  • 10930阅读
abaqus的 system error code 5问题 [复制链接]
离线tydoor
只看楼主 倒序阅读 使用道具 楼主  发表于: 2012-04-09
用abaqus进行计算时,出现以下错误信息导致计算无法进行。
错误信息如下:The executable d:\SIMULIA\Abaqus\6.10-1\exec\standard.exe aborted with system error code 5. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job ww aborted due to errors.
求解答!!!灰常感谢
在计算时用到了子程序
离线215130669
只看该作者 1楼 发表于: 2012-08-24
朋友你解决了你的问题了吗?我也遇到了这个问题
可否分享解决之道啊?
做一个爷们儿
离线bafenzhai
只看该作者 2楼 发表于: 2013-06-02
同求问题答案啊
自信人生二百年,会当击水三千里!
