  • 36764阅读
  • 26回复
[公路]边坡绿化工程(挂网、客土、喷播、生态袋、植生袋综合) [复制链接]
离线ayf250
只看该作者 12楼 发表于: 2011-01-11
学习了 谢谢楼主
离线ttplay
只看该作者 13楼 发表于: 2011-02-25
不错的图片,学习学习
离线bluesilence
只看该作者 14楼 发表于: 2011-03-03
生态袋太陡了,是否有稳定的锚固?如果没有的话,估计要出问题的!
离线geojg
只看该作者 15楼 发表于: 2011-03-19
谢谢楼主的分享......................
离线fanmingchan
只看该作者 16楼 发表于: 2011-04-27
Public Sub 工作表保护密码破解()
Const DBLSPACE As String = vbNewLine & vbNewLine
Const AUTHORS As String = DBLSPACE & vbNewLine & _
"作者:XXXXXXX"
Const HEADER As String = "工作表保护密码破解"
Const VERSION As String = DBLSPACE & "版本 Version 1.1.1"
Const REPBACK As String = DBLSPACE & ""
Const ZHENGLI As String = DBLSPACE & "                   XXXXXXX"
Const ALLCLEAR As String = DBLSPACE & "该工作簿中的工作表密码保护已全部解除!!" & DBLSPACE & "请记得另保存" _
& DBLSPACE & "注意:不要用在不当地方,要尊重他人的劳动成果!"
Const MSGNOPWORDS1 As String = "该文件工作表中没有加密"
Const MSGNOPWORDS2 As String = "该文件工作表中没有加密2"
Const MSGTAKETIME As String = "解密需花费一定时间,请耐心等候!" & DBLSPACE & "按确定开始破解!"
Const MSGPWORDFOUND1 As String = "密码重新组合为:" & DBLSPACE & "$$" & DBLSPACE & _
"如果该文件工作表有不同密码,将搜索下一组密码并修改清除"
Const MSGPWORDFOUND2 As String = "密码重新组合为:" & DBLSPACE & "$$" & DBLSPACE & _
"如果该文件工作表有不同密码,将搜索下一组密码并解除"
Const MSGONLYONE As String = "确保为唯一的?"
Dim w1 As Worksheet, w2 As Worksheet
Dim i As Integer, j As Integer, k As Integer, l As Integer
Dim m As Integer, n As Integer, i1 As Integer, i2 As Integer
Dim i3 As Integer, i4 As Integer, i5 As Integer, i6 As Integer
Dim PWord1 As String
Dim ShTag As Boolean, WinTag As Boolean
Application.ScreenUpdating = False
With ActiveWorkbook
WinTag = .ProtectStructure Or .ProtectWindows
End With
ShTag = False
For Each w1 In Worksheets
ShTag = ShTag Or w1.ProtectContents
Next w1
If Not ShTag And Not WinTag Then
MsgBox MSGNOPWORDS1, vbInformation, HEADER
Exit Sub
End If
MsgBox MSGTAKETIME, vbInformation, HEADER
If Not WinTag Then
Else
On Error Resume Next
Do 'dummy do loop
For i = 65 To 66: For j = 65 To 66: For k = 65 To 66
For l = 65 To 66: For m = 65 To 66: For i1 = 65 To 66
For i2 = 65 To 66: For i3 = 65 To 66: For i4 = 65 To 66
For i5 = 65 To 66: For i6 = 65 To 66: For n = 32 To 126
With ActiveWorkbook
.Unprotect Chr(i) & Chr(j) & Chr(k) & _
Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & _
Chr(i3) & Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
If .ProtectStructure = False And _
.ProtectWindows = False Then
PWord1 = Chr(i) & Chr(j) & Chr(k) & Chr(l) & _
Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
MsgBox Application.Substitute(MSGPWORDFOUND1, _
"$$", PWord1), vbInformation, HEADER
Exit Do 'Bypass all for...nexts
End If
End With
Next: Next: Next: Next: Next: Next
Loop Until True
On Error GoTo 0
End If
If WinTag And Not ShTag Then
MsgBox MSGONLYONE, vbInformation, HEADER
Exit Sub
End If
'Attempt clearance with PWord1
w1.Unprotect PWord1
Next w1
On Error GoTo 0
ShTag = False
'Checks for all clear ShTag triggered to 1 if not.
Next w1
If ShTag Then
With w1
If .ProtectContents Then
Do 'Dummy do loop
Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
If Not .ProtectContents Then
MsgBox Application.Substitute(MSGPWORDFOUND2, _
'leverage finding Pword by trying on other sheets
For Each w2 In Worksheets
w2.Unprotect PWord1
Next w2
End If
Loop Until True
On Error GoTo 0
End If
End With
Next w1
End If
MsgBox ALLCLEAR & AUTHORS & VERSION & REPBACK & ZHENGLI, vbInformation, HEADER
End Sub
离线maozhenggang
只看该作者 17楼 发表于: 2011-05-04
同行!!学习!!!
离线spaceboy
只看该作者 18楼 发表于: 2012-05-18
谢谢斑竹建立这样可供学习的网站
离线xiaokan01
只看该作者 19楼 发表于: 2013-01-09
刚好在弄这方面东西, thank you
惟 楚 有 才   于 斯 为 盛
离线fuxiaoxiao
只看该作者 20楼 发表于: 2014-10-24
刚加入这一行,学习。。
离线dzb666666
只看该作者 21楼 发表于: 2017-04-13
非常感谢楼主的无私,下来看看!!岩土论坛真是个好地方!
离线solargang
只看该作者 22楼 发表于: 2018-08-10
美化环境,值得学习
离线ljz0702
只看该作者 23楼 发表于: 2018-09-24
挂双网+植生袋?
