  • 1014阅读
  • 0回复
abaqus建模出现错误,求解决 [复制链接]
离线911110lfl
只看楼主 倒序阅读 使用道具 楼主  发表于: 2016-06-21
Error in job Job-4: AN INITIAL CONDITION HAS BEEN SPECIFIED ON NODE SET ASSEMBLY_SOIL. THIS NODE SET IS NOT ACTIVE IN THE MODEL.
Error in job Job-4: Permeability is specified on 704 elements but the initial void ratio is not defined. Use *initial conditions to the value. The elements are identified in element set ErrElemPermNoInitVoidRatio.
