  • 28961阅读
  • 118回复
岩石与岩体有何不同? [复制链接]
离线xyd65273
只看该作者 12楼 发表于: 2009-11-29
老帽的问题不错,5楼的全面回答又使我加深了岩石和岩体的认识。值得学习学习。
离线1060949895
只看该作者 13楼 发表于: 2009-11-29
        楼上回答的很好很全面
离线美好525
只看该作者 14楼 发表于: 2009-11-30
谢谢楼主,也谢谢5楼的,学习了。
桃李不言,下自成蹊!
离线truerobin
只看该作者 15楼 发表于: 2009-12-01
岩体存在结构面
离线fengchun521-
只看该作者 16楼 发表于: 2009-12-02
岩石是岩体的组成部分,岩石是完整的块体,而岩体由岩石及各类结构面组合而成。
岩石力学研究的是实验室尺度下的本构关系,如低围压下的脆性破坏,高围压下的塑性破坏,及岩石的蠕变特性等。
岩体力学研究的是工程尺度下本构关系,除了岩石的基本物理力学特性之外,还需引入节理、断层等的本构。
岩体力学的关键是要弄清楚结构面的分布及展布特性,也即孙广忠先生说的结构控制论。
呵呵,以上仅以个人的看法,请各位指正:)
共1条评分
土老帽 土币 +100 - 2010-01-25
爱岩土,爱生活
离线zhuhaha
只看该作者 17楼 发表于: 2009-12-03
The engineering mechanics problem posed in all structural design is the prediction of the performance of the structure under the loads imposed on it during its prescribed functional operation. The subject of engineering rock mechanics, as applied in mining engineering practice, is concerned with the application of the principles of engineering mechanics to the design of the rock structures generated by mining activity. The discipline is closely related to the main streams of classical mechanics and continuum mechanics, but several specific factors identify it as a distinct and coherent field of engineering.
A widely accepted definition of rock mechanics is that first offered by the US National Committee on Rock Mechanics in 1964, and subsequently modified in 1974: Rock mechanics is the theoretical and applied science of the mechanical behaviour of rock and rock masses; it is that branch of mechanics concerned with the response of rock and rock masses to the force fields of their physical environment.
Rock mechanics itself forms part of the broader subject of geomechanics which is concerned with the mechanical responses of all geological materials, including soils. The learned society for geomechanics in Australia, the Australian Geomechanics Society, defines geomechanics as “the application of engineering and geological principles to the behaviour of the ground and ground water and the use of these principles in civil, mining, offshore and environmental engineering in the widest sense”.
This definition of geomechanics is almost synonymous with the term geotechnical engineering, which has been defined as “the application of the sciences of soil mechanics and rock mechanics, engineering geology and other related disciplines to civil engineering construction, the extractive industries and the preservation and enhancement of the environment” (Anon, 1999). The term geotechnical engineering and the adjective geotechnical will be used in this sense in this text.
Rock differs from most other engineering materials in that it contains fractures of one type or another which render its structure discontinuous. Thus a clear distinction must be made between the rock element or rock material on the one hand and the rock mass on the other. Rock material is the term used to describe the intact rock between discontinuities; it might be represented by a hand specimen or piece of drill core examined in the laboratory. The rock mass is the total in situ medium containing bedding planes, faults, joints, folds and other structural features. Rock masses are discontinuous and often have heterogeneous and anisotropic engineering properties. The nature and distribution of structural features within the rock mass is known as the rock structure. Obviously, rock structure can have a dominant effect on the response of a rock mass to mining operations. It can influence the choice of a mining method and the design of mining layouts because it can control stable excavation spans, support requirements, subsidence, cavability and fragmentation characteristics. At shallow depths and in de-stressed areas, structurally controlled failures may be the prime concern in excavation design. At depth and in areas of high stress concentration, the influence of structure may be less marked, and limiting the induced boundary stresses or energy release rates may be more important considerations.
