  • 26347阅读
  • 41回复
一些geo-studio资料,敞开下载!!! [复制链接]
离线gnotil80
只看楼主 倒序阅读 使用道具 楼主  发表于: 2015-01-12
Footing stability Footing stability.pdf (50 K) 下载次数:68 Filling pond H vs V functions. Filling pond H vs V functions.pdf (88 K) 下载次数:42 Excavation below watertable Excavation below watertable.pdf (176 K) 下载次数:53 Drains Drains.pdf (116 K) 下载次数:41 Dam2 Dam.pdf (126 K) 下载次数:39 Dam with core Dam with core.pdf (548 K) 下载次数:50 Dam1 Dam construction by stages.pdf (106 K) 下载次数:43 Cutoff interface Cutoff interface.pdf (160 K) 下载次数:43 Cutoff interface anisotropy Cutoff interface anisotropy.pdf (257 K) 下载次数:33 CTRAN Tutorial CTRAN Tutorial.pdf (149 K) 下载次数:37 Convective air flow Convective air flow in heated column.pdf (1872 K) 下载次数:62 Convective air flow Convective air flow in heated column.pdf (1872 K) 下载次数:62 Consolidation Consolidation.pdf (58 K) 下载次数:35 Comparison4 Comparison with stability chart.pdf (30 K) 下载次数:35 Comparison3 Comparison with publication.pdf (74 K) 下载次数:36 Comparison 2 Comparison with infinite slope.pdf (84 K) 下载次数:46 Comparison1 Comparison with hand calculations.pdf (104 K) 下载次数:32 Buried pipe stresses Buried pipe stresses.pdf (115 K) 下载次数:34 Braced deep excavation Braced deep excavation in soft ground.pdf (224 K) 下载次数:40 box dT test box dT test increase Pa.pdf (1530 K) 下载次数:34 Block slip surfaces Block slip surfaces.pdf (61 K) 下载次数:40 Blast Vibrations Blast Vibrations.pdf (54 K) 下载次数:37 Berlin tie-back wall Berlin tie-back wall.pdf (436 K) 下载次数:34 Auto locate weak layer Auto locate weak layer.pdf (115 K) 下载次数:69 Anisotropy in Seepage Anisotropy in Seepage Analyses.pdf (1002 K) 下载次数:86 Anisotropic strength Anisotropic strength.pdf (67 K) 下载次数:66 Auto locate weak layer Auto locate weak layer.pdf (115 K) 下载次数:69 Anisotropy in Seepage Anisotropy in Seepage Analyses.pdf (1002 K) 下载次数:86 Anisotropic strength Anisotropic strength.pdf (67 K) 下载次数:66 指南 ++++++++++【2007】GeoStudio_中文操作教程.pdf (9190 K) 下载次数:182 GeoStudio软件在岩土工程中 GeoStudio软件在岩土工程中的应用.pdf (4506 K) 下载次数:272 应力与渗流的耦合分析 应力与渗流的耦合分析.pdf (1228 K) 下载次数:232 非饱和渗流关键问题探讨 非饱和渗流关键问题探讨.pdf (802 K) 下载次数:180 运用Excel、AutoCAD 运用Excel、AutoCAD实现岩土分析软件GeoStudio中的辅助建模.pdf (231 K) 下载次数:307
附件: Gravity retaining wall.pdf (45 K) 下载次数:81
附件: Heave due to infiltration.pdf (706 K) 下载次数:62
附件: Henry Density Dependent.pdf (651 K) 下载次数:57
附件: High earth pressure coefficient Ko.pdf (117 K) 下载次数:46
附件: Hyperbolic footing.pdf (205 K) 下载次数:42
附件: Hyperbolic triaxial tests.pdf (166 K) 下载次数:41
附件: Infiltration and air pressure build up.pdf (207 K) 下载次数:50
附件: Level ground.pdf (280 K) 下载次数:48
附件: Lower San Fernando Dam.pdf (775 K) 下载次数:55
附件: Lysimeter beneath cap.pdf (535 K) 下载次数:51
