学 elasticity
弹性理论 theory of elasticity
均匀应力状态 homogeneous state of stress
应力不变量 stress invariant
应变不变量 strain invariant
应变椭球 strain ellipsoid
均匀应变状态 homogeneous state of strain
应变协调方程 equation of strain compatibility
拉梅常量 Lame constants
各向同性弹性 isotropic elasticity
旋转圆盘 rotating circular disk
楔 wedge
开尔文问题 Kelvin problem
布西内斯克问题 Boussinesq problem
艾里应力函数 Airy stress function
克罗索夫--穆斯赫利什维利法 Kolosoff-Muskhelishvili method
基尔霍夫假设 Kirchhoff hypothesis
板 Plate
矩形板 Rectangular plate
圆板 Circular plate
环板 Annular plate
波纹板 Corrugated plate
加劲板 Stiffened plate,reinforced Plate
中厚板 Plate of moderate thickness
弯[曲]应力函数 Stress function of bending
壳 Shell
扁壳 Shallow shell
旋转壳 Revolutionary shell
球壳 Spherical shell
[圆]柱壳 Cylindrical shell
锥壳 Conical shell
环壳 Toroidal shell
封闭壳 Closed shell
波纹壳 Corrugated shell
扭[转]应力函数 Stress function of torsion
翘曲函数 Warping function
半逆解法 semi-inverse method
瑞利--里茨法 Rayleigh-Ritz method
松弛法 Relaxation method
莱维法 Levy method
松弛 Relaxation
量纲分析 Dimensional analysis
自相似[性] self-similarity
影响面 Influence surface
接触应力 Contact stress
赫兹理论 Hertz theory
协调接触 Conforming contact
滑动接触 Sliding contact
滚动接触 Rolling contact
压入 Indentation
各向异性弹性 Anisotropic elasticity
颗粒材料 Granular material
散体力学 Mechanics of granular media
热弹性 Thermoelasticity
超弹性 Hyperelasticity
粘弹性 Viscoelasticity
对应原理 Correspondence principle
褶皱 Wrinkle
塑性全量理论 Total theory of plasticity
滑动 Sliding
微滑 Microslip
粗糙度 Roughness
非线性弹性 Nonlinear elasticity
大挠度 Large deflection
突弹跳变 snap-through
有限变形 Finite deformation
格林应变 Green strain
阿尔曼西应变 Almansi strain
弹性动力学 Dynamic elasticity
运动方程 Equation of motion
准静态的 Quasi-static
气动弹性 Aeroelasticity
水弹性 Hydroelasticity
颤振 Flutter
弹性波 Elastic wave
简单波 Simple wave
柱面波 Cylindrical wave
水平剪切波 Horizontal shear wave
竖直剪切波 Vertical shear wave
体波 body wave
无旋波 Irrotational wave
畸变波 Distortion wave
膨胀波 Dilatation wave
瑞利波 Rayleigh wave
等容波 Equivoluminal wave
勒夫波 Love wave
界面波 Interfacial wave
边缘效应 edge effect
塑性力学 Plasticity
可成形性 Formability
金属成形 Metal forming
耐撞性 Crashworthiness
结构抗撞毁性 Structural crashworthiness
拉拔 Drawing
破坏机构 Collapse mechanism
回弹 Springback
挤压 Extrusion
冲压 Stamping
穿透 Perforation
层裂 Spalling
塑性理论 Theory of plasticity
安定[性]理论 Shake-down theory
运动安定定理 kinematic shake-down theorem
静力安定定理 Static shake-down theorem
率相关理论 rate dependent theorem
载荷因子 load factor
加载准则 Loading criterion
加载函数 Loading function
加载面 Loading surface
塑性加载 Plastic loading
塑性加载波 Plastic loading wave
简单加载 Simple loading
比例加载 Proportional loading
卸载 Unloading
卸载波 Unloading wave
冲击载荷 Impulsive load
阶跃载荷 step load
脉冲载荷 pulse load
极限载荷 limit load
中性变载 nentral loading
拉抻失稳 instability in tension
加速度波 acceleration wave
本构方程 constitutive equation
完全解 complete solution
名义应力 nominal stress
过应力 over-stress
真应力 true stress
等效应力 equivalent stress
流动应力 flow stress
应力间断 stress discontinuity
应力空间 stress space
主应力空间 principal stress space
静水应力状态 hydrostatic state of stress
对数应变 logarithmic strain
工程应变 engineering strain
等效应变 equivalent strain
应变局部化 strain localization
应变率 strain rate
应变率敏感性 strain rate sensitivity
应变空间 strain space
有限应变 finite strain
塑性应变增量 plastic strain increment
累积塑性应变 accumulated plastic strain
永久变形 permanent deformation
内变量 internal variable
应变软化 strain-softening
理想刚塑性材料 rigid-perfectly plastic Material
刚塑性材料 rigid-plastic material
理想塑性材料 perfectl plastic material
材料稳定性 stability of material
应变偏张量 deviatoric tensor of strain
应力偏张量 deviatori tensor of stress
应变球张量 spherical tensor of strain
应力球张量 spherical tensor of stress
路径相关性 path-dependency
线性强化 linear strain-hardening
应变强化 strain-hardening
随动强化 kinematic hardening
各向同性强化 isotropic hardening
强化模量 strain-hardening modulus
幂强化 power hardening
塑性极限弯矩 plastic limit bending Moment
塑性极限扭矩 plastic limit torque
弹塑性弯曲 elastic-plastic bending
弹塑性交界面 elastic-plastic interface
弹塑性扭转 elastic-plastic torsion
生命不息,奋斗不止!
