  • 3213阅读
  • 40回复
Settle3D三维固结沉降分析软件使用方法 [复制链接]
在线cdddd
只看楼主 倒序阅读 使用道具 楼主  发表于: 2021-12-06
Settle3D三维固结沉降分析软件(已破解)
https://bbs.yantuchina.com/read.php?tid=217760
Settle3D三维固结沉降分析软件使用方法,哪个有教程?
settle    英[ˈsetl]
美[ˈsetl]
v.    解决(分歧、纠纷等); 定居; 结束(争论、争端等); (最终)决定,确定,安排好;
n.    高背长椅(老式木家具,有扶手,座下多带柜);
[例句]It's time you settled your differences with your father.
现在你该解决同你父亲之间的分歧了。
[其他]    第三人称单数:settles 复数:settles 现在分词:settling 过去式:settled 过去分词:settled
这里settle具体是什么含义?求解?
在线cdddd
只看该作者 1楼 发表于: 2021-12-06
[软件应用交流]rocscience Settle3D新型计算固结沉降的分析软件
https://bbs.yantuchina.com/read.php?tid=316820
Analysis of tunnel-induced settlement damage to surface structures.pdf
https://bbs.yantuchina.com/read.php?tid=5360
在线cdddd
只看该作者 2楼 发表于: 2021-12-06
[软件]三维有限元分析软件
https://bbs.yantuchina.com/read.php?tid=276982
[资料]【GEO5】地基固结沉降分析模块/Settlement
https://bbs.yantuchina.com/read.php?tid=280929
https://bbs.yantuchina.com/read.php?tid=280928
在线cdddd
只看该作者 3楼 发表于: 2021-12-06
Reliability assessment of EPB tunnel-related settlement
https://bbs.yantuchina.com/read.php?tid=197622
[书籍]An Engineering Manual for Settlement Studies by JM Duncan 1976
https://bbs.yantuchina.com/read.php?tid=119850
[其他]群桩沉降估算 Pile Group Settlement Estimation
https://bbs.yantuchina.com/read.php?tid=88712
在线cdddd
只看该作者 4楼 发表于: 2021-12-06
shallow foundations- bearing capacity and settlement
https://bbs.yantuchina.com/read.php?tid=67863
consolidation settlement caused by shield tunnel
https://bbs.yantuchina.com/read.php?tid=68025
[建筑地基]SETTLEMENT OF SHALLOW FOUNDATION-SCHMERTMANN'S METHOD
https://bbs.yantuchina.com/read.php?tid=73877
在线cdddd
只看该作者 5楼 发表于: 2021-12-06
Settlement Ratio of Pile Groups in Sandy Soils from Field Load Test
https://bbs.yantuchina.com/read.php?tid=24599
the nonlinearity of the load-settlement behaviors 如何翻译
https://bbs.yantuchina.com/read.php?tid=25736
在线cdddd
只看该作者 6楼 发表于: 2021-12-06
[国外文献]求文献:Effect of stone column yield on settlement of rigid foundations in stabilized clay
https://bbs.yantuchina.com/read.php?tid=40465
[国外文献]求文献:Improvement of settlement behaviour of soft layers by means of stone columns
https://bbs.yantuchina.com/read.php?tid=40745
[其他]Settlement of vertical piles exposed to waves
https://bbs.yantuchina.com/read.php?tid=50097
在线cdddd
只看该作者 7楼 发表于: 2021-12-06
surface settlement  formula  due to tunnel construction
https://bbs.yantuchina.com/read.php?tid=62912
tunnel induced settlements and structural forces in linings
https://bbs.yantuchina.com/read.php?tid=65710
在线cdddd
只看该作者 8楼 发表于: 2021-12-06
沉降分析1-3页未
砂土地基上圆形基础的沉降分析模型
https://bbs.yantuchina.com/read.php?tid=325911
在线cdddd
只看该作者 9楼 发表于: 2021-12-06
[软件]大面积地基处理后的沉降分析,用什么软件比较好啊
https://bbs.yantuchina.com/read.php?tid=328672
[软件]中翰建筑沉降分析软件2.01(学习版)
https://bbs.yantuchina.com/read.php?tid=319258
在线cdddd
只看该作者 10楼 发表于: 2021-12-06
宣武门地铁车站群洞施工技术及沉降分析.pd
https://bbs.yantuchina.com/read.php?tid=18520
地铁隧道盾构法施工引起的地表沉降分析.pdf
https://bbs.yantuchina.com/read.php?tid=16902
在线cdddd
只看该作者 11楼 发表于: 2021-12-06
秦山三期核电工程场地岩石力学性质与差异性沉降分析
https://bbs.yantuchina.com/read.php?tid=14228
[其他]地铁深基坑施工引起的既有建筑物沉降分析
https://bbs.yantuchina.com/read.php?tid=8857
