  • 3024阅读
Three-dimensional Analysis of the Partner of Laterally Loaded Variable Rigidity Pile (Pile Partner) [复制链接]
离线pilepartner
只看楼主 倒序阅读 使用道具 楼主  发表于: 2012-10-10
  • 【作者】:Jiangwei XUE,Yong YANG,Yi ZHAO
  • 【作者机构】:Taiyuan University of Technology;Taiyuan Committee of Housing & Municipal and Rural Construction
  • 【摘要】:Concerning the stress and displacement of the partner under lateral load, reference on full-scale model tests on behavior of cast-in-place concrete pipe piles, two cases are analyzed by means of 3D finite element method, calculations show that in condition I, pile and cap rigid joint (pile foundation) plus partner, partner block the punching stress from pile top to cap continue to spread; and in condition II, the distance between pile top and pile cap is 200 mm, partner is in normal bending shear state; As the flexural rigidity of partner is much larger than the pile, if under earthquake or other rare action, partner may sacrifice firstly to keep pile perform well.
  • 【Abstract】:Concerning the stress and displacement of the partner under lateral load, reference on full-scale model tests on behavior of cast-in-place concrete pipe piles, two cases are analyzed by means of 3D finite element method, calculations show that in condition I, pile and cap rigid joint (pile foundation) plus partner, partner block the punching stress from pile top to cap continue to spread; and in condition II, the distance between pile top and pile cap is 200 mm, partner is in normal bending shear state; As the flexural rigidity of partner is much larger than the pile, if under earthquake or other rare action, partner may sacrifice firstly to keep pile perform well.
  • 【曾发表在】:Applied Mechanics and Materials
Three-dimensional Analysis of the Partner of Laterally Loaded Variable Rigidity Pile (Pile Partner).pdf (219 K) 下载次数:5
文章所研究的桩伴侣,是作者多年的原始创新研究成果并已经获得了国家发明专利,文章开展对
这项技术理论和应用技术的深入研究是很有意义的。按照目前国内建筑工程设计专业的分工惯例,基
础底板的设计都是由结构专业来做,所以本文所研究的承台目前尚属于结构专业的关注对象,但今后
的发展趋势是岩土工程师将全面承担地基基础的设计工作,所以将文章划分到岩土工程专业也是适合
的。
桩伴侣作为将桩与承台联系在一起的纽带,整合桩基础与褥垫层复合地基为一体,伴侣是一个传
统构造上没有而新增加的受力体,对其位移、受力性状的研究有助于摸清规律、为工程设计提供理论
支持,文章在一定程度上基于实体试验的结果,以有限元软件为工具,研究方法适当,结论清晰,所
研究的对象具有首创性,建议发表,并推荐至高水平的S C I杂志。
本帖提到的人: @dahengba @chiaotung
离线dahengba