离线qyxmcad
只看该作者 22楼 发表于: 2008-11-02
粘塑性 Viscoplasticity
非弹性 Inelasticity
理想弹塑性材料 elastic-perfectly plastic Material
极限分析 limit analysis
极限设计 limit design
极限面 limit surface
上限定理 upper bound theorem
上屈服点 upper yield point
下限定理 lower bound theorem
下屈服点 lower yield point
界限定理 bound theorem
初始屈服面 initial yield surface
后继屈服面 subsequent yield surface
屈服面[的]外凸性 convexity of yield surface
截面形状因子 shape factor of cross-section
沙堆比拟 sand heap analogy
屈服 Yield
屈服条件 yield condition
屈服准则 yield criterion
屈服函数 yield function
屈服面 yield surface
塑性势 plastic potential
能量吸收装置 energy absorbing device
能量耗散率 energy absorbing device
塑性动力学 dynamic plasticity
塑性动力屈曲 dynamic plastic buckling
塑性动力响应 dynamic plastic response
塑性波 plastic wave
运动容许场 kinematically admissible Field
静力容许场 statically admissible Field
流动法则 flow rule
速度间断 velocity discontinuity
滑移线 slip-lines
滑移线场 slip-lines field
移行塑性铰 travelling plastic hinge
塑性增量理论 incremental theory of Plasticity
米泽斯屈服准则 Mises yield criterion
普朗特--罗伊斯关系 prandtl- Reuss relation
特雷斯卡屈服准则 Tresca yield criterion
洛德应力参数 Lode stress parameter
莱维--米泽斯关系 Levy-Mises relation
亨基应力方程 Hencky stress equation
赫艾--韦斯特加德应力空间 Haigh-Westergaard stress space
洛德应变参数 Lode strain parameter
德鲁克公设 Drucker postulate
盖林格速度方程 Geiringer velocity Equation
结构力学 structural mechanics
结构分析 structural analysis
结构动力学 structural dynamics
拱 Arch
三铰拱 three-hinged arch
抛物线拱 parabolic arch
圆拱 circular arch
穹顶 Dome
空间结构 space structure
空间桁架 space truss
雪载[荷] snow load
风载[荷] wind load
土压力 earth pressure
地震载荷 earthquake loading
弹簧支座 spring support
支座位移 support displacement
支座沉降 support settlement
超静定次数 degree of indeterminacy
机动分析 kinematic analysis
结点法 method of joints
截面法 method of sections
结点力 joint forces
共轭位移 conjugate displacement
影响线 influence line
三弯矩方程 three-moment equation
单位虚力 unit virtual force
刚度系数 stiffness coefficient
柔度系数 flexibility coefficient
力矩分配 moment distribution
力矩分配法 moment distribution method
力矩再分配 moment redistribution
分配系数 distribution factor
矩阵位移法 matri displacement method
单元刚度矩阵 element stiffness matrix
单元应变矩阵 element strain matrix
总体坐标 global coordinates
贝蒂定理 Betti theorem
高斯--若尔当消去法 Gauss-Jordan elimination Method
屈曲模态 buckling mode
复合材料力学 mechanics of composites
复合材料 composite material
纤维复合材料 fibrous composite
单向复合材料 unidirectional composite
泡沫复合材料 foamed composite
颗粒复合材料 particulate composite
层板 Laminate
夹层板 sandwich panel
正交层板 cross-ply laminate
斜交层板 angle-ply laminate
层片 Ply
多胞固体 cellular solid
膨胀 Expansion
压实 Debulk
劣化 Degradation
脱层 Delamination
脱粘 Debond
纤维应力 fiber stress
层应力 ply stress
层应变 ply strain
层间应力 interlaminar stress
比强度 specific strength
强度折减系数 strength reduction factor
强度应力比 strength -stress ratio
横向剪切模量 transverse shear modulus
横观各向同性 transverse isotropy
正交各向异 Orthotropy
剪滞分析 shear lag analysis
短纤维 chopped fiber
长纤维 continuous fiber
纤维方向 fiber direction
纤维断裂 fiber break
纤维拔脱 fiber pull-out
纤维增强 fiber reinforcement
致密化 Densification
最小重量设计 optimum weight design
网格分析法 netting analysis
混合律 rule of mixture
失效准则 failure criterion
蔡--吴失效准则 Tsai-W u failure criterion
达格代尔模型 Dugdale model
断裂力学 fracture mechanics
概率断裂力学 probabilistic fracture Mechanics
格里菲思理论 Griffith theory
线弹性断裂力学 linear elastic fracture mechanics, LEFM
弹塑性断裂力学 elastic-plastic fracture mecha-nics, EPFM
断裂 Fracture
脆性断裂 brittle fracture
解理断裂 cleavage fracture
蠕变断裂 creep fracture
延性断裂 ductile fracture
晶间断裂 inter-granular fracture
准解理断裂 quasi-cleavage fracture
穿晶断裂 trans-granular fracture
裂纹 Crack
裂缝 Flaw
缺陷 Defect
割缝 Slit
微裂纹 Microcrack
折裂 Kink
椭圆裂纹 elliptical crack
深埋裂纹 embedded crack
[钱]币状裂纹 penny-shape crack
预制裂纹 Precrack
短裂纹 short crack
表面裂纹 surface crack
裂纹钝化 crack blunting
裂纹分叉 crack branching
裂纹闭合 crack closure
裂纹前缘 crack front
裂纹嘴 crack mouth
裂纹张开角 crack opening angle,COA
裂纹张开位移 crack opening displacement, COD
裂纹阻力 crack resistance
裂纹面 crack surface
裂纹尖端 crack tip
裂尖张角 crack tip opening angle, CTOA
裂尖张开位移 crack tip opening displacement, CTOD
裂尖奇异场 crack tip singularity Field
裂纹扩展速率 crack growth rate
稳定裂纹扩展 stable crack growth
定常裂纹扩展 steady crack growth
亚临界裂纹扩展 subcritical crack growth
裂纹[扩展]减速 crack retardation
止裂 crack arrest
止裂韧度 arrest toughness
断裂类型 fracture mode
滑开型 sliding mode
张开型 opening mode
撕开型 tearing mode
复合型 mixed mode
撕裂 Tearing
撕裂模量 tearing modulus
断裂准则 fracture criterion
J积分 J-integral
J阻力曲线 J-resistance curve
断裂韧度 fracture toughness
应力强度因子 stress intensity factor
HRR场 Hutchinson-Rice-Rosengren Field
守恒积分 conservation integral
有效应力张量 effective stress tensor
应变能密度 strain energy density
能量释放率 energy release rate
内聚区 cohesive zone
塑性区 plastic zone
张拉区 stretched zone
热影响区 heat affected zone, HAZ
延脆转变温度 brittle-ductile transition temperature
