大家帮我看看为什么会出现'property 'poro' not found in zone 1,在这里谢谢了。 x~,?Zj)n?C
new 4>eg@s N
config fluid @)B5^[4(;
set fluid off !Dn1pjxc
gen zone brick p0 0 0 0 p1 20 0 0 p2 0 20 0 p3 0 0 4 size 20 20 4 group soil1 24k}~"We
gen zone brick p0 0 0 4 p1 20 0 4 p2 0 20 4 p3 0 0 6 size 20 20 4 group soil2 #Y b9w3N
gen zone brick p0 0 0 6 p1 20 0 6 p2 0 20 6 p3 0 0 10 size 20 20 4 group soil3 ?fwr:aP~
ep1Ajz.l
model fl_iso WED7]2>
pro perm 0.599e-13 poro 0.0559 range group soil2 =7Gi4X%
pro perm 0.599e-15 poro 0.04 range group soil3 fC:\Gh5
pro perm 0.599e-15 poro 0.04 range group soil1 B
~bU7.Cd
ini pp 1.5e6 range group soil1
0V
ini pp 0 range group soil3 Z?[J_[ZtR3
ini pp 0 range group soil2 d`*vJ#$>2
ini fdensity 1.52 %ieAY-<"
ini fmod 0.026e9 \}(-9dr
8#3cmpx4
fix pp range z -0.1 0.1 ;底部约束 (.t:sn"P
\shoLp
model mohr Eu_0n6J
def cs c=mFYsSv
;五煤底板 nr%^:u
b_1=E_1/(3*(1-2*p_1)) +n]Knfi
s_1=E_1/(2*(1+p_1)) #!<s& f|O
;五煤 PltPIu)F
b_2=E_2/(3*(1-2*p_2)) Xc<9[@
s_2=E_2/(2*(1+p_2)) n m$G4Q
;三煤底板 ?AH<y/i<Y
b_3=E_3/(3*(1-2*p_3)) Yhdt8[ 2
s_3=E_3/(2*(1+p_3)) SaScP
end Wsz9X;
ZACn_gd[5
set E_1=1e9 p_1=0.36 .j,&/y&
set E_2=1.2e9 p_2=0.37 F=lj$?4{
set E_3=1.3e9 p_3=0.36 "A$Y)j<#G
cs X*;p;N
property bulk = b_1 shear = s_1 friction = 25 cohesion = 0.2e6 ten = 0.04e6 range group soil1 Fsdn2{g8U
property bulk = b_2 shear = s_2 friction = 23 cohesion = 0.1e6 ten = 0.04e6 range group soil2 2^j9m}`
property bulk = b_3 shear = s_3 friction = 21 cohesion = 0.26e6 ten = 0.06e6 range group soil3 Lg53
Ms%
initial density = 2100 range group soil1 `OK
}q
initial density = 1800 range group soil2 1&WFs6
initial density = 2210 range group soil3 5rhdm?Ls0
&Vm[5XW
fix x range x -.1 .1 =swcmab;
fix x range x 9.9 10.1 CF4y$aC#
fix y range y -0.1 0.1 mQ)l`wGh
fix y range y 9.9 10.1 &0blHDMj{#
fix z range z -.1 .1 vdM\scO:
set gravity 0 0 -10 {uG_)G Fr0
step 10 g9Ll>d)tE3
save wei.sav Fs~-exY1
ini xdis=0 ydis=0 zdis=0 &}?e:PEy
;根据体积应变计算渗透率 YRXe j
config zextra 2 z[Qv}pv
def xxx q3:'
69
whilestepping Mqy`j9FbL
pz=zone_head !pXz-hxKT
loop while pz # null b s*Z{R
b=z_vsi(pz) qd ZYaS ~
if z_group(pz)='soil2' [!$>:_Vq/
a=0.0599 \/G Y0s
k=0.599e-13 [O'p&j@
z_prop(pz,'poro')=(a+b)/(1+b) 1 ErYob.p
z_prop(pz,'perm')=(k/(1+b))*(1+b/a)^3
)BB a
else >TJ$Z3
a=0.04 1+#8} z:
k=0.599e-15 F3'G9Xf8Q=
z_prop(pz,'poro')=(a+b)/(1+b) NoIdO/vy"
z_prop(pz,'perm')=(k/(1+b))*(1+b/a)^3 YEj U3^@
endif -"H9 W:
z_extra(pz,1)=z_prop(pz,'poro') b
/ySt<
z_extra(pz,2)=z_prop(pz,'per') 2y,wN"qH*
pz=z_next(pz) .42OSV
end_loop Sy55w={
end YG|T;/-
xxx $<#sCrNX
;开挖 `w}"0+V
model null range group soil2 x 6 14 y 6 14 z 4 4.5 >?V->7QLP
D.}b<kDD
save jiang1.sav t~M_NEPxV
u,q#-d0g;
}mK_d9d x
D%btlw?{
