  • 12380阅读
  • 34回复
从新加坡尼诰大道塌陷谈谈PLAXIS的缺陷! [复制链接]
离线bingjihuashi
只看该作者 12楼 发表于: 2008-08-25
很好的资料 学习
离线bingjihuashi
只看该作者 13楼 发表于: 2008-08-25
wenjian下不了了 啊
离线bingjihuashi
只看该作者 14楼 发表于: 2008-08-25
郁闷啊
离线bingjihuashi
只看该作者 15楼 发表于: 2008-08-25
离线leixiaoqin
只看该作者 16楼 发表于: 2008-08-26
感谢分享!
离线ongyinhoe
只看该作者 17楼 发表于: 2008-08-26
gcoast,
i agree with gcoast, where there are few reasons causing the casualty.
1. no steel prop at bottom which is the site negligence
2. not sensitive to the real time monitoring
3. use of MC model in modelling. lower excess pore water pressure and higher undrained shear strength. This can be easily seen from the MC stress path. The shortcoming will be eliminated if you use higher order of soil model such as modified cam clay or HSM.
ong
oyh48@hotmail.com
2条评分土币+1
tm038 土币 +1 - 2011-06-20
gcoast 鲜花 +1 - 2008-08-26
离线ongyinhoe
只看该作者 18楼 发表于: 2008-08-26
gcoast,
do you use geofea?
ong
oyh48@hotmail.com
离线gcoast
只看该作者 19楼 发表于: 2008-08-27
引用第18楼ongyinhoe于2008-08-26 13:24发表的  :
gcoast,
do you use geofea?
ong
No, I don't. i am new in this area. I was as a structure engineer and now i moved to this area so called a area far above structure. where i later found intersting. have to pick up many things from you guys. cheers
离线高铉清
只看该作者 20楼 发表于: 2008-08-31
如果用ansys来模拟,不知道结果又如何?
离线ddedit817
只看该作者 21楼 发表于: 2008-08-31
任何 事物都没有 完美的。
离线hhuzhb
只看该作者 22楼 发表于: 2009-07-19
都是本构惹得祸呀!都是本构惹得祸呀!
hhuzhb
离线hgzyyl
只看该作者 23楼 发表于: 2010-03-31
谢谢了!下载了!
