set log on BLMcvK\9
set logfile mgan.log ~xvQ?c?-
new OtQKDpJq
plot block group O8dDoP\F2
plot show zq1&MXR)l
generate zone radcyl p0 = (0,0,0) p1 = (20,0,0) & 8|7Tk[X1j
p2 = (0,1,0) p3 = (0,0,20) p4 = (20,1,0) p5 = (0,1,20) & "OK(<x]3;>
p6 = (20,0,20) p7 = (20,1,20) p8 = (2.4,0,0) p9 = (0,0,2.4) p10 = (2.4,1,0) & }[i35f[w
p11 = (0,1,2.4) size 10 5 10 10 dimension 2.4 2.4 2.4 2.4 ratio 1 1 1 1 fill group tunnel $V5Ol6@2
gen zone radtunnel p0 = (0,0,0) p1 = (0,0,-20) & cs@5K$v
p2 = (0,1,0) p3 = (20,0,0) & zWjGGTP~3&
size 10 5 10 10 dimension 2.2,2.4,2.2 fill group tunnel2 D4o?
gen zone reflect normal (-1,0,0) origin =(0,0,0) +;;fw |/
group section1 range y 0 1 group tunnel any group tunnel2 any Eda
sGCo
save model.sav :B=`^>RK
pau ]/d2*#
;德鲁克-普拉格模型的材料参数 df8rf8B-
model dr ?0_i{BvN
prop bulk 1.41e9 shear 0.97e9 kshear 1.603e7 qvol 0.917 2ix_,yTO
;给定边界条件 jv_sRV
fix x range x -20.1 -19.9 k5}i^^.
fix x range x 19.9 20.1 +m>Kb edl
fix z range z -20.1 -19.9 OQ[>s(`*{
fix y range y -0.1 0.1 V?Nl% M[b
fix y range y 0.9 1.1 lbv, jS
;初始应力赋值 ]7xAL7x
set grav 0 0 -10 (iWNvVGS
ini density 2750 Gl1`Nx0
ini szz -17.6e6 grad 0 0 27500 wlKL|N
ini sxx -17.6e6 grad 0 0 27500 W%1fm/G0
ini syy -17.6e6 grad 0 0 27500 Ho"FB|e
hist unbal AHZ6
solve &6}vvgz
save chushihua1_maogan.sav K5w22L^=+
ini xvel 0 yvel 0 zvel 0 ^i:%;oeG
ini xdis 0 ydis 0 zdis 0 Hs-NP#I
mod null range group section1 +d'h20
solve RbrvY
save kaiwa4.sav }#yRaIp
;第一排 XUSfOf(
sel cable id=1 begin 0 0 2.4 end 0 0 4.9 nseg 25 #Q$4EQB
sel cable id=1 begin 0.92 0 2.2 end 1.88 0 4.53 nseg 25 PK+][.6H
sel cable id=1 begin 1.7 0 1.7 end 3.46 0 3.46 nseg 25 P, S9gG9
sel cable id=1 begin 2.2 0 0.92 end 4.53 0 1.88 nseg 25 9qqEr~
sel cable id=1 begin 2.4 0 0 end 4.9 0 0 nseg 25 8{d`N|k
sel cable id=1 begin 2.4 0 -0.8 end 4.9 0 -0.8 nseg 25 ~i
&K,
sel cable id=1 begin 2.4 0 -1.6 end 4.9 0 -1.6 nseg 25 .R-:vU880
sel cable id=1 begin -0.92 0 2.2 end -1.88 0 4.53 nseg 25 H!45w;,I
sel cable id=1 begin -1.7 0 1.7 end -3.46 0 3.46 nseg 25 SH`"o
sel cable id=1 begin -2.2 0 0.92 end -4.53 0 1.87 nseg 25 wh~~g
qi9
sel cable id=1 begin -2.4 0 0 end -4.9 0 0 nseg 25 *`l>1)B>
sel cable id=1 begin -2.4 0 -0.8 end -4.9 0 -0.8 nseg 25 "&2D6
sel cable id=1 begin -2.4 0 -1.6 end -4.9 0 -1.6 nseg 25 hw1ZTD:Y
sel cable pro emod 2.06e11 xcarea 1.57e-3 gr_per 1. & wT.V3G
yten 25e4 gr_k 17.5e6 gr_c 20e4 range id 1
|u$AzI
solve M#|TQa N
save maogan4.save t*D[Q$v
aa".d[*1
[e&$4l IS
请大家帮忙看看,我这个程序为什么运行了,支护没效果,谢谢!!
