analyze
:6.0版以上的SLIDE尚未见有可汉化的CRACK
(2011-11-28 10:41) .W[[Z;D
B Q)1)8r 好像是有6.0的cr版的吧?
/3]b!lFZZ G{4~{{tI D7'P^*4_B Slide v6.007
;c>Co:W http://www.rocscience.com/products \1 ^qfw Setup Serial: 8G79256DA4A283HAF
fe,A\W&8 T*m;G( install sl6007d21.exe
{9 PeBc and copy all from "crack" directory to your instalation dir
+x?_\?&Ks x+mfQcSD& Important Notice:
;JNI$DR You may use this software for evaluation purposes only.
d{~5tv- H If you like it, it is strongly suggested you buy it to support the developers.
Ng;K-WB\ By any means you may not use this software to make money or use it for commercial purpose.
w_*UFLMSqR HOEjLwH Cracked By Freestar
muD7+rn?& 12.27.2010