附件: Lysimeters.pdf (534 K) 下载次数:48
附件: MCC - triaxial tests.pdf (164 K) 下载次数:47
附件: Newmark deformation analysis.pdf (68 K) 下载次数:46
附件: Normal stress on inclined beams.pdf (20 K) 下载次数:40
附件: Pile pull out test.pdf (92 K) 下载次数:51
附件: Pipeline Freezing Analysis.pdf (198 K) 下载次数:43
附件: Pond Infiltration.pdf (193 K) 下载次数:47
附件: Preferential Flow in Vertical Layers.pdf (657 K) 下载次数:45
附件: Pressure plate drying and wetting.pdf (111 K) 下载次数:48
附件: Probabilistic and Sensitivity.pdf (83 K) 下载次数:46
附件: Probability - James Bay Case History.pdf (72 K) 下载次数:40
附件: Radial flow to a well.pdf (80 K) 下载次数:39
附件: Rapid drawdown with effective stress.pdf (183 K) 下载次数:49
附件: Rapid drawdown with multi-stage.pdf (95 K) 下载次数:44
附件: Rapid drawdown.pdf (522 K) 下载次数:57
附件: Rapid fill and drain.pdf (506 K) 下载次数:52
附件: Reinforcement with anchors.pdf (100 K) 下载次数:55
附件: Reinforcement with fabrics.pdf (147 K) 下载次数:51
附件: Reinforcement with nails.pdf (143 K) 下载次数:56
附件: Reinforcement with piles.pdf (97 K) 下载次数:49
附件: Relief Well Spacing.pdf (1371 K) 下载次数:42
附件: Road ditch ponding during rainfall.pdf (253 K) 下载次数:49
附件: Sandbox.pdf (164 K) 下载次数:37
附件: Sat-Unsat column tests.pdf (172 K) 下载次数:42
附件: Seepage and stability.pdf (109 K) 下载次数:58
附件: Sequential tailings placement.pdf (176 K) 下载次数:40
附件: Settlement due to pumping well.pdf (253 K) 下载次数:37
附件: Shaking Tie-back wall.pdf (53 K) 下载次数:36
附件: Sheet pile wall.pdf (59 K) 下载次数:46
附件: SIGMA Tutorial.pdf (239 K) 下载次数:69
附件: Slip on weak layer.pdf (55 K) 下载次数:42
附件: Slope with ponded water.pdf (156 K) 下载次数:52
附件: Soft ground coupled consolidation.pdf (72 K) 下载次数:54
附件: Soil-Structure Interaction.pdf (32 K) 下载次数:47
附件: Spatial pore water pressure head.pdf (135 K) 下载次数:47
附件: Spatial variation of soil properties.pdf (1283 K) 下载次数:53
附件: Stability with FE pore water pressure.pdf (169 K) 下载次数:62
附件: Stability with FE stresses.pdf (95 K) 下载次数:51
附件: Strength reduction stability.pdf (169 K) 下载次数:53
附件: Strip footing.pdf (309 K) 下载次数:50
附件: Structural Beams in Quake.pdf (54 K) 下载次数:40
附件: Strutted Excavation.pdf (58 K) 下载次数:51
2条评分土币+6
2020596 土币 +5 - 2017-03-14
心飞扬2015 土币 +1 优秀资料,感谢! 2016-07-02
离线keepcalm
只看该作者 1楼 发表于: 2015-01-13
都是英文的?
离线zhangheng
只看该作者 2楼 发表于: 2015-03-17
离线LeeG2015
只看该作者 3楼 发表于: 2015-05-19
离线phdsxc2012
只看该作者 4楼 发表于: 2015-05-31
好资料!正需要的资料。
离线xiaojunok01
只看该作者 5楼 发表于: 2015-07-05
牛人啊!只是全是英文,比较难分辨哪些是需要的
离线zhangheng
只看该作者 6楼 发表于: 2016-06-30
离线ntxiaohui1
只看该作者 7楼 发表于: 2016-09-13
离线zxhbd100
只看该作者 8楼 发表于: 2016-09-14
离线liuzhenxiang
只看该作者 9楼 发表于: 2016-09-14
这么多,真是大好人呀
只看该作者 10楼 发表于: 2016-10-25
好厉害,资料好丰富呢,认真学习~谢谢
离线岩土小弟
只看该作者 11楼 发表于: 2016-11-28
牛逼的资料
