  • 73333阅读
  • 576回复
[变形监测]土木工程监测技术 同济大学 Word版本 [复制链接]
离线41642245
只看该作者 264楼 发表于: 2009-06-03
Abstract: The purpose of this chapter is to present criteria and example problems of the current state of practice of =A,B'n\R
seismic design of wood and reinforced masonry buildings. It is assumed that the reader is familiar with the >U* p[FGW
provisions of either the Uniform Building Code (UBC), Building Officials and Code Administrators ShC$ue?Q
(BOCA), or Southern Building Code Congress International (SBCCI), or international code council, ep"{{S5g
international building code (IBC). For consistency of presentation the primary reference, including notations 8'@5X-nD
and definitions, will be to the UBC 97. Included within the presentation on diaphragms are criteria and Szt2 "AR
example problems for both rigid and flexible diaphragms. Also included is the UBC 97 criteria for the `,SL\\%u
analytical definition of rigid versus flexible diaphragms. Wood shear walls and the distribution of lateral iwM x Tty
forces to a series of wood shear walls is presented using Allowable Stress Design (ASD). Masonry slender tgG 8pL
walls (out-of-plane loads) and masonry shear walls (in-plane loads) are presented using Load and Resistance gk| % 4.
Factor Design (LRFD).
勇往直前!GO  GO
离线flykid
只看该作者 265楼 发表于: 2009-06-09
谢谢分享
离线king888520
只看该作者 266楼 发表于: 2009-07-02
离线dwhuang
只看该作者 267楼 发表于: 2009-07-26
谢谢您无私的共享!
离线xingyuan2008
只看该作者 268楼 发表于: 2009-07-26
谢谢分享,顶
离线gigi2599
只看该作者 269楼 发表于: 2009-07-29
一定得好好看看
离线lyhn
只看该作者 270楼 发表于: 2009-07-29
感谢楼主的分享!!!!!!!!!
离线ickingkuoo
只看该作者 271楼 发表于: 2009-07-29
下来看看
离线jamescao
只看该作者 272楼 发表于: 2009-07-29
离线wangshimin
只看该作者 273楼 发表于: 2009-08-01
楼主很神奇啊,连夏老师和杨老师的资料都弄到了。佩服。
离线monkeylzx
只看该作者 274楼 发表于: 2009-08-03
很好的参考学习资料,学习过程中,谢谢
离线bigbreeze
只看该作者 275楼 发表于: 2009-08-03
太好了,正想找这方面的资料
