  • 19947阅读
  • 65回复
[软件]同济启明星免费软件-工程计算器软件 Etools [复制链接]
离线菜菜
只看该作者 36楼 发表于: 2011-02-27
搞错了 是下面那个TOOL 怪不得不能安装...
离线czb203
只看该作者 37楼 发表于: 2011-02-27
不知好不好用啊 下载来看看
只看该作者 38楼 发表于: 2011-06-10
好像不能安装啊! 楼主如何安装呀
岩土人肤色随季节而变化。
离线geo张健
只看该作者 39楼 发表于: 2011-06-27
谢谢啊11111111
离线geo张健
只看该作者 40楼 发表于: 2011-06-27
谢谢啊11111111111
离线daustor
只看该作者 41楼 发表于: 2011-07-04
楼主强大啊
http://img2.pconline.com.cn/pconline/0812/01/1495754_1.jpg
离线wang489752
只看该作者 42楼 发表于: 2011-07-08
各位同仁能告诉我,这个计算器用处大吗?
离线欲海猛男
只看该作者 43楼 发表于: 2011-07-09
Engineering calculator Etools software ETools v2.0 engineering calculator provides geotechnical engineering and structural engineering design in great quantities in the calculation method of commonly used, to avoid a lot look-up table calculation and many repeatability can greatly reduce labor, labor, and design staff working intensity. A software function. The software for building structure engineering and bridge engineering, can provide the continuous beam calculation and the component crack checking and calculating the deflection component, the ultimate bearing capacity for inclined section cutting checking and calculating the bearing capacity, the local press press bearing capacity calculation and various kinds of reinforced concrete members reinforced with calculation; To bridge engineering and port engineering special offer level by calculation by pile; For road engineering can also provide special foundation treatment design calculation, etc.; For geotechnical engineering can also provide special foundation bearing capacity calculation, weak lie layer under the checking and localized parameters are calculated and soil name discrimination, CFG pile design calculation and pile caps calculation, and the design of natural foundation and composite foundation settlement calculation, etc. The software "choose Windows exercise
离线欲海猛男
只看该作者 44楼 发表于: 2011-07-09
该软件“选取Windows操作系统作为软件的开发平台,数据录入采用表格和对话框,并有图形显示和出错提示,操作简单方便。”各项功能不依赖于具体当地具体条件,因而极具在全国范围内推广的价值。 该软件可避免大量的手工计算工作,加上其考虑了实际使用过程中的工程衔接性,因而能够大大提高广大工程技术人员的计算和设计效率。
只看该作者 45楼 发表于: 2011-08-04
计算器不错,我弄几个算例试一试
离线飞来一峰
只看该作者 46楼 发表于: 2011-11-07
是下面的tool能用
随他起云落日,还我立地顶天!
离线huchunmei
只看该作者 47楼 发表于: 2011-11-08
文件损坏,无法解压安装