只看该作者 1楼 发表于: 2012-11-17
把会唱的歌
都为你唱一遍
把你写来的信都深藏在我心
世界上的事不用急着去了解
时间象小船会载我们去远方
他们说这样的梦想太简单不实际
可是我们手牵手誓言不放弃
他们说这样的爱太幼稚多阻碍
可是只有你了解我伤痛永远不走开
不管他们怎么说我只要你爱我
当阳光照耀大地 OH 朋友那么多
不管他们怎么说我只要你爱我
痛苦快乐和伤心我们一起渡过
不管他们怎么说我只要你爱我
当阳光照耀大地 OH 朋友那么多
离线pilepartner
只看该作者 2楼 发表于: 2013-02-23
“扬弃”就是“否定之否定”,前提是继承,目的是发展,特征是标新立异,本质是反传统。笔者申报并获得授权的中国发明专利“桩头的箍与带箍的桩”,就是在综合了桩基础、褥垫层复合地基、桩帽、大直径薄壁筒桩、预留净空、位移调节等众多现有技术基础上的一个“杂交”体,其命名也颇有创意:
(1)直观上可称为“套箍桩”,只是桩周围有“箍”并无新意,也不会获得发明专利授权;
(2)“箍”与竖向增强体之间分开,使得两者之间在水平与竖向的受力和变形既相互独立又相互影响,特别是当调整竖向增强体的顶部与基础底板(承台)之间的距离或垫层的模量时,其整体竖向支承刚度也可相应地发生较大改变,因此,“带箍的桩”专业的学术名称不妨称为“变刚度桩(Variable Rigidity Pile)”,或“变刚度调平桩(变刚度的根本目的是调平底板沉降均匀)”;
(3)竖向增强体的顶部与基础底板(承台)之间预留净空或设置低于模量较低的垫层后,虽然降低了其初始支承刚度,但随着净空减小或垫层压实,竖向增强体的后期支承刚度逐渐恢复或增大刚度降低的阀值,具有柔中带刚或刚中带柔的工程特性(褥垫层复合地基也具有区别于桩基础的类似的特性),因此,取中国古代著名女性将领的名字,称为“木兰桩”、“桂英桩”也很生动形象;
(4)刚性竖向增强体竖向承载能力虽然很强,但作为细长的杆件,其水平承载能力却很弱,特别是桩头通常是基桩最薄弱的部位需要额外增强,工程实践中也有局部增大桩头尺寸、局部加强桩身上部配筋或者对空心桩顶局部填充等做法和规定,但都是依附于竖向增强体上并不独立,而同样是增强,“箍”与竖向增强体之间却是分开的,另外,类似于结构专业无梁楼盖的柱帽,“箍”还具有增强基础底板(承台)刚度的作用,再考虑到“箍”不仅仅分担竖向增强体的水平荷载也间接影响其竖向承载等多种因素,因此,笔者更倾向于称其为桩伴侣(Pile Partner),或者是伴侣桩(Partner & Pile)、侣伴桩(Pile with Partner)这样一个貌似与工程不搭界、甚至带有点文艺、暧昧和浪漫情愫的名称,在这篇堂堂工学博士论文的序言中,摘录借用著名诗人舒婷的代表作《致橡树》的诗句可以科学解释、阐述、和理解桩伴侣名称的合理性:
我如果爱你——
绝不像攀缘的凌霄花,
借你的高枝炫耀自己;……
我必须是你近旁的一株木棉,
作为树的形象和你站在一起。……
你有你的铜枝铁干,……
我有我的红硕花朵,……
我们分担……,
我们共享……,
仿佛永远分离,
却又终身相依。
幸运的是,生逢鼓励创新、提倡偏执的时代,桩伴侣不仅是岩土论坛、QQ群等网络平台近年的热门词汇,而且,桩伴侣及其初步理论在业内也得到了一定程度的认可和支持鼓励,感谢建设部2008奥运工程及全国重大基础工程创新技术成果应用交流会、第三届全国岩土与工程学术大会、2012年全国吹填土地基处理学术研讨会、等组办方所给予笔者专题报告介绍桩伴侣的机会,同时,随着一些文章的发表,桩伴侣(Pile Partner)成为工程索引EI检索的正式条目。
实践是检验真理的唯一标准,笔者多年来一直没有放弃向业主、设计、施工单位尽力争取桩伴侣在工程中得到应用的机会,然而,虽然业界专家基本认可桩伴侣在理论上所具有的“正能量”,但由于建筑工程的单件性、投资巨大,以及设计严格遵守“规范”不逾矩,传统上对于沉降和承载力的认识以及对于基桩承受地震等水平荷载的忽视,甚至还有近年国内房地产业投资火爆“不差钱”等原因,桩伴侣目前仍无工程应用,桩伴侣的研究“很差钱”。
因为没有工程实例,本文的写作框架和行文特征难免与常规的工学博士论文有所不同,于是,在研究深度上的欠缺以增大广度加以弥补,在数学工具应用难度上的欠缺以基础理论的突破加以弥补,在具体工程计算上的欠缺以一般的理论假设和推导加以弥补,因此,本文天然地存在着假设有余而求证不足、创新有余而数据不足的缺陷。
本文也遵循着揭示问题——解决问题的最基本的研究路线,桩伴侣技术主要是针对目前桩基础或褥垫层复合地基这两种常规的基桩构造形式所各自存在缺陷的改进而提出的,广大学者和工程技术人员对褥垫层复合地基已研究应用数十年,桩基础甚至应用数十万年,相关研究已非常精细、精准、精致,而本文的研究对象桩伴侣还仅仅是一个新生儿,作为多种既有技术的“杂交”体,桩伴侣的“DNA”结构(即构造形式)显然更加复杂,有限的研究不可能达到目前基桩计算和理论推导的深度和难度,而且在岩土工程的研究中也更应当注重基本概念的把握和经验数据的修正,因此,本文的研究方法首先更应当先将复杂问题简单化,抓住主要矛盾和矛盾的主要方面,影响或变革业内长期形成的惯性思维和路径依赖,研究目标是为后续研究和工程应用抛砖引玉。
感谢您的理解、支持或参与,期待您的宝贵意见和建议。
