Volume 36, Issues 1-2, Pages 1-358 (January-March 2009) ◄ Previous vol/iss Next vol/iss ►
Add to my Quick Links
Open All Previews articles 1 - 32
1.
Editorial Board
Page IFC
Preview PDF (32 K) | Related Articles
2.
A practical procedure for searching critical slip surfaces of slopes based on the strength reduction technique
Pages 1-5
Hong Zheng, Guanhua Sun, Defu Liu
Preview PDF (803 K) | Related Articles
3.
Axisymmetric finite element analysis of pile loading tests
Pages 6-19
I. Said, V. De Gennaro, R. Frank
Preview PDF (1162 K) | Related Articles
4.
On the use of the generalised effective stress in the constitutive modelling of unsaturated soils
Pages 20-23
Lyesse Laloui, Mathieu Nuth
Preview PDF (190 K) | Related Articles
5.
A general theoretical solution for the consolidation of a composite foundation
Pages 24-30
Kang-He Xie, Meng-Meng Lu, An-Feng Hu, Guo-Hong Chen
Preview PDF (446 K) | Related Articles
6.
Parametric sensitivity analysis of coupled mechanical consolidation and contaminant transport through clay barriers
Pages 31-40
T.W. Lewis, P. Pivonka, S.G. Fityus, D.W. Smith
Preview PDF (530 K) | Related Articles
7.
A fast common plane identification algorithm for 3D contact problem
Pages 41-51
J. Liu, Q.D. Geng, X.J. Kong
Preview PDF (565 K) | Related Articles
8.
Dynamic response of pavements on poroelastic half-space soil medium to a moving traffic load
Pages 52-60
Yuanqiang Cai, Zhigang Cao, Honglei Sun, Changjie Xu
Preview PDF (901 K) | Related Articles
9.
Discrete element modelling of drying shrinkage and cracking of soils
Pages 61-69
H. Peron, J.Y. Delenne, L. Laloui, M.S. El Youssoufi
Preview PDF (835 K) | Related Articles
10.
Three-dimensional slope failure analysis by the strength reduction and limit equilibrium methods
Pages 70-80
W.B. Wei, Y.M. Cheng, L. Li
Preview PDF (1320 K) | Related Articles
11.
Critical contact stiffness concept and simulation of crack generation in particle models of large length-scales
Pages 81-92
Chongbin Zhao, B.E. Hobbs, A. Ord, Shenglin Peng
Preview PDF (2983 K) | Related Articles
12.
Strength reduction FEM in stability analysis of soil slopes subjected to transient unsaturated seepage
Pages 93-101
Maosong Huang, Cang-Qin Jia
13.
Soil height randomness influence on seismic response: Case of an Algiers site
Pages 102-112
M. Badaoui, M.K. Berrah, A. Mebarki
Preview PDF (3611 K) | Related Articles
14.
Comparison of analytical method, 3D finite element model with experimental subsidence measurements resulting from the extension of the Milan underground
Pages 113-124
M. Migliazza, M. Chiorboli, G.P. Giani
Preview PDF (2089 K) | Related Articles
15.
The effect of strength anisotropy on the bearing capacity of spudcan foundations
Pages 125-134
Jun Liu, Yuxia Hu
Preview PDF (840 K) | Related Articles
16.
Seismic rock slope stability charts based on limit analysis methods
Pages 135-148
A.J. Li, A.V. Lyamin, R.S. Merifield
Preview PDF (723 K) | Related Articles
17.
The concept of reference curves for constitutive modelling in soil mechanics
Pages 149-165
Dorival M. Pedroso, Daichao Sheng, Jidong Zhao
Preview PDF (859 K) | Related Articles
18.
Modeling sand response using two-surface plasticity
Pages 166-186
D. Loukidis, R. Salgado
Preview PDF (1875 K) | Related Articles
19.
The at-rest earth pressure coefficient prediction using simple elasto-plastic constitutive models
Pages 187-198
Antonio Federico, Gaetano Elia, Agnese Murianni
Preview PDF (795 K) | Related Articles
20.
An approximate spring–dashpot artificial boundary for transient wave analysis of fluid-saturated porous media
Pages 199-210
Zihui Wang, Chenggang Zhao, Liang Dong
Preview PDF (1096 K) | Related Articles
21.
Interpretation of strains in torsion shear tests
Pages 211-225
Poul V. Lade, Jungman Nam, Won Pyo Hong
Preview PDF (986 K) | Related Articles
22.
Axial stress–strain relation of encapsulated granular column
Pages 226-240
Cho-Sen Wu, Yung-Shan Hong, Hsien-Chin Lin
Preview PDF (561 K) | Related Articles
23.
Utilization of self-organizing map and fuzzy clustering for site characterization using piezocone data
Pages 241-248
Sarat Kumar Das, Prabir Kumar Basudhar
Preview PDF (632 K) | Related Articles
24.
FE-modeling of shear resistance degradation in granular materials during cyclic shearing under CNS condition
Pages 249-263
J. Tejchman, E. Bauer
Preview PDF (1694 K) | Related Articles
25.
Discrete modelling of rock-ageing in rockfill dams
Pages 264-275
Thi-Huong Tran, Romain Vénier, Bernard Cambou
Preview PDF (1013 K) | Related Articles
26.
Application of nonlinear optimization technique to back analyses of deep excavation
Pages 276-290
Yu-Geng Tang, Gordon Tung-Chin Kung
Preview PDF (560 K) | Related Articles
27.
Numerical modelling of fluid flow tests in a rock fracture with a special algorithm for contact areas
Pages 291-303
T. Koyama, B. Li, Y. Jiang, L. Jing
Preview PDF (2971 K) | Related Articles
28.
Modeling small-strain behavior of Taipei clays for finite element analysis of braced excavations
Pages 304-319
Gordon Tung-Chin Kung, Chang-Yu Ou, C. Hsein Juang
Preview PDF (982 K) | Related Articles
29.
Numerical simulation of drained triaxial test using 3D discrete element modeling
Pages 320-331
N. Belheine, J.-P. Plassiard, F.-V. Donzé, F. Darve, A. Seridi
Preview PDF (1292 K) | Related Articles
30.
Displacement based multiple wedge slope stability analysis
Pages 332-341
Paul F. McCombie
Preview PDF (277 K) | Related Articles
Technical Communications
31.
Seismic vertical uplift capacity of horizontal strip anchors using pseudo-dynamic approach
Pages 342-351
Priyanka Ghosh
Preview PDF (218 K) | Related Articles
32.
Axi-symmetric active earth pressure obtained by the slip line method with a general tangential stress coefficient
Pages 352-358
F.Q. Liu, J.H. Wang, L.L. Zhang
Preview PDF (191 K) | Related Articles
