  • 1264阅读
  • 0回复
新手求interface命令答疑? [复制链接]
离线szygmysf
只看楼主 倒序阅读 使用道具 楼主  发表于: 2013-05-18
; Create Base
gen zone brick size 3 3 3 &
         p0 (0,0,0) p1 (3,0,0) p2 (0,3,0) p3 (0,0,1.5) &
         p4 (3,3,0) p5 (0,3,1.5) p6 (3,0,4.5) p7 (3,3,4.5)
group Base
; Create Top - 1 unit high for initial spacing
         p0 (0,0,2.5) p1 (3,0,5.5) p2 (0,3,2.5) p3 (0,0,7) &
         p4 (3,3,5.5) p5 (0,3,7) p6 (3,0,7) p7 (3,3,7)
group Top range group Base not
; Create interface elements on the top surface of the base
interface 1 face range plane norm (-1,0,1) origin (1.5,1.5,3) dist 0.1
plot create view_int
plot add surface
plot add interface red
plot show
pause
; Lower top to complete geometry
ini z add -1.0 range group Top
save int.sav
这里的interface命令是来模拟什么的?