剪切带 shear band
剪切唇 shear lip
无损检测 non-destructive inspection
双边缺口试件 double edge notched specimen, DEN specimen
单边缺口试件 single edge notched specimen, SEN specimen
三点弯曲试件 three point bending specimen, TPB specimen
中心裂纹拉伸试件 center cracked tension specimen, CCT specimen
中心裂纹板试件 center cracked panel specimen, CCP specimen
紧凑拉伸试件 compact tension specimen, CT specimen
大范围屈服 large scale yielding
小范围攻屈服 small scale yielding
韦布尔分布 Weibull distribution
帕里斯公式 paris formula
空穴化 Cavitation
应力腐蚀 stress corrosion
概率风险判定 probabilistic risk assessment, PRA
损伤力学 damage mechanics
损伤 Damage
连续介质损伤力学 continuum damage mechanics
细观损伤力学 microscopic damage mechanics
累积损伤 accumulated damage
脆性损伤 brittle damage
延性损伤 ductile damage
宏观损伤 macroscopic damage
细观损伤 microscopic damage
微观损伤 microscopic damage
损伤准则 damage criterion
损伤演化方程 damage evolution equation
损伤软化 damage softening
损伤强化 damage strengthening
损伤张量 damage tensor
损伤阈值 damage threshold
损伤变量 damage variable
损伤矢量 damage vector
损伤区 damage zone
疲劳 Fatigue
低周疲劳 low cycle fatigue
应力疲劳 stress fatigue
随机疲劳 random fatigue
蠕变疲劳 creep fatigue
腐蚀疲劳 corrosion fatigue
疲劳损伤 fatigue damage
疲劳失效 fatigue failure
疲劳断裂 fatigue fracture
疲劳裂纹 fatigue crack
疲劳寿命 fatigue life
疲劳破坏 fatigue rupture
疲劳强度 fatigue strength
疲劳辉纹 fatigue striations
疲劳阈值 fatigue threshold
交变载荷 alternating load
交变应力 alternating stress
应力幅值 stress amplitude
应变疲劳 strain fatigue
应力循环 stress cycle
应力比 stress ratio
安全寿命 safe life
过载效应 overloading effect
循环硬化 cyclic hardening
循环软化 cyclic softening
环境效应 environmental effect
裂纹片 crack gage
裂纹扩展 crack growth, crack Propagation
裂纹萌生 crack initiation
循环比 cycle ratio
实验应力分析 experimental stress Analysis
工作[应变]片 active[strain] gage
基底材料 backing material
应力计 stress gage
零[点]飘移 zero shift, zero drift
应变测量 strain measurement
应变计 strain gage
应变指示器 strain indicator
应变花 strain rosette
应变灵敏度 strain sensitivity
机械式应变仪 mechanical strain gage
直角应变花 rectangular rosette
引伸仪 Extensometer
应变遥测 telemetering of strain
横向灵敏系数 transverse gage factor
横向灵敏度 transverse sensitivity
焊接式应变计 weldable strain gage
平衡电桥 balanced bridge
粘贴式应变计 bonded strain gage
粘贴箔式应变计 bonded foiled gage
粘贴丝式应变计 bonded wire gage
桥路平衡 bridge balancing
电容应变计 capacitance strain gage
补偿片 compensation technique
补偿技术 compensation technique
基准电桥 reference bridge
电阻应变计 resistance strain gage
温度自补偿应变计 self-temperature compensating gage
半导体应变计 semiconductor strain Gage
集流器 slip ring
应变放大镜 strain amplifier
疲劳寿命计 fatigue life gage
电感应变计 inductance [strain] gage
光[测]力学 Photomechanics
光弹性 Photoelasticity
光塑性 Photoplasticity
杨氏条纹 Young fringe
双折射效应 birefrigent effect
等位移线 contour of equal Displacement
暗条纹 dark fringe
条纹倍增 fringe multiplication
干涉条纹 interference fringe
等差线 Isochromatic
等倾线 Isoclinic
等和线 isopachic
应力光学定律 stress- optic law
主应力迹线 Isostatic
亮条纹 light fringe
光程差 optical path difference
热光弹性 photo-thermo -elasticity
光弹性贴片法 photoelastic coating Method
光弹性夹片法 photoelastic sandwich Method
动态光弹性 dynamic photo-elasticity
空间滤波 spatial filtering
空间频率 spatial frequency
起偏镜 Polarizer
反射式光弹性仪 reflection polariscope
残余双折射效应 residual birefringent Effect
应变条纹值 strain fringe value
应变光学灵敏度 strain-optic sensitivity
应力冻结效应 stress freezing effect
应力条纹值 stress fringe value
应力光图 stress-optic pattern
暂时双折射效应 temporary birefringent Effect
脉冲全息法 pulsed holography
透射式光弹性仪 transmission polariscope
实时全息干涉法 real-time holographic interferometry
网格法 grid method
全息光弹性法 holo-photoelasticity
全息图 Hologram
全息照相 Holograph
全息干涉法 holographic interferometry
全息云纹法 holographic moire technique
全息术 Holography
全场分析法 whole-field analysis
散斑干涉法 speckle interferometry
散斑 Speckle
错位散斑干涉法 speckle-shearing interferometry, shearography
散斑图 Specklegram
白光散斑法 white-light speckle method
云纹干涉法 moire interferometry
[叠栅]云纹 moire fringe
[叠栅]云纹法 moire method
云纹图 moire pattern
离面云纹法 off-plane moire method
参考栅 reference grating
试件栅 specimen grating
分析栅 analyzer grating
面内云纹法 in-plane moire method
脆性涂层法 brittle-coating method
条带法 strip coating method
坐标变换 transformation of Coordinates
计算结构力学 computational structural mechanics
加权残量法 weighted residual method
有限差分法 finite difference method
有限[单]元法 finite element method
配点法 point collocation
里茨法 Ritz method
广义变分原理 generalized variational Principle
最小二乘法 least square method
胡[海昌]一鹫津原理 Hu-Washizu principle
赫林格-赖斯纳原理 Hellinger-Reissner Principle
修正变分原理 modified variational Principle
约束变分原理 constrained variational Principle
混合法 mixed method
杂交法 hybrid method
边界解法 boundary solution method
有限条法 finite strip method
半解析法 semi-analytical method
协调元 conforming element
非协调元 non-conforming element
混合元 mixed element
杂交元 hybrid element
边界元 boundary element
强迫边界条件 forced boundary condition
