  • 38033阅读
  • 88回复
Computers and Geotechnics  目次(不断更新) [复制链接]
离线chunhuo420
只看楼主 倒序阅读 使用道具 楼主  发表于: 2007-10-18
便于了解国际上对岩土工程研究的前沿,另外如果需要哪篇文章,可回帖索求
Volume 34, Issue 4  Volume 34 (2007)
1.    Special Issue on Chemo-Mechanical Interaction in Geomaterials
Page 199
Tomasz Hueckel
2.    Coupling transport of chemical species and damage of bonded geomaterials
Pages 200-215
J.A. Fernandez-Merodo, R. Castellanza, M. Mabssout, M. Pastor, R. Nova and M. Parma
3.    A chemo-thermo-mechanically coupled numerical simulation of the subsurface ground deformations due to methane hydrate dissociation
Pages 216-228
Sayuri Kimoto, Fusao Oka, Tomohiko Fushita and Masaya Fujiwaki
4.    A hydro-bio-mechanical model for settlement and other behaviour in landfilled waste
Pages 229-246
John McDougall
5.    Simulation of reactive materials in column and reservoir tests. Sensitivity analysis for a linear coupled model
Pages 247-253
M. Kaczmarek and K. Kazimierska-Drobny
6.  An algorithm for computing the compressive strength of heterogeneous cohesive-frictional materials – Application to cement paste
Pages 254-266
F.P. Ganneau, F.-J. Ulm, J. Gondzio and E.J. Garboczi
7.    Theory of flow and deformation of swelling porous materials at the macroscale
Pages 267-278
Lynn Schreyer-Bennethum
8.  Unsaturated poroelasticity for crystallization in pores
Pages 279-290
Olivier Coussy and Paulo Monteiro
9.    Intergranular pressure solution in chalk: a multiscale approach
Pages 291-305
D. Lydzba, S. Pietruszczak and J.F. Shao
10.  Coupled chemo-mechanics of intergranular contact: Toward a three-scale model
Pages 306-327
Liang Bo Hu and Tomasz Hueckel
[ 此贴被chunhuo420在2007-10-18 12:20重新编辑 ]
共1条评分
ycsyyq 鲜花 +1 - 2007-10-18
离线liu1735
只看该作者 1楼 发表于: 2007-11-03
很是 感谢了
离线chunhuo420
只看该作者 2楼 发表于: 2007-11-09
Volume 34, Issue 5, Pages 329-422 (September 2007)
1.
Special issue on biologically inspired and other novel computing techniques in geomechanics
Page 329
Youssef M.A. Hashash
2.
Integration of laboratory testing and constitutive modeling of soils
Pages 330-345
Qingwei Fu, Youssef M.A. Hashash, Sungmoon Jung and Jamshid Ghaboussi
3.
Simulating the stress–strain behavior of Georgia kaolin via recurrent neuronet approach
Pages 346-361
Yacoub M. Najjar and Chune Huang
4.
Computational intelligence tools for the prediction of slope performance
Pages 362-384
M.D. Ferentinou and M.G. Sakellariou
5.
A neural network approach to estimating deflection of diaphragm walls caused by excavation in clays
Pages 385-396
Gordon T.C. Kung, Evan C.L. Hsiao, Matt Schuster and C. Hsein Juang
6.
Using multiple neural networks to estimate the screening effect of surface waves by in-filled trenches
Pages 397-409
Chang-Chi Hung and Sheng-Huoo Ni
7.
Support vector machines: Their use in geotechnical engineering as illustrated using seismic liquefaction data
Pages 410-421
Anthony T.C. Goh and S.H. Goh
离线chunhuo420
只看该作者 3楼 发表于: 2008-01-04
Re:Computers and Geotechnics 目次(不断更新)
Volume 34, Issue 6, Pages 423-540 (November 2007)
1.
An intelligent displacement back-analysis method for earth-rockfill dams
Pages 423-434
Yuzhen Yu, Bingyin Zhang and Huina Yuan
Abstract | View Related Articles
2.
Numerical analysis of foundation columns to support widening of embankments
Pages 435-448
Jie Han, Sadik Oztoprak, Robert L. Parsons and Jie Huang
3.
Modeling of pile installation using contact mechanics and quadratic elements
Pages 449-461
Kathrin A. Fischer, Daichao Sheng and Andrew J. Abbo
4.
Performance studies on six heuristic global optimization methods in the location of critical slip surface
Pages 462-484
Y.M. Cheng, L. Li and S.C. Chi
5.
Influence of vertical ground motion on seismic-induced displacements of gravity structures
Pages 485-497
Andrzej Sawicki, Włodzimierz Chybicki and Marek Kulczykowski
6.
Numerical simulation of ground anchors
Pages 498-507
Nak-Kyung Kim, Jong-Sik Park and Sung-Kyu Kim
7.
