  • 4453阅读
abaqus用户子程序计算时出现的问题error code 5 [复制链接]
离线chenqzmessi
只看楼主 倒序阅读 使用道具 楼主  发表于: 2013-09-13
提示:“The executable C:\SIMULIA\Abaqus\6.10-1\exec\standard.exe aborted with system error code 5. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same com“
请问出现这种问题怎么解决??????
离线805048710
只看该作者 1楼 发表于: 2013-10-30
楼主,你的问题解决没。我也遇到同样的问题The executable d:\SIMULIA\Abaqus\6.10-1\exec\standard.exe aborted with system error code 5. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
离线chenqzmessi
只看该作者 2楼 发表于: 2013-11-04
可能是少了参数的定义