自然边界条件 natural boundary condition
离散化 Discretization
离散系统 discrete system
连续问题 continuous problem
广义位移 generalized displacement
广义载荷 generalized load
广义应变 generalized strain
广义应力 generalized stress
界面变量 interface variable
节点 node, nodal point
[单]元 Element
角节点 corner node
边节点 mid-side node
内节点 internal node
无节点变量 nodeless variable
杆元 bar element
桁架杆元 truss element
梁元 beam element
二维元 two-dimensional element
一维元 one-dimensional element
三维元 three-dimensional element
轴对称元 axisymmetric element
板元 plate element
壳元 shell element
厚板元 thick plate element
三角形元 triangular element
四边形元 quadrilateral element
四面体元 tetrahedral element
曲线元 curved element
二次元 quadratic element
线性元 linear element
三次元 cubic element
四次元 quartic element
等参[数]元 isoparametric element
超参数元 super-parametric element
亚参数元 sub-parametric element
节点数可变元 variable-number-node element
拉格朗日元 Lagrange element
拉格朗日族 Lagrange family
巧凑边点元 serendipity element
巧凑边点族 serendipity family
无限元 infinite element
单元分析 element analysis
单元特性 element characteristics
刚度矩阵 stiffness matrix
几何矩阵 geometric matrix
等效节点力 equivalent nodal force
节点位移 nodal displacement
节点载荷 nodal load
位移矢量 displacement vector
载荷矢量 load vector
质量矩阵 mass matrix
集总质量矩阵 lumped mass matrix
相容质量矩阵 consistent mass matrix
阻尼矩阵 damping matrix
瑞利阻尼 Rayleigh damping
刚度矩阵的组集 assembly of stiffness Matrices
载荷矢量的组集 consistent mass matrix
质量矩阵的组集 assembly of mass matrices
单元的组集 assembly of elements
局部坐标系 local coordinate system
局部坐标 local coordinate
面积坐标 area coordinates
体积坐标 volume coordinates
曲线坐标 curvilinear coordinates
静凝聚 static condensation
合同变换 contragradient transformation
形状函数 shape function
试探函数 trial function
检验函数 test function
权函数 weight function
样条函数 spline function
代用函数 substitute function
降阶积分 reduced integration
零能模式 zero-energy mode
P收敛 p-convergence
H收敛 h-convergence
掺混插值 blended interpolation
等参数映射 isoparametric mapping
双线性插值 bilinear interpolation
小块检验 patch test
非协调模式 incompatible mode
节点号 node number
单元号 element number
带宽 band width
带状矩阵 banded matrix
变带状矩阵 profile matrix
带宽最小化 minimization of band width
波前法 frontal method
子空间迭代法 subspace iteration method
行列式搜索法 determinant search method
逐步法 step-by-step method
纽马克 法 Newmark
威尔逊 法 Wilson
拟牛顿法 quasi-Newton method
牛顿-拉弗森法 Newton-Raphson method
增量法 incremental method
初应变 initial strain
初应力 initial stress
切线刚度矩阵 tangent stiffness matrix
割线刚度矩阵 secant stiffness matrix
模态叠加法 mode superposition method
平衡迭代 equilibrium iteration
子结构 Substructure
子结构法 substructure technique
超单元 super-element
网格生成 mesh generation
结构分析程序 structural analysis program
前处理 pre-processing
后处理 post-processing
网格细化 mesh refinement
应力光顺 stress smoothing
组合结构 composite structure
流体动力学 fluid dynamics
连续介质力学 mechanics of continuous media
介质 medium
流体质点 fluid particle
无粘性流体 nonviscous fluid, inviscid fluid
连续介质假设 continuous medium hypothesis
流体运动学 fluid kinematics
水静力学 hydrostatics
液体静力学 hydrostatics
支配方程 governing equation
伯努利方程 Bernoulli equation
伯努利定理 Bernonlli theorem
毕奥-萨伐尔定律 Biot-Savart law
欧拉方程 Euler equation
亥姆霍兹定理 Helmholtz theorem
开尔文定理 Kelvin theorem
涡片 vortex sheet
库塔-茹可夫斯基条件 Kutta-Zhoukowski condition
布拉休斯解 Blasius solution
达朗贝尔佯廖 d'Alembert paradox
雷诺数 Reynolds number
施特鲁哈尔数 Strouhal number
随体导数 material derivative
不可压缩流体 incompressible fluid
质量守恒 conservation of mass
动量守恒 conservation of momentum
能量守恒 conservation of energy
动量方程 momentum equation
能量方程 energy equation
控制体积 control volume
液体静压 hydrostatic pressure
涡量拟能 enstrophy
压差 differential pressure
流[动] flow
流线 stream line
流面 stream surface
流管 stream tube
迹线 path, path line
流场 flow field
流态 flow regime
流动参量 flow parameter
流量 flow rate, flow discharge
涡旋 vortex
涡量 vorticity
涡丝 vortex filament
涡线 vortex line
涡面 vortex surface
涡层 vortex layer
涡环 vortex ring
涡对 vortex pair
涡管 vortex tube
涡街 vortex street
卡门涡街 Karman vortex street
马蹄涡 horseshoe vortex
对流涡胞 convective cell
卷筒涡胞 roll cell
涡 eddy
涡粘性 eddy viscosity
环流 circulation
环量 circulation
速度环量 velocity circulation
偶极子 doublet, dipole
驻点 stagnation point
总压[力] total pressure
总压头 total head
静压头 static head
总焓 total enthalpy
能量输运 energy transport
速度剖面 velocity profile
库埃特流 Couette flow
单相流 single phase flow
单组份流 single-component flow
均匀流 uniform flow
非均匀流 nonuniform flow
二维流 two-dimensional flow
三维流 three-dimensional flow
准定常流 quasi-steady flow
非定常流 unsteady flow, non-steady flow
暂态流 transient flow
周期流 periodic flow
振荡流 oscillatory flow
分层流 stratified flow
无旋流 irrotational flow
有旋流 rotational flow
轴对称流 axisymmetric flow
不可压缩性 incompressibility
不可压缩流[动] incompressible flow
浮体 floating body
定倾中心 metacenter
阻力 drag, resistance
减阻 drag reduction
表面力 surface force
表面张力 surface tension
毛细[管]作用 capillarity