A numerical study on 2-D compressive wave propagation in rock masses with a set of joints along the radial direction normal to the joints
Pages 508-523
W.D. Lei, A.M. Hefny, S. Yan and J. Teng
8.
Optimisation procedure for choosing Cam clay parameters
Pages 524-531
V. Navarro, M. Candel, A. Barenca, A. Yustres and B. García
Technical note
9.
Sedimentation–consolidation of a double porosity material
Pages 532-538
Henry Wong, Chin J. Leo, J.M. Pereira and Ph. Dubujet
Discussion
10.
Comment on “Influence of vertical load on the lateral response of piles in sand”, by S. Karthigeyan, V.V.G.S.T. Ramakrishna, K. Rajagogal, Computers and Geotechnics 33(2) (2006) 121–131
Page 539
Emilios Comodromos
11.
Reply to comments on the paper “Influence of vertical load on the lateral response of piles in sand” [Computers and Geotechnics 33(2) (2006) 121–131]
Page 540
S. Karthigeyan, V.V.G.S.T. Ramakrishna and K. Rajagopal
离线chunhuo420
只看该作者 4楼 发表于: 2008-01-04
Volume 35, Issue 1, Pages 1-114 (January 2008)
1.
Dynamic response of a layered water-saturated half space to a moving load
Pages 1-10
Bin Xu, Jian-Fei Lu and Jian-Hua Wang
SummaryPlus | Full Text + Links | PDF (668 K) | View Related Articles
2.
Torsional vibrations of single piles embedded in saturated medium
Pages 11-21
Guocai Wang, Wei Ge, Xiaodong Pan and Zhe Wang
SummaryPlus | Full Text + Links | PDF (729 K) | View Related Articles
3.
3D periodic BE–FE model for various transportation structures interacting with soil
Pages 22-32
H. Chebli, R. Othman, D. Clouteau, M. Arnst and G. Degrande
SummaryPlus | Full Text + Links | PDF (1797 K) | View Related Articles
4.
Ultimate bearing capacity prediction of shallow foundations on cohesionless soils using neurofuzzy models
Pages 33-46
D. Padmini, K. Ilamparuthi and K.P. Sudheer
SummaryPlus | Full Text + Links | PDF (435 K) | View Related Articles
5.
Numerical evaluation of 3D passive earth pressure coefficients for retaining wall subjected to translation
Pages 47-60
S. Benmebarek, T. Khelifa, N. Benmebarek and R. Kastner
SummaryPlus | Full Text + Links | PDF (3096 K) | View Related Articles
6.
Influence of past loading history on the seismic response of earth dams
Pages 61-85
Stefania Sica, Luca Pagano and Arezou Modaressi
SummaryPlus | Full Text + Links | PDF (1665 K) | View Related Articles
7.
Design implications of the vertical pseudo-static coefficient in slope analysis
Pages 86-96
Robert Shukha and Rafael Baker
SummaryPlus | Full Text + Links | PDF (635 K) | View Related Articles
8.
UDEC modelling on wave propagation across fractured rock masses
Pages 97-104
X.B. Zhao, J. Zhao, J.G. Cai and A.M. Hefny
SummaryPlus | Full Text + Links | PDF (194 K) | View Related Articles
Technical Communication
9.
Impact of convergence on slope stability analysis and design
Pages 105-113
Y.M. Cheng, T. Lansivaara and J. Siu
SummaryPlus | Full Text + Links | PDF (268 K) | View Related Articles
离线baitian121
只看该作者 5楼 发表于: 2008-01-10
An efficient technique for generating homogeneous specimens for DEM studies
请问这篇文章有么?
谢谢
Email:wufeng2002wf@163.com
baitian121
离线chunhuo420
只看该作者 6楼 发表于: 2008-01-26
离线chunhuo420
只看该作者 7楼 发表于: 2008-03-12
Volume 35, Issue 2, Pages 115-312 (March 2008)
1.
Three-dimensional absorbing boundary for analysis of fluid-saturated porous media
Pages 115-123
Mohammad Reza Maleki Javan, Asadollah Noorzad and Manouchehr Latifi Namin
SummaryPlus | Full Text + Links | PDF (244 K) | View Related Articles
2.
Equivalent pile load–head settlement curve using a bi-directional pile load test
Pages 124-133
Jong-Sub Lee and Yung-Ho Park
SummaryPlus | Full Text + Links | PDF (283 K) | View Related Articles
3.
Optimum design of cantilever sheet pile walls in sandy soils using inverse reliability approach
Pages 134-143
G.L. Sivakumar Babu and B. Munwar Basha
SummaryPlus | Full Text + Links | PDF (1286 K) | View Related Articles
4.
Bearing capacity of shallow foundations on rocks obeying a modified Hoek–Brown failure criterion
Pages 144-154
Z. Saada, S. Maghous and D. Garnier
SummaryPlus | Full Text + Links | PDF (299 K) | View Related Articles
5.
