  • 6421阅读
  • 21回复
[国外文献]Lectures and Papers of Hoek [复制链接]
离线schwein001
只看楼主 倒序阅读 使用道具 楼主  发表于: 2010-01-01
1964 Fracture of Anistropic Rock.pdf (1526 K) 下载次数:80
1965 Brittle fracture propagation in rock under compression.pdf (4526 K) 下载次数:62
1965 Rock Fracture Under Static Stress Conditions.part1.rar (9766 K) 下载次数:52
1965 Rock Fracture Under Static Stress Conditions.part2.rar (4480 K) 下载次数:51
1966 Rock Mechanics - an introduction for the practical engineer.pdf (8238 K) 下载次数:53
1968 A simple triaxial cell for field and laboratory testing of rock.pdf (4396 K) 下载次数:50
1970 Developments in triaxial testing equipment.pdf (2938 K) 下载次数:44
1974 The Design of Rock Slopes and Foundations.pdf (3310 K) 下载次数:47
1977 Drakensberg pumped storage scheme, rock engineering aspects.pdf (3766 K) 下载次数:53
1978 Trends in relationships between measured rock in situ stresses and depth.pd (474 K) 下载次数:41
1981 Design of large underground caverns for hydro-electric projects, with refer (1818 K) 下载次数:42
1982 Geotechnical considerations in tunnel design and contract preparation.pdf (799 K) 下载次数:43
1983 Strength of jointed rock masses.pdf (4557 K) 下载次数:45
1987 Rock support in underground mines.pdf (1029 K) 下载次数:48
1989 Progress with the excavation and support of the Mingtan power cavern roof.p (1826 K) 下载次数:37
1990 Estimating Mohr-Coulomb friction and cohesion values from the Hoek-Brown fa (242 K) 下载次数:39
1992  A modified Hoek-Brown criterion for jointed rock masses.pdf (1819 K) 下载次数:43
1995 Consulting Boards for Large Civil Engineering Projects.pdf (47 K) 下载次数:32
1997 Practical estimates or rock mass strength.pdf (3365 K) 下载次数:43
1998 Applicability of the Geological Strength Index (GSI) classification for ver (930 K) 下载次数:38
1998 Geotechnical risks on large civil engineering projects.pdf (119 K) 下载次数:37
1998 Tunnel support in weak rock.pdf (290 K) 下载次数:38
1999 Putting Numbers to Geology – an Engineer’s Viewpoint.pdf (2826 K) 下载次数:41
1999 Support for very weak rock associated with faults and shear zones.pdf (443 K) 下载次数:45
2000 GSI – A geologically friendly tool for rock mass strength estimation.pdf (3210 K) 下载次数:52
2000 Predicting Tunnel Squeezing problems in weak heterogeneous rock masses.pdf (3457 K) 下载次数:60
2000 Rock mass properties for surface mines.pdf (373 K) 下载次数:40
2000 Rock slopes in Civil and Mining Engineering.pdf (1880 K) 下载次数:44
2001 Big tunnels in bad rock.pdf (2668 K) 下载次数:48
2001 Estimating the geotechnical properties of heterogeneous rock masses such as (5725 K) 下载次数:38
2001 Rock mass properties for underground mines.pdf (313 K) 下载次数:32
2001 The role of experts in tunneling – experience from Greece and the world.pdf (76 K) 下载次数:32
2002 Hoek-Brown failure criterion – 2002 Edition.pdf (932 K) 下载次数:52
2004 Characterization of Granite and the Underground Construction in Metro do Po (2847 K) 下载次数:44
2004 Geological risk in the use of TBMs in heterogeneous rock masses – The case (1484 K) 下载次数:38
2004 Thissavros hydropower plant managing geotechnical problems in construction. (1560 K) 下载次数:38
2005 Characterization and engineering properties of tectonically undisturbed but (1333 K) 下载次数:38
2005 Face support control in the Metro do Porto project.pdf (1253 K) 下载次数:44
2005 The geological Strength index applications and limitations.pdf (860 K) 下载次数:47
2005 Variability of the engineering properties.pdf (1620 K) 下载次数:43
2006 Empirical estimation of rock mass modulus.pdf (1444 K) 下载次数:45
2006 Greece’s Egnatia Highway Tunnels.pdf (493 K) 下载次数:46
2006 Support Decision Criteria for Tunnels in Fault Zones.pdf (1663 K) 下载次数:47
2006 The construction of the Egnatia Highway through unstable slopes in northern (3210 K) 下载次数:40
2006 Variability of the engineering properties of rock masses quantified by the (1620 K) 下载次数:44
2007 A brief history of the development of the.pdf (646 K) 下载次数:51
2008 Integration of geotechnical and structural design in tunnelling.pdf (6778 K) 下载次数:66
离线schwein001
只看该作者 1楼 发表于: 2010-01-01
祝大家新年快乐,有任何无法下载的,请指出,非常感谢!
刚 搜索了下,发现没有 这本书(也许有中文名字) ,这是 2007版
Practical_Rock_Engineering.part1.rar (9766 K) 下载次数:42
Practical_Rock_Engineering.part2.rar (9766 K) 下载次数:43
Practical_Rock_Engineering.part3.rar (2775 K) 下载次数:40
[ 此帖被schwein001在2010-03-15 09:30重新编辑 ]
鲜花(wangshimin) 感谢楼主条评分
离线xueleixll
只看该作者 2楼 发表于: 2010-01-01
楼主太好啦!
离线彩虹
只看该作者 3楼 发表于: 2010-01-01
非常感谢楼主!!!
雨后彩虹
离线hegc9210
只看该作者 4楼 发表于: 2010-01-05
Thank you very much
离线huangmanbin
只看该作者 5楼 发表于: 2010-01-07
谢谢楼主了  很少这么系统的找到HOEK的PAPER了
engineer make things,and they make things better
离线windyxsw
只看该作者 6楼 发表于: 2010-01-08
Thank you very much
离线schwein001
只看该作者 7楼 发表于: 2010-01-19
我的贡献沉了,杯具啊
离线tianyazhilv
只看该作者 8楼 发表于: 2010-02-02
谢谢,都能下载,很好
离线ylxiong
只看该作者 9楼 发表于: 2010-02-04
you are very kind ,thank you for your sharing
离线schwein001
只看该作者 10楼 发表于: 2010-03-14
最近抽空看完本书(Practical Rock Engineering),发现后面缺几章,先补上,对各位造成不便,请见谅。
12_Tunnels_in_weak_rock.pdf (5009 K) 下载次数:10
13_Design_of_large_underground_caverns.pdf (3346 K) 下载次数:10
14_Rockbolts_and_cables.pdf (1548 K) 下载次数:11
15_Model_to_demonstrate_how_rockbolts_work.pdf (2280 K) 下载次数:10
16_Shotcrete_support.pdf (2356 K) 下载次数:10
17_Blasting_damage_in_rock.pdf (1355 K) 下载次数:10
离线wangshimin
只看该作者 11楼 发表于: 2010-03-17
千年不遇的好帖,谢谢楼主的无私,顶起。
