  • 15564阅读
  • 59回复
Rock Mechanics and Rock Engineering——Online First™ (不断更新) [复制链接]
离线spsyc
只看该作者 48楼 发表于: 2009-10-23
谢谢
离线bad1985
只看该作者 49楼 发表于: 2009-10-25
楼主很强悍啊
One world, one dream!
离线riversun
只看该作者 50楼 发表于: 2009-12-11
求:Estimating the intensity of rock discontinuities,谢谢
求:Estimating the intensity of rock discontinuities,我的邮箱:hsky189@126.com
作者:Lianyang Zhang and H. H. Einstein
其他信息:
Copyright © 2000 Elsevier Science Ltd. All rights reserved.
References and further reading may be available for this article. To view references and further reading you must purchase this article.
Lianyang Zhang and H. H. Einstein,
Department of Civil and Environmental Engineering, Massachusetts Institute of Technology, Cambridge, MA 02139, USA
Accepted 15 March 2000 Available online 3 July 2000.
Abstract
This paper presents an approach for estimating the intensity of discontinuities and formulating intensity and orientation as a fracture tensor. Specifically the size distribution and the number of discontinuities are estimated first, from which the fracture tensor is then derived. Discontinuity size distribution is inferred from the trace data sampled in circular windows by using a general stereological relationship between the true trace length distribution and the discontinuity diameter distribution assuming circular shaped discontinuities. Because the measured trace lengths are biased, a method is proposed to estimate the true trace length distribution for circular window sampling. Circular window sampling has the advantage of automatically eliminating the orientation bias when estimating the true trace lengths. A method is then presented with which the total number of discontinuities in an objective volume can be estimated from the number of discontinuities observed in normal-size boreholes and using the inferred discontinuity diameter from the circular window sampling on the rock surface. With the derived size distribution and number of discontinuities, the intensity of discontinuities, which is the total surface area of discontinuities per unit volume, can then be calculated and included in a new definition of a fracture tensor. An application of the approach to analyze simulated discontinuities produces satisfactory results.
Article Outline
1. Introduction
2. Basic assumptions
2.1. Planar discontinuities
2.2. Circular discontinuities
2.3. Discontinuities randomly distributed in space
2.4. Discontinuity sizes independent of position
3. Inference of discontinuity size distribution
3.1. Estimation of true trace length distribution f(l)
3.1.1. Mean μl of f(l)
3.1.2. Standard deviation σl of f(l)
3.1.3. Distribution form of f(l)
3.2. Inference of g(D) from f(l)
4. Number of discontinuities
4.1. Probability of intersection
4.2. Number of discontinuities in the objective volume
4.3. Discussion
5. Fracture tensor for describing discontinuity intensity
6. Application to the simulated data by FracMan
6.1. Estimation of true trace length distribution f(l)
6.1.1. Analysis of measured trace lengths
6.1.2. True trace length distribution f(l)
6.2. Inference of discontinuity size distribution
6.3. Number of discontinuities in the objective volume
6.4. Fracture tensor
7. Summary and conclusions
Acknowledgements
References
离线jasmine927
只看该作者 51楼 发表于: 2010-07-04
楼主,现在如果还需要此期刊的论文,还能给提供吗?
离线qbzhang666
只看该作者 52楼 发表于: 2010-07-12
引用第51楼jasmine927于2010-07-04 17:55发表的  :
可以 发信息
离线qbzhang666
只看该作者 53楼 发表于: 2010-07-12
Re:求:Estimating the intensity of rock discontinuities,谢谢
引用第50楼riversun于2009-12-11 12:44发表的 求:Estimating the intensity of rock discontinuities,谢谢 :
不好意思哈,这篇文章是IJRMMS的 我没权下载
离线deaden
只看该作者 54楼 发表于: 2010-10-07
樓主....能否將文章3, 5, 7, 8, 9, 10, 12, 13, 14, 19, 22, 25, 34, 35 & 36 發電邮給我...hunter30001@hotmail.com
多謝你了
离线fsigh
只看该作者 55楼 发表于: 2010-12-23
楼主,请问,在这个期刊上发表文章,一般多久会给消息?谢谢
一切皆有可能
离线junson219
只看该作者 56楼 发表于: 2011-03-11
看不懂
离线footballone
只看该作者 57楼 发表于: 2011-03-16
恩,这样的东西还是应该以后继续的
离线zou80471436
只看该作者 58楼 发表于: 2011-04-30
楼主你好,请问你这些英语论文有中文翻译的吗,小弟英语水平有限~有的话麻烦发几篇岩土方面的论文到我邮箱,80471436@qq.com
离线xiaocheng
只看该作者 59楼 发表于: 2013-08-10
感谢分享
