Run LocationTemplate Behavior [ RunTime:0.000164s ]
[ view_template ] --END-- [ RunTime:0.000179s ]
[ view_parse ] --START--
Run ParseTemplate Behavior [ RunTime:0.002992s ]
[ view_parse ] --END-- [ RunTime:0.003011s ]
[ view_filter ] --START--
Run ContentReplace Behavior [ RunTime:0.000118s ]
Run TokenBuild Behavior [ RunTime:0.000105s ]
Run WriteHtmlCache Behavior [ RunTime:0.000073s ]
Run ShowRuntime Behavior [ RunTime:0.000119s ]
[ view_filter ] --END-- [ RunTime:0.000444s ]
[ view_end ] --START--
[2048] Declaration of RedisAction::get() should be compatible with Action::get($name = '') /var/www/yantu/home/Lib/Action/RedisAction.class.php 第 117 行.
[8192] preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead /var/www/yantu/ThinkPHP/Lib/Template/ThinkTemplate.class.php 第 270 行.
[8192] preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead /var/www/yantu/ThinkPHP/Lib/Template/ThinkTemplate.class.php 第 165 行.
[8192] preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead /var/www/yantu/ThinkPHP/Lib/Template/ThinkTemplate.class.php 第 401 行.
[8192] preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead /var/www/yantu/ThinkPHP/Lib/Template/ThinkTemplate.class.php 第 396 行.
[8192] preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead /var/www/yantu/ThinkPHP/Lib/Template/ThinkTemplate.class.php 第 194 行.
[8192] preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead /var/www/yantu/ThinkPHP/Lib/Template/ThinkTemplate.class.php 第 134 行.
