  • 15558阅读
  • 59回复
Rock Mechanics and Rock Engineering——Online First™ (不断更新) [复制链接]
离线qbzhang666
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-02-15
截至2009年2月15日,在线发行论文(Articles In Press)的题目(若需全文可向我索要)
1.  添加入标记条目中
文章
Analytical Behaviour of Bolt–Joint Intersection Under Lateral Loading Conditions
H. Jalalifar and N. Aziz
PDF (498.4 KB)HTML
  2.  添加入标记条目中
文章
The Shear Behavior of Bedding Planes of Weakness Between Two Different Rock Types with High Strength Difference
A. H. Ghazvinian, A. Taghichian, Mahmoud Hashemi and S. A. Mar’ashi
PDF (1.1 MB)HTML
  3.  添加入标记条目中
文章
Incorporating Parameter Variability in Rock Mechanics Analyses: Fuzzy Mathematics Applied to Underground Rock Spalling
John P. Harrison and John A. Hudson
PDF (2.1 MB)HTML
  4.  添加入标记条目中
文章
Different Approaches for Simulating Brittle Failure in Two Hard Rock Mass Cases: A Parametric Study
Catrin Edelbro
PDF (771.5 KB)HTML
  5.  添加入标记条目中
文章
Experimental and 3D Numerical Simulation of Reinforced Shear Joints
Hossein Jalalifar and N. Aziz
PDF (767.7 KB)HTML
  6.  添加入标记条目中
文章
Application of Fuzzy Set Theory to Rock Engineering Classification Systems: An Illustration of the Rock Mass Excavability Index
Jafar Khademi Hamidi, Kourosh Shahriar, Bahram Rezai and Hadi Bejari
PDF (845.2 KB)HTML
  7.  添加入标记条目中
文章
Exploration of Tunnel Alignment using Geophysical Methods to Increase Safety for Planning and Minimizing Risk
Bodo Lehmann, Dirk Orlowsky and Rüdiger Misiek
PDF (991.5 KB)HTML
  8.  添加入标记条目中
文章
Shear Load Transfer Characteristics of Drilled Shafts Socketed in Rocks
Sangseom Jeong, Sangyong Ahn and Hoonil Seol
PDF (1.0 MB)HTML
  9.  添加入标记条目中
文章
An Integrated Numerical Modelling–Discrete Fracture Network Approach Applied to the Characterisation of Rock Mass Strength of Naturally Fractured Pillars
Davide Elmo and Doug Stead
PDF (1.1 MB)HTML
  10.  添加入标记条目中
文章
A Procedure for Determining Rock-Type Specific Hoek-Brown Brittle Parameter s
F. T. Suorineni, D. R. Chinnasane and P. K. Kaiser
PDF (1.0 MB)HTML
11.  添加入标记条目中
文章
Method for Quantification of Wear of Sheared Joint Walls Based on Surface Morphology
T. Belem, M. Souley and F. Homand
PDF (1.3 MB)HTML
  12.  添加入标记条目中
文章
The Effect of the Stress Path on Squeezing Behavior in Tunneling
Linard Cantieni and Georgios Anagnostou
PDF (1.5 MB)HTML
  13.  添加入标记条目中
文章
Further Development of the Three-Dimensional Hoek–Brown Yield Criterion
N. Melkoumian, S. D. Priest and S. P. Hunt
PDF (369.1 KB)HTML
  14.  添加入标记条目中
文章
Stability Analysis and the Stabilisation of Flexural Toppling Failure
Mehdi Amini, Abbas Majdi and Ömer Aydan
PDF (1.7 MB)HTML
  15.  添加入标记条目中
文章
Stress Measurement by Overcoring at Shallow Depths in a Rock Slope: the Scattering of Input Data and Results
C. Clément, V. Merrien-Soukatchoff, C. Dünner and Y. Gunzburger
PDF (766.3 KB)HTML
  16.  添加入标记条目中
文章
