gtcewli3网友上传了IASPEI 的 International Handbook of Earthquake and Engineering Seismology。这本书附带三张CD里有很多有用的东西。这里上传的是用有限断层模型计算地震动的程序,在本书附带CD里编号85.14。具体说明可参看本书。简介贴在这里: ^&\<[\
vz^=o'
Software For Calculating Earthquake Ground Motions From Finite Faults In Vertically Varying Media s]Z++Lh<{
Id{Ix(O
Chapter 85.14 of the IASPEI International Handbook of Earthquake and Engineering Seismology Cf.(/5X
G$t:#2
We have prepared two Fortran 77 software packages, COMPSYN and ISOSYN, for calculating earthquake ground motions caused by ruptures occuring on planar faults of finite spatial extent embedded in vertically varying media. Both packages contain all necessary Fortran source files, as well as source files for visualizing the results of the calculations in device-independent postscript graphic output files. Also included in the packages are documentation and sample input and output files that duplicate several published theoretical seismogram examples. All software must be run in a command-line-oriented operating system and has been successfully run unmodified under DOS and VMS. UNIX and LINUX users might need to make slight changes to the fortran source code to accommodate the fact that UNIX file names are case sensitive whereas DOS and VMS file names are not. This is described in the documentation.