来流 incoming flow
自由流 free stream
自由流线 free stream line
外流 external flow
进口 entrance, inlet
出口 exit, outlet
扰动 disturbance, perturbation
分布 distribution
传播 propagation
色散 dispersion
弥散 dispersion
附加质量 added mass ,associated mass
收缩 contraction
镜象法 image method
无量纲参数 dimensionless parameter
几何相似 geometric similarity
运动相似 kinematic similarity
动力相似[性] dynamic similarity
平面流 plane flow
势 potential
势流 potential flow
速度势 velocity potential
复势 complex potential
复速度 complex velocity
流函数 stream function
源 source
汇 sink
速度[水]头 velocity head
拐角流 corner flow
空泡流 cavity flow
超空泡 supercavity
超空泡流 supercavity flow
空气动力学 aerodynamics
低速空气动力学 low-speed aerodynamics
高速空气动力学 high-speed aerodynamics
气动热力学 aerothermodynamics
亚声速流[动] subsonic flow
跨声速流[动] transonic flow
超声速流[动] supersonic flow
锥形流 conical flow
楔流 wedge flow
叶栅流 cascade flow
非平衡流[动] non-equilibrium flow
细长体 slender body
细长度 slenderness
钝头体 bluff body
钝体 blunt body
翼型 airfoil
翼弦 chord
薄翼理论 thin-airfoil theory
构型 configuration
后缘 trailing edge
迎角 angle of attack
失速 stall
脱体激波 detached shock wave
波阻 wave drag
诱导阻力 induced drag
诱导速度 induced velocity
临界雷诺数 critical Reynolds number
前缘涡 leading edge vortex
附着涡 bound vortex
约束涡 confined vortex
气动中心 aerodynamic center
气动力 aerodynamic force
气动噪声 aerodynamic noise
气动加热 aerodynamic heating
离解 dissociation
地面效应 ground effect
气体动力学 gas dynamics
稀疏波 rarefaction wave
热状态方程 thermal equation of state
喷管 Nozzle
普朗特-迈耶流 Prandtl-Meyer flow
瑞利流 Rayleigh flow
可压缩流[动] compressible flow
可压缩流体 compressible fluid
绝热流 adiabatic flow
非绝热流 diabatic flow
未扰动流 undisturbed flow
等熵流 isentropic flow
匀熵流 homoentropic flow
兰金-于戈尼奥条件 Rankine-Hugoniot condition
状态方程 equation of state
量热状态方程 caloric equation of state
完全气体 perfect gas
拉瓦尔喷管 Laval nozzle
马赫角 Mach angle
马赫锥 Mach cone
马赫线 Mach line
马赫数 Mach number
马赫波 Mach wave
当地马赫数 local Mach number
冲击波 shock wave
激波 shock wave
正激波 normal shock wave
斜激波 oblique shock wave
头波 bow wave
附体激波 attached shock wave
激波阵面 shock front
激波层 shock layer
压缩波 compression wave
反射 reflection
折射 refraction
散射 scattering
衍射 diffraction
绕射 diffraction
出口压力 exit pressure
超压[强] over pressure
反压 back pressure
爆炸 explosion
爆轰 detonation
缓燃 deflagration
水动力学 hydrodynamics
液体动力学 hydrodynamics
泰勒不稳定性 Taylor instability
盖斯特纳波 Gerstner wave
斯托克斯波 Stokes wave
瑞利数 Rayleigh number
自由面 free surface
波速 wave speed, wave velocity
波高 wave height
波列 wave train
波群 wave group
波能 wave energy
表面波 surface wave
表面张力波 capillary wave
规则波 regular wave
不规则波 irregular wave
浅水波 shallow water wave
深水波 deep water wave
重力波 gravity wave
椭圆余弦波 cnoidal wave
潮波 tidal wave
涌波 surge wave
破碎波 breaking wave
船波 ship wave
非线性波 nonlinear wave
孤立子 soliton
水动[力]噪声 hydrodynamic noise
水击 water hammer
空化 cavitation
空化数 cavitation number
空蚀 cavitation damage
超空化流 supercavitating flow
水翼 hydrofoil
水力学 hydraulics
洪水波 flood wave
涟漪 ripple
消能 energy dissipation
海洋水动力学 marine hydrodynamics
谢齐公式 Chezy formula
欧拉数 Euler number
弗劳德数 Froude number
水力半径 hydraulic radius
水力坡度 hvdraulic slope
高度水头 elevating head
水头损失 head loss
水位 water level
水跃 hydraulic jump
含水层 aquifer
排水 drainage
排放量 discharge
壅水曲线 back water curve
压[强水]头 pressure head
过水断面 flow cross-section
明槽流 open channel flow
孔流 orifice flow
无压流 free surface flow
有压流 pressure flow
缓流 subcritical flow
急流 supercritical flow
渐变流 gradually varied flow
急变流 rapidly varied flow
临界流 critical flow
异重流 density current, gravity flow
堰流 weir flow
掺气流 aerated flow
含沙流 sediment-laden stream
降水曲线 dropdown curve
沉积物 sediment, deposit
沉[降堆]积 sedimentation, deposition
沉降速度 settling velocity
流动稳定性 flow stability
不稳定性 instability
奥尔-索末菲方程 Orr-Sommerfeld equation
涡量方程 vorticity equation
泊肃叶流 Poiseuille flow
奥辛流 Oseen flow
剪切流 shear flow
粘性流[动] viscous flow
层流 laminar flow
分离流 separated flow
二次流 secondary flow
近场流 near field flow
远场流 far field flow
滞止流 stagnation flow
尾流 wake [flow]
回流 back flow
反流 reverse flow
射流 jet
自由射流 free jet
管流 pipe flow, tube flow
内流 internal flow
拟序结构 coherent structure
猝发过程 bursting process
表观粘度 apparent viscosity
运动粘性 kinematic viscosity
动力粘性 dynamic viscosity
泊 poise
厘泊 centipoise
厘沱 centistoke
剪切层 shear layer
次层 sublayer
流动分离 flow separation
层流分离 laminar separation
湍流分离 turbulent separation
分离点 separation point
附着点 attachment point
再附 reattachment
再层流化 relaminarization
起动涡 starting vortex
驻涡 standing vortex
涡旋破碎 vortex breakdown
涡旋脱落 vortex shedding
压[力]降 pressure drop
压差阻力 pressure drag
压力能 pressure energy
型阻 profile drag
滑移速度 slip velocity
无滑移条件 non-slip condition
壁剪应力 skin friction, frictional drag
壁剪切速度 friction velocity
磨擦损失 friction loss
磨擦因子 friction factor
耗散 dissipation
滞后 lag
相似性解 similar solution
局域相似 local similarity
气体润滑 gas lubrication