共1条评分
土老帽 土币 +251 - 2009-12-05
离线zhuhaha
只看该作者 18楼 发表于: 2009-12-03
粘贴后,发现有些word被分解了
共1条评分
土老帽 土币 +100 - 2009-12-05
离线zhuhaha
只看该作者 19楼 发表于: 2009-12-03
以上内容来自:B.H.G.Brady, E.T.Brown - Rock Mechanics(Third edition),KLUWER ACADEMIC PUBLISHERS,2004
离线41642245
只看该作者 20楼 发表于: 2009-12-04
补充一下:
一、岩体力学(rockmass mechanics)是力学的一个分支学科,是研究岩体在各种力场作用下变形与破坏规律的理论及其实际应用的科学,是一门应用型基础学科。
二、岩体力学的研究对象是各类岩体,而服务对象则涉及到许多领域和学科。如水利水电工程、采矿工程、道路交通工程、国防工程、海洋工程、重要工厂(如核电站、大型发电厂及大型钢铁厂等)以及地震地质学、地球物理学和构造地质学等地学学科都应用到岩体力学的理论和方法。但不同的领域和学科对岩体力学的要求和研究重点是不同的。概括起来,可分为三个方面:①为各类建筑工程及采矿工程等服务的岩体力学,重点是研究工程活动引起的岩体重分布应力以及在这种应力场作用下工程岩体(如边坡岩体、地基岩体和地下洞室围岩等)的变形和稳定性。②为掘进、钻井及爆破工程服务的岩体力学,主要是研究岩石的切割和破碎理论以及岩体动力学特性。③为构造地质学、找矿及地震预报等服务的岩体力学,重点是探索地壳深部岩体的变形与断裂机理,为此需研究高温高压下岩石的变形与破坏规律以及与时间效应有关的流变特征。以上三方面的研究虽各有侧重点,但对岩石及岩体基本物理力学性质的研究却是共同的。
三、岩体力学的研究内容决定了在岩体力学研究中必须采用如下几种研究方法。
(1)工程地质研究法。目的是研究岩块和岩体的地质与结构特征,为岩体力学的进一步研究提供地质模型和地质资料。如用岩矿鉴定方法,了解岩体的岩石类型、矿物组成及结构构造特征;用地层学方法、构造地质学方法及工程勘察方法等,了解岩体的成因、空间分布及岩体中各种结构面的发育情况等;用水文地质学方法了解赋存于岩体中地下水的形成与运移规律,等等。
(2)试验法。科学试验是岩体力学研究中一种非常重要的方法,是岩体力学发展的基础。包括岩块力学性质的室内实验、岩体力学性质的原位试验、天然应力量测、模型模拟试验及原位岩体监测等方面。其目的主要是为岩体变形和稳定性分析计算提供必要的物理力学参数。同时,还可以用某些试验成果(如模拟试验及原位监测成果等)直接评价岩体的变形和稳定性,以及探讨某些岩体力学理论问题。因此应当高度重视并大力开展岩体力学试验研究。
(3)数学力学分析法。数学力学分析是岩体力学研究中的一个重要环节。它是通过建立岩体力学模型和利用适当的分析方法,预测岩体在各种力场作用下的变形与稳定性,为设计和施工提供定量依据。其中建立符合实际的力学模型和选择适当的分析方法是数学力学分析中的关键。目前常用的力学模型有:刚体力学模型、弹性及弹塑性力学模型、断裂力学模型和损伤力学模型及流变模型等等。常用的分析方法有:块体极限平衡法,有限元、边界元和离散元法,模糊聚类和概率分析法等等。近年来,随着科学技术的发展,还出现了用系统论、信息论、人工智能专家系统、灰色系统等新方法来解决岩体力学问题。
(4)综合分析法。这是岩体力学研究中极其重要的一套工作方法。由于岩体力学工作中每一环节都是多因素的,且信息量大。因此,必须采用多种方法考虑各种因素(包括工程的、地质的及施工的等)进行综合分析和综合评价,才能得出符合实际情况的正确结论,而综合分析判断是该阶段常用的方法。
以上几种方法紧密结合并且相互促进,相辅相成,缺一不可。
四、岩体力学的形成与发展历史是从岩石力学的兴起开始的。尽管岩石力学的诞生之日难以考查,但一般认为,岩体力学形成于20世纪50年代末,其主要标志:是1957年法国的塔罗勃(J•Talobre)所著《岩石力学》的出版,以及1962年国际岩石力学学会(ISRM)的成立。岩体力学作为一门独立的学科至今才40余年的历史,这是很短暂的,但其形成的历史是漫长的,这与当时的生产力水平低,工程建设数量少、规模小有关。
勇往直前!GO  GO
离线huanghanbing
只看该作者 21楼 发表于: 2009-12-04
楼主是真不懂,还是抛砖引玉?
祝地质行业越来越好
离线ynshiyun110
只看该作者 22楼 发表于: 2009-12-05
哎 这个问题就没有什么质量了 ?恕本人直言
离线xtk7304
只看该作者 23楼 发表于: 2009-12-06
关键是看有没有结构面,岩石只是矿物的结合体,而岩体是指岩石组合后形成的整体,具有一定的结构面
每天都是新的起点
