> Warning : Failed to find a pivot within current block due to too small block size!
> You'd better increase buffer size.
> MULTI-FRONTAL SOLUTION HAS BEEN COMPLETED.
> ERROR : THE SOLUTION IS DIVERGED. PROGRAM STOP THE ANALYSIS.
> Stop - Program terminated.
> 不正常的执行中断!