液体动力润滑 hydrodynamic lubrication
浆体 slurry
泰勒数 Taylor number
纳维-斯托克斯方程 Navier-Stokes equation
牛顿流体 Newtonian fluid
边界层理论 boundary later theory
边界层方程 boundary layer equation
边界层 boundary layer
附面层 boundary layer
层流边界层 laminar boundary layer
湍流边界层 turbulent boundary layer
温度边界层 thermal boundary layer
边界层转捩 boundary layer transition
边界层分离 boundary layer separation
边界层厚度 boundary layer thickness
位移厚度 displacement thickness
动量厚度 momentum thickness
能量厚度 energy thickness
焓厚度 enthalpy thickness
注入 injection
吸出 suction
泰勒涡 Taylor vortex
速度亏损律 velocity defect law
形状因子 shape factor
测速法 anemometry
粘度测定法 visco[si] metry
流动显示 flow visualization
油烟显示 oil smoke visualization
孔板流量计 orifice meter
频率响应 frequency response
油膜显示 oil film visualization
阴影法 shadow method
纹影法 schlieren method
烟丝法 smoke wire method
丝线法 tuft method
氢泡法 nydrogen bubble method
相似理论 similarity theory
相似律 similarity law
部分相似 partial similarity
定理 pi theorem, Buckingham theorem
静[态]校准 static calibration
动态校准 dynamic calibration
风洞 wind tunnel
激波管 shock tube
激波管风洞 shock tube wind tunnel
水洞 water tunnel
拖曳水池 towing tank
旋臂水池 rotating arm basin
扩散段 diffuser
测压孔 pressure tap
皮托管 pitot tube
普雷斯顿管 preston tube
斯坦顿管 Stanton tube
文丘里管 Venturi tube
U形管 U-tube
压强计 manometer
微压计 micromanometer
多管压强计 multiple manometer
静压管 static [pressure]tube
流速计 anemometer
风速管 Pitot- static tube
激光多普勒测速计 laser Doppler anemometer, laser Doppler velocimeter
热线流速计 hot-wire anemometer
热膜流速计 hot- film anemometer
流量计 flow meter
粘度计 visco[si] meter
涡量计 vorticity meter
传感器 transducer, sensor
压强传感器 pressure transducer
热敏电阻 thermistor
示踪物 tracer
时间线 time line
脉线 streak line
尺度效应 scale effect
壁效应 wall effect
堵塞 blockage
堵寒效应 blockage effect
动态响应 dynamic response
响应频率 response frequency
底压 base pressure
菲克定律 Fick law
巴塞特力 Basset force
埃克特数 Eckert number
格拉斯霍夫数 Grashof number
努塞特数 Nusselt number
普朗特数 prandtl number
雷诺比拟 Reynolds analogy
施密特数 schmidt number
斯坦顿数 Stanton number
对流 convection
自由对流 natural convection, free convec-tion
强迫对流 forced convection
热对流 heat convection
质量传递 mass transfer
传质系数 mass transfer coefficient
热量传递 heat transfer
传热系数 heat transfer coefficient
对流传热 convective heat transfer
辐射传热 radiative heat transfer
动量交换 momentum transfer
能量传递 energy transfer
传导 conduction
热传导 conductive heat transfer
热交换 heat exchange
临界热通量 critical heat flux
浓度 concentration
扩散 diffusion
扩散性 diffusivity
扩散率 diffusivity
扩散速度 diffusion velocity
分子扩散 molecular diffusion
沸腾 boiling
蒸发 evaporation
气化 gasification
凝结 condensation
成核 nucleation
计算流体力学 computational fluid mechanics
多重尺度问题 multiple scale problem
伯格斯方程 Burgers equation
对流扩散方程 convection diffusion equation
KDU方程 KDV equation
修正微分方程 modified differential equation
拉克斯等价定理 Lax equivalence theorem
数值模拟 numerical simulation
大涡模拟 large eddy simulation
数值粘性 numerical viscosity
非线性不稳定性 nonlinear instability
希尔特稳定性分析 Hirt stability analysis
相容条件 consistency condition
CFL条件 Courant- Friedrichs- Lewy condition ,CFL condition
狄里克雷边界条件 Dirichlet boundary condition
熵条件 entropy condition
远场边界条件 far field boundary condition
流入边界条件 inflow boundary condition
无反射边界条件  nonreflecting boundary condition
数值边界条件 numerical boundary condition
流出边界条件 outflow boundary condition
冯.诺伊曼条件 von Neumann condition
近似因子分解法 approximate factorization method
人工压缩 artificial compression
人工粘性 artificial viscosity
边界元法 boundary element method
配置方法 collocation method
能量法 energy method
有限体积法 finite volume method
流体网格法 fluid in cell method, FLIC method
通量校正传输法 flux-corrected transport method
通量矢量分解法 flux vector splitting method
伽辽金法 Galerkin method
积分方法 integral method
标记网格法 marker and cell method, MAC method
特征线法 method of characteristics
直线法 method of lines
矩量法 moment method
多重网格法 multi- grid method
板块法 panel method
质点网格法 particle in cell method, PIC method
质点法 particle method
预估校正法 predictor-corrector method
投影法 projection method
准谱法 pseudo-spectral method
随机选取法 random choice method
激波捕捉法 shock-capturing method
激波拟合法 shock-fitting method
谱方法 spectral method
稀疏矩阵分解法 split coefficient matrix method
不定常法 time-dependent method
时间分步法 time splitting method
变分法 variational method
涡方法 vortex method
隐格式 implicit scheme
显格式 explicit scheme
交替方向隐格式 alternating direction implicit scheme, ADI scheme
反扩散差分格式 anti-diffusion difference scheme
紧差分格式 compact difference scheme
守恒差分格式 conservation difference scheme
克兰克-尼科尔森格式 Crank-Nicolson scheme
杜福特-弗兰克尔格式 Dufort-Frankel scheme
指数格式 exponential scheme
戈本诺夫格式 Godunov scheme
高分辨率格式 high resolution scheme
拉克斯-温德罗夫格式 Lax-Wendroff scheme
蛙跳格式 leap-frog scheme
单调差分格式 monotone difference scheme
保单调差分格式 monotonicity preserving difference scheme
穆曼-科尔格式 Murman-Cole scheme
半隐格式 semi-implicit scheme
