The soil displacement is mainly based on the soil stiffness (Young's Modulus E), drainage condition and stress distribution.
,3y9yJQa*# -p.\fvip For Clay, the poisson's ratio varies from 0.4 to 0.2 (soft clay to stiff clay), meanwhile the stiffness(E) from 1-15MPa to 30-100MPa. The poisson's ratio decrease with stiffness increase, the dispalcement will be smaller with the same stress level;
~IS8DW$; )AQ^PBwp For sand, the poisson's ratio varies from 0.15 to 0.35 (loose sand to dense sand), the E from 10-20 MPa to 40-80 MPa, obviously, the settlement is bigger in loose sand with smaller poisson's ratio.
;'= cNj _Uq' N0U All these are based on drained condition. Of course the displacement is affect by many other issues.
oSC'b% <.B+&3') Hope some help!
-4&
i t: Mjy:k|aY" 引用第8楼daniellb1023于2007-08-31 15:43发表的 : $
VP1(C
THANKS Friend... a4=(z72xe
may i know the relationship between the "v" value and the soil displacemnt?
thank. hW<v5!,
[表情]
[ 此贴被mano在2007-09-01 05:16重新编辑 ]
