  • 6390阅读
  • 29回复
[资料共享]Relationship between Young’s modulus and effective Young’s modulus [复制链接]
离线daniellb1023
只看该作者 12楼 发表于: 2007-09-01
引用第10楼mano于2007-09-01 05:06发表的  : | VPs5
The soil displacement is mainly based on the soil stiffness (Young's Modulus E), drainage condition and stress distribution.
For Clay, the poisson's ratio varies from 0.4 to 0.2 (soft clay to stiff clay), meanwhile the stiffness(E) from 1-15MPa  to 30-100MPa. The poisson's ratio decrease with stiffness increase, the dispalcement will be smaller with the same stress level;
For sand, the poisson's ratio varies from 0.15 to 0.35 (loose sand to dense sand), the E from 10-20 MPa to 40-80 MPa, obviously, the settlement is bigger in loose sand with smaller poisson's ratio. g#ubxC7t<
]S9~2;2^,
NlXHOUw)u
34_:.QK-
oh, thanks..... it does help me a lot. 3ddH@Y|
:$."x '
so from your explaination. i can understand the value for "v" clearly. 8`XpcK-0
i understand if the soil is "sand" the "v" value is increase if the soil is better. however the value is decrease in "clay" soil. Zm& X $U
zRN_` U
but may i know, if is undrain condition. what is the standard/typical "v" value ? <\eHK[_*
li;Np5P
i understand the soil displacement is gover by a lot of condition. However, my opinion is, if "v" can also change this, i will play on it. because minor people here will question on this value, However, if i change the "E" value,they may comment on it. ^]o]'
+RQlMAB
thanks
离线mano
只看该作者 13楼 发表于: 2007-09-01
To daniellb1023: = zW}vm }
ag^EH"%zw
The undrained condition, the soil is uncompressible,  what's  the value for "v"? Q!(16
unKTa*U^q
You may take a look some textbook and find out!
离线daniellb1023
只看该作者 14楼 发表于: 2007-09-01
i understand if the soil is undrained saturated clays/silts, the v value is 0.5, however, if the soil is not 100% saturated, what is the suggested value ? below 0.5 but larger than the drain value..? or.....? w^EAk(77
YA9Xe+g
thanks
离线daniellb1023
只看该作者 15楼 发表于: 2007-09-01
and ..... .)~IoIW=
QxG:NN;jW
i understand that the saturated undrain soil is uncompressiable, the volume no change. However, may i know how to calculate step to get the "v" value is 0.5? (i know v = ey/ex.........but how to get ey/ex = 0.5 based on "uncompressiable" defination.) @N,dA#
\ 8sjAr.iT.
thanks
离线mano
只看该作者 16楼 发表于: 2007-09-02
From Hook's law: rdZk2\<
Total volume change=ex+ey+ez=(1-2v)ex XoEiW R
If Total volume change=0, ----->1-2v=0 bzD <6Z
So, v=0.5
离线mano
只看该作者 17楼 发表于: 2007-09-02
Whether the soil is saturated or not is related to water table, not the water content in the original soil. _]:wltPv
D_er(
Remember, the drained and undrained condition are based on time(drainage time, rate of applying external load).
离线yabby
只看该作者 18楼 发表于: 2007-10-15
看看,学学英文
I'm from GeoHohai.
离线gcoast
只看该作者 19楼 发表于: 2008-05-27
good artical to read, Many thanks
离线georgexue
只看该作者 20楼 发表于: 2008-05-27
E and E' will depend on the v value. meanwhile, these two value are all related to the current stress status. modified cam clay model may explain it very well.
离线wangshimin
只看该作者 21楼 发表于: 2008-06-03
thanks ....may i know what is the reference book's name? 46`(u"RP
L-Qc[L
may i conclude that, the "v "value is related to soil parameter, and for good soil "v" value is smaller? and in Plaxis input, if the "v" value is smaller, the soil deformation is samller? '| (#^jAj
OSACH0h
thanks
离线hundream
只看该作者 22楼 发表于: 2008-06-18
经典论文 虽然是英文的  但我还是会努力学习的
离线yunhe
只看该作者 23楼 发表于: 2008-07-01
已经下载学习,非常感谢!