斜迎风格式 skew-upstream scheme
全变差下降格式 total variation decreasing scheme TVD scheme
迎风格式 upstream scheme , upwind scheme
计算区域 computational domain
物理区域 physical domain
影响域 domain of influence
依赖域 domain of dependence
区域分解 domain decomposition
维数分解 dimensional split
物理解 physical solution
弱解 weak solution
黎曼解算子 Riemann solver
守恒型 conservation form
弱守恒型 weak conservation form
强守恒型 strong conservation form
散度型 divergence form
贴体曲线坐标 body- fitted curvilinear coordi-nates
[自]适应网格 [self-] adaptive mesh
适应网格生成 adaptive grid generation
自动网格生成 automatic grid generation
数值网格生成 numerical grid generation
交错网格 staggered mesh
网格雷诺数 cell Reynolds number
数植扩散 numerical diffusion
数值耗散 numerical dissipation
数值色散 numerical dispersion
数值通量 numerical flux
放大因子 amplification factor
放大矩阵 amplification matrix
阻尼误差 damping error
离散涡 discrete vortex
熵通量 entropy flux
熵函数 entropy function
分步法 fractional step method
广义连续统力学 generalized continuum mechanics
简单物质 simple material
纯力学物质 purely mechanical material
微分型物质 material of differential type
积分型物质 material of integral type
混合物组份 constituents of a mixture
非协调理论 incompatibility theory
微极理论 micropolar theory
决定性原理 principle of determinism
等存在原理 principle of equipresence
局部作用原理 principle of objectivity
客观性原理 principle of objectivity
电磁连续统理论 theory of electromagnetic continuum
内时理论 endochronic theory
非局部理论 nonlocal theory
混合物理论 theory of mixtures
里夫林-矣里克森张量 Rivlin-Ericksen tensor
声张量 acoustic tensor
半向同性张量 hemitropic tensor
各向同性张量 isotropic tensor
应变张量 strain tensor
伸缩张量 stretch tensor
连续旋错 continuous dislination
连续位错 continuous dislocation
动量矩平衡 angular momentum balance
余本构关系 complementary constitutive relations
共旋导数 co-rotational derivative, Jaumann derivative
非完整分量 anholonomic component
爬升效应 climbing effect
协调条件 compatibility condition
错综度 complexity
当时构形 current configuration
能量平衡 energy balance
变形梯度 deformation gradient
有限弹性 finite elasticity
熵增 entropy production
标架无差异性 frame indifference
弹性势 elastic potential
熵不等式 entropy inequality
极分解 polar decomposition
低弹性 hypoelasticity
参考构形 reference configuration
响应泛函 response functional
动量平衡 momentum balance
奇异面 singular surface
贮能函数 stored-energy function
内部约束 internal constraint
物理分量 physical components
本原元 primitive element
普适变形 universal deformation
速度梯度 velocity gradient
测粘流动 viscometric flow
当地导数 local derivative
岩石力学 rock mechanics
原始岩体应力 virgin rock stress
构造应力 tectonic stress
三轴压缩试验 three-axial compression test
三轴拉伸试验 three-axial tensile test
三轴试验 triaxial test
岩层静态应力 lithostatic stress
吕荣 lugeon
地压强 geostatic pressure
水力劈裂 hydraulic fracture
咬合[作用] interlocking
内禀抗剪强度 intrinsic shear strength
循环抗剪强度 cyclic shear strength
残余抗剪强度 residual shear strength
土力学 soil mechanics
孔隙比 void ratio
内磨擦角 angle of internal friction
休止角 angle of repose
孔隙率 porosity
围压 ambient pressure
[抗]剪切角 angle of shear resistance
渗流力 seepage force
表观粘聚力 apparent cohesion
粘聚力 cohesion
稠度 consistency
固结 consolidation
固结仪 consolidometer
浮升力 uplift
扩容 dilatancy
絮凝[作用] flocculation
土动力学 soil dynamics
应力解除 stress relief
次时间效应 secondary time effect
贯入阻力 penetration resistance
沙土液化 liquefaction of sand
泥流 mud flow
多相流 multiphase flow
马格努斯效应 Magnus effect
韦伯数 Weber number
环状流 annular flow
泡状流 bubble flow
层状流 stratified flow
平衡流 equilibrium flow
二组份流 two-component flow
冻结流 frozen flow
均质流 homogeneous flow
二相流 two-phase flow
气-液流 gas-liquid flow
气-固流 gas-solid flow
液-气流 liquid-gas flow
液-固流 liquid-solid flow
液体-蒸气流 liquid-vapor flow
浓相 dense phase
稀相 dilute phase
连续相 continuous phase
离散相 dispersed phase
悬浮 suspension
气力输运 pneumatic transport
气泡形成 bubble formation
体密度 bulk density
壅塞 choking
微滴 droplet
挟带 entrainment
流型 flow pattern
流[态]化 fluidization
界面 interface
跃动速度 saltation velocity
非牛顿流体力学 non-Newtonian fluid mechanics
非牛顿流体 non-Newtonian fluid
幂律流体 power law fluid
拟塑性流体 pseudoplastic fluid
触稠流体 rheopectic fluid
触变流体 thixotropic fluid
粘弹性流体 viscoelastic fluid
流变测量学 rheometry
震凝性 rheopexy
体[积]粘性 bulk viscosity
魏森贝格效应 Weissenberg effect
流变仪 rheometer
稀薄气体动力学 rarefied gas dynamics
物理化学流体力学 physico-chemical hydrodynamics
空气热化学 aerothermochemistry
绝对压强 absolute pressure
绝对反应速率 absolute reaction rate
绝对温度 absolute temperature
活化分子 activated molecule
活化能 activation energy
绝热压缩 adiabatic compression
绝热膨胀 adiabatic expansion
绝热火焰温度 adiabatic flame temperature
电弧风洞 arc tunnel
原子热 atomic heat
雾化 atomization
自燃 auto-ignition
自动氧化 auto-oxidation
可用能量 available energy
缓冲作用 buffer action
松密度 bulk density
燃烧率 burning rate
燃烧速度 burning velocity
接触面 contact surface
烧蚀 ablation
连续过程 continuous process
碰撞截面 collision cross section
通用气体常数 conventional gas constant
燃烧不稳定性 combustion instability
稀释度 dilution
完全离解 complete dissociation