A generalized slip line solution to the active earth pressure on circular retaining walls
Pages 155-164
F.Q. Liu and J.H. Wang
SummaryPlus | Full Text + Links | PDF (243 K) | View Related Articles
6.
Dynamic response of a pile in a transversely isotropic saturated soil to transient torsional loading
Pages 165-172
Gang Chen, Yuanqiang Cai, Feiyu Liu and Honglei Sun
SummaryPlus | Full Text + Links | PDF (263 K) | View Related Articles
7.
Dynamic response of a porous seabed–pipeline interaction under wave loading: Soil–pipeline contact effects and inertial effects
Pages 173-186
M. Luan, P. Qu, D.-S. Jeng, Y. Guo and Q. Yang
SummaryPlus | Full Text + Links | PDF (335 K) | View Related Articles
8.
Time-settlement behaviour of piled raft foundations using infinite elements
Pages 187-195
John C. Small and Hana L.S. Liu
SummaryPlus | Full Text + Links | PDF (394 K) | View Related Articles
9.
Numerical analysis of blast-induced liquefaction of soil
Pages 196-209
Zhongqi Wang, Yong Lu and Chunhua Bai
SummaryPlus | Full Text + Links | PDF (1144 K) | View Related Articles
10.
A unified constitutive model for both clay and sand with hardening parameter independent on stress path
Pages 210-222
Y.P. Yao, D.A. Sun and H. Matsuoka
SummaryPlus | Full Text + Links | PDF (321 K) | View Related Articles
11.
A simple method to analyze infiltration into unsaturated soil slopes
Pages 223-230
Kenneth Gavin and Jianfeng Xue
SummaryPlus | Full Text + Links | PDF (326 K) | View Related Articles
12.
Deep excavation-induced ground surface movement characteristics – A numerical investigation
Pages 231-252
Chungsik Yoo and Dongyeob Lee
SummaryPlus | Full Text + Links | PDF (4945 K) | View Related Articles
13.
An assessment of time integration schemes for dynamic geotechnical problems
Pages 253-264
Stavroula Kontoe, Lidija Zdravkovic and David M. Potts
SummaryPlus | Full Text + Links | PDF (3202 K) | View Related Articles
14.
Role of micromechanics features on stress-level dependency of cross-anisotropic elastic moduli in granular soils
Pages 265-277
Young-Hoon Jung and Choong-Ki Chung
SummaryPlus | Full Text + Links | PDF (382 K) | View Related Articles
15.
A GIS application for assessing landslide hazard over a large area
Pages 278-285
A. Zolfaghari and A.C. Heath
SummaryPlus | Full Text + Links | PDF (1933 K) | View Related Articles
Technical Communications
16.
A new back analysis of strength parameters from single slips
Pages 286-291
Jing-Cai Jiang and Takuo Yamagami
SummaryPlus | Full Text + Links | PDF (173 K) | View Related Articles
17.
Vertical bearing capacity for ring footings
Pages 292-304
L. Zhao and J.H. Wang
SummaryPlus | Full Text + Links | PDF (755 K) | View Related Articles
Discussion
18.
Comments on ‘Two-dimensional slope stability analysis by limit equilibrium and strength reduction methods’ by Y.M. Cheng, T. Lansivaara and W.B. Wei [Computers and Geotechnics 34 (2007) 137–150]
Pages 305-308
J. Bojorque, G. De Roeck and J. Maertens
SummaryPlus | Full Text + Links | PDF (548 K) | View Related Articles
19.
Reply to “Comments on ‘Two-dimensional slope stability analysis by limit equilibrium and strength reduction methods’ by Y.M. Cheng, T. Lansivaara and W.B. Wei,” by J. Bojorque, G. De Roeck and J. Maertens
Pages 309-311
SummaryPlus | Full Text + Links | PDF (82 K) | View Related Articles
离线liuzhx3716
只看该作者 8楼 发表于: 2008-03-30
不知道有SIMPLIFIED PILE-SLOPE STABILITY ANALYSIS么,急求!谢谢
liuzhx3716@163.com
新时代的土八路
离线liuzhx3716
只看该作者 9楼 发表于: 2008-03-30
能传SIMPLIFIED PILE-SLOPE STABILITY ANALYSIS  给我吗,谢谢,
liuzhx3716@163.com
新时代的土八路
离线chunhuo420
只看该作者 10楼 发表于: 2008-03-31
Re:Re:Computers and Geotechnics 目次(不断更新)
引用第8楼liuzhx3716于2008-03-30 18:30发表的 Re:Computers and Geotechnics 目次(不断更新) :
liuzhx3716@163.com
附件: Simplified pile-slope stability analysis.pdf (684 K) 下载次数:79
只看该作者 11楼 发表于: 2008-03-31
什么时候能在这里发一篇就好了。。
