  • 1191阅读
  • 0回复
求助,abaqus模拟桩土接触承载试验,这问题咋整 .. [复制链接]
离线liu19870906
只看楼主 倒序阅读 使用道具 楼主  发表于: 2012-03-13
经过调试错误变成了3个,求高手帮助
Error in job Job-1: A PROPERTY OPTION MAY ONLY BE GIVEN ONCE FOR A MATERIAL
Error in job Job-1: 1101 elements have missing property definitions. The elements have been identified in element set ErrElemMissingSection.
Error in job Job-1: SECTION DEFINITIONS ARE MISSING OR INCORRECT FOR THE ELEMENTS INDICATED ABOVE. FURTHER PROCESSING OF THE INPUT FILE IS NOT POSSIBLE UNTIL THIS INPUT ERROR IS FIXED.
就是这个问题!在job这步过不去了!
