在山区地方修建一个高14m的土石坝,土石坝拦住的是14m高的稀泥巴。我想得到的是坝体是否安全,坝体及地基土的整体应力和应变。坝体坡度是按照1:1.75的比例 /&Vgo~.J
,`nl";Zc
我建的模型是: O,A}p:Pgs
New 7J$5dFV2
;title ,Z1W3;O
;Analysis of embankment dam |&xjuBC
;set logfile Analysisofembankmentdam |=U(8t
;set log on "RG #e+
;1 几何建模================================================= /*2sg>e'QF
Generate zone brick & @[] A&)B
p0=(0,0,0) & R$xk cg2(
p1=(28,0,0) & nbM7 >tnsk
p2=(0,1,0) & f8X/kz
p3=(0,0,14) & YTo^Q&
P4=(28,1,0) & 5q>u]n9]
P5=(0,1,14) & t
9Dr%#
P6=(3,0,14) & JJn+H&[B
P7=(3,1,14) & AG==A&d>$
size 14 1 7 ratio 1 1 1 ;矩形 z,#3YC{'
plot gp surface 9e xHR&>{
gen zone brick & ;th]/ G
p0 0 0 -10 p1 add 50 0 0 p2 add 0 1 0 p3 add 0 0 10 & 8OW504AD
size 25 1 10 ratio 1 1 1 ;矩形 9b}AZ]$
attach face range z -0.1 0.1 ;联接网格 8G0DuMI5
;镜像网格 A[.5Bi
Generate zone reflect normal (1,0,0) origin=(0,0,0) T.j&UEsd
group soildam range z 0 14 TPeBb8v8D
group groundsill1 range z -2 0 I-`qo7dQ_S
group groundsill2 range z -6 -2 O&c~7tM%
group groundsill3 range z -10 -6 avI
; 2 指定地基土为Mohr Coulomb 模型============================================= Y
=BXV7\
model null range z 0 15 ;对坝体设置空单元 B%e#u.'6
model moh range z -11 0 ;对地基土网格进行赋值 7h3JH
pro coh 1e10 fric 30 di 2 bulk 6.7e6 she 3.1e6 ten 1e10 range group groundsill1 fpK`
ini density 1800 range group groundsill1 eS{ xma
pro coh 1e10 fric 10 di 0 bulk 1.11e7 she 3.70e6 ten 1e10 range group groundsill2 3ZKaqwK
ini density 1700 range group groundsill2 T1}9^3T?{
pro coh 1e10 fric 30 di 3 bulk 3.33e8 she 1.11e8 ten 1e10 range group groundsill3 FII>6c
ini density 1700 range group groundsill3 1>1ii
; 3 边界条件================================================================= raPUx _$PH
fix x range x 49.9 50.1 mK2M1r
fix x range x -50.1 -49.9 \p&a c&]
fix y range y -0.1 0.1 NXyuv7%5=
fix y range y 0.9 1.1 > =Z@)PAe
fix x y z range z -10.1 -9.9 8*V8B=q}K
; 4 初始应力状态========================================================= D;l)&"|r?
set grav 0 0 -9.81 Gr
a(DGX
set large v8L&F9
o
ini szz -300e3 grad 0 0 18000 d{LQr}_o$$
ini sxx -150e3 grad 0 0 9000 >&kb|)
ini syy -150e3 grad 0 0 9000 +^6v%z
plot cont szz outline on b[I;6HW
solve ;第一次求解 $*u{i4b
pro coh 1e4 fric 30 di 2 bulk 1.07e7 she 6.4e6 ten 1e5 range group groundsill1 /`Wd+
pro coh 0.8e4 fric 20 di 0 bulk 5.14e6 she 1.97e6 ten 1e5 range group groundsill2 9ywPWT[^
pro coh 2.5e4 fric 30 di 3 bulk 3.33e8 she 1.11e8 ten 14433.7 range group groundsill3 |NiWr1&i0
solve ;第二次求解 6$JRV
ini xdisp 0 ydisp 0 zdisp 0 ;将节点位移清零 b@&ydgmaQ
ini xvel 0 yvel 0 zvel 0 ;将节点速度清零 J&