火焰传播 flame propagation
组份 constituent
碰撞反应速率 collision reaction rate
燃烧理论 combustion theory
浓度梯度 concentration gradient
阴极腐蚀 cathodic corrosion
火焰速度 flame speed
火焰驻定 flame stabilization
火焰结构 flame structure
着火 ignition
湍流火焰 turbulent flame
层流火焰 laminar flame
燃烧带 burning zone
渗流 flow in porous media, seepage
达西定律 Darcy law
赫尔-肖流 Hele-Shaw flow
毛[细]管流 capillary flow
过滤 filtration
爪进 fingering
不互溶驱替 immiscible displacement
不互溶流体 immiscible fluid
互溶驱替 miscible displacement
互溶流体 miscible fluid
迁移率 mobility
流度比 mobility ratio
渗透率 permeability
孔隙度 porosity
多孔介质 porous medium
比面 specific surface
迂曲度 tortuosity
空隙 void
空隙分数 void fraction
注水 water flooding
可湿性 wettability
地球物理流体动力学 geophysical fluid dynamics
物理海洋学 physical oceanography
大气环流 atmospheric circulation
海洋环流 ocean circulation
海洋流 ocean current
旋转流 rotating flow
平流 advection
埃克曼流 Ekman flow
埃克曼边界层 Ekman boundary layer
大气边界层 atmospheric boundary layer
大气-海洋相互作用 atmosphere-ocean interaction
埃克曼数 Ekman number
罗斯贝数 Rossby unmber
罗斯贝波 Rossby wave
斜压性 baroclinicity
正压性 barotropy
内磨擦 internal friction
海洋波 ocean wave
盐度 salinity
环境流体力学 environmental fluid mechanics
斯托克斯流 Stokes flow
羽流 plume
理查森数 Richardson number
污染源 pollutant source
污染物扩散 pollutant diffusion
噪声 noise
噪声级 noise level
噪声污染 noise pollution
排放物 effulent
工业流体力学 industrical fluid mechanics
流控技术 fluidics
轴向流 axial flow
并向流 co-current flow
对向流 counter current flow
横向流 cross flow
螺旋流 spiral flow
旋拧流 swirling flow
滞后流 after flow
混合层 mixing layer
抖振 buffeting
风压 wind pressure
附壁效应 wall attachment effect, Coanda effect
简约频率 reduced frequency
爆炸力学 mechanics of explosion
终点弹道学 terminal ballistics
动态超高压技术 dynamic ultrahigh pressure technique
流体弹塑性体 hydro-elastoplastic medium
热塑不稳定性 thermoplastic instability
空中爆炸 explosion in air
地下爆炸 underground explosion
水下爆炸 underwater explosion
电爆炸 discharge-induced explosion
激光爆炸 laser-induced explosion
核爆炸 nuclear explosion
点爆炸 point-source explosion
殉爆 sympathatic detonation
强爆炸 intense explosion
粒子束爆炸 explosion by beam radiation
聚爆 implosion
起爆 initiation of explosion
爆破 blasting
霍普金森杆 Hopkinson bar
电炮 electric gun
电磁炮 electromagnetic gun
爆炸洞 explosion chamber
轻气炮 light gas gun
马赫反射 Mach reflection
基浪 base surge
成坑 cratering
能量沉积 energy deposition
爆心 explosion center
爆炸当量 explosion equivalent
火球 fire ball
爆高 height of burst
蘑菇云 mushroom
侵彻 penetration
规则反射 regular reflection
崩落 spallation
应变率史 strain rate history
流变学 rheology
聚合物减阻 drag reduction by polymers
挤出[物]胀大 extrusion swell, die swell
无管虹吸 tubeless siphon
剪胀效应 dilatancy effect
孔压[误差]效应 hole-pressure[error]effect
剪切致稠 shear thickening
剪切致稀 shear thinning
触变性 thixotropy
反触变性 anti-thixotropy
超塑性 superplasticity
粘弹塑性材料 viscoelasto-plastic material
滞弹性材料 anelastic material
本构关系 constitutive relation
麦克斯韦模型 Maxwell model
沃伊特-开尔文模型 Voigt-Kelvin model
宾厄姆模型 Bingham model
奥伊洛特模型 Oldroyd model
幂律模型 power law model
应力松驰 stress relaxation
应变史 strain history
应力史 stress history
记忆函数 memory function
衰退记忆 fading memory
应力增长 stress growing
粘度函数 voscosity function
相对粘度 relative viscosity
复态粘度 complex viscosity
拉伸粘度 elongational viscosity
拉伸流动 elongational flow
第一法向应力差 first normal-stress difference
第二法向应力差 second normal-stress difference
德博拉数 Deborah number
魏森贝格数 Weissenberg number
动态模量 dynamic modulus
振荡剪切流 oscillatory shear flow
宇宙气体动力学 cosmic gas dynamics
等离[子]体动力学 plasma dynamics
电离气体 ionized gas
行星边界层 planetary boundary layer
阿尔文波 Alfven wave
泊肃叶-哈特曼流] Poiseuille-Hartman flow
哈特曼数 Hartman number
生物流变学 biorheology
生物流体 biofluid
生物屈服点 bioyield point
生物屈服应力 bioyield stress
电气体力学 electro-gas dynamics
铁流体力学 ferro-hydrodynamics
血液流变学 hemorheology, blood rheology
血液动力学 hemodynamics
磁流体力学 magneto fluid mechanics
磁流体动力学 magnetohydrodynamics, MHD
磁流体动力波 magnetohydrodynamic wave
磁流体流 magnetohydrodynamic flow
磁流体动力稳定性 magnetohydrodynamic stability
生物力学 biomechanics
生物流体力学 biological fluid mechanics
生物固体力学 biological solid mechanics
宾厄姆塑性流 Bingham plastic flow
开尔文体 Kelvin body
沃伊特体 Voigt body
可贴变形 applicable deformation
可贴曲面 applicable surface
边界润滑 boundary lubrication
液膜润滑 fluid film lubrication
向心收缩功 concentric work
离心收缩功 eccentric work
关节反作用力 joint reaction force
微循环力学 microcyclic mechanics
微纤维 microfibril
渗透性 permeability
生理横截面积 physiological cross-sectional area
农业生物力学 agrobiomechanics
纤维度 fibrousness
硬皮度 rustiness
胶粘度 gumminess
粘稠度 stickiness
嫩度 tenderness
渗透流 osmotic flow
易位流 translocation flow
蒸腾流 transpirational flow
过滤阻力 filtration resistance
压扁 wafering
风雪流 snow-driving wind
停滞堆积 accretion
遇阻堆积 encroachment
沙漠地面 desert floor
流沙固定 fixation of shifting sand
流动阈值 fluid threshold
生命不息,奋斗不止!
离线kkygxw
只看该作者 23楼 发表于: 2009-06-15
有一本书专门是岩土术语的中英文对译的,哪位有上传一下吗?
云桂人