Field Evidence and Kinematical Back-Analysis of Block Rebounds: The Lavone Rockfall, Northern Italy
Paolo Paronuzzi
PDF (956.2 KB)HTML
  17.  添加入标记条目中
文章
Depth Variability of Compressive Strength Test Results of Toki Granite from Shobasama and Mizunami Construction Sites, Japan
Flavio Lanaro, Toshinori Sato and Shigeo Nakama
PDF (840.8 KB)HTML
  18.  添加入标记条目中
文章
A Numerical Study on the Screening of Blast-Induced Waves for Reducing Ground Vibration
Dohyun Park, Byungkyu Jeon and Seokwon Jeon
PDF (731.7 KB)HTML
  19.  添加入标记条目中
文章
Brittle Rock Failure in the Steg Lateral Adit of the Lötschberg Base Tunnel
F. Rojat, V. Labiouse, P. K. Kaiser and F. Descoeudres
PDF (750.6 KB)HTML
  20.  添加入标记条目中
文章
Crack Coalescence in Molded Gypsum and Carrara Marble: Part 2—Microscopic Observations and Interpretation
L. N. Y. Wong and H. H. Einstein
PDF (1.3 MB)HTML
21.  添加入标记条目中
文章
Crack Coalescence in Molded Gypsum and Carrara Marble: Part 1. Macroscopic Observations and Interpretation
PDF (1.3 MB)HTML
  22.  添加入标记条目中
文章
Theoretical Derivation of a Peak Particle Velocity–Distance Law for the Prediction of Vibrations from Blasting
Luigi Sambuelli
PDF (247.0 KB)HTML
  23.  添加入标记条目中
文章
Probabilistic Stability Evaluation of Oppstadhornet Rock Slope, Norway
H. S. B. Duzgun and R. K. Bhasin
PDF (633.5 KB)HTML
  24.  添加入标记条目中
文章
Estimating Rock Cuttability using Regression Trees and Artificial Neural Networks
Bulent Tiryaki
PDF (168.3 KB)HTML
  25.  添加入标记条目中
文章
Numerical Analyses of the Influence of Blast-Induced Damaged Rock Around Shallow Tunnels in Brittle Rock
David Saiang and Erling Nordlund
PDF (1.2 MB)HTML
  26.  添加入标记条目中
文章
A Comparison of Different Indirect Techniques to Evaluate Volcanic Intact Rock Strength
Rodrigo del Potro and Marcel Hürlimann
PDF (358.1 KB)HTML
  27.  添加入标记条目中
文章
Comment on “Correlation of P and S-Waves with Cutting Specific Energy and Dominant Properties of Volcanic and Carbonate Rocks” by A. Ersoy and U. Atici, Rock Mechanics and Rock Engineering 2007 40(5), 491–504
R. M. Goktan
PDF (80.3 KB)HTML
  28.  添加入标记条目中
文章
Advanced Geostructural Survey Methods Applied to Rock Mass Characterization
A. M. Ferrero, G. Forlani, R. Roncella and H. I. Voyat
PDF (2.0 MB)HTML
  29.  添加入标记条目中
文章
Application of an Improved Flow-Stress-Damage Model to the Criticality Assessment of Water Inrush in a Mine: a Case Study
H. Q. Zhang, Y. N. He, C. A. Tang, Bashir Ahmad and L. J. Han
PDF (633.8 KB)HTML
  30.  添加入标记条目中
文章
Response to Dr. Goktan’s Discussion “Correlation of P and S-Waves with Cutting Specific Energy and Dominant Properties of Volcanic and Carbonate Rocks”
PDF (89.3 KB)HTML
31.  添加入标记条目中
文章
Numerical Analysis of the 650,000 m2 Åknes Rock Slope based on Measured Displacements and Geotechnical Data
Vidar Kveldsvik, Herbert H. Einstein, Bjørn Nilsen and Lars Harald Blikra
PDF (1.4 MB)HTML
  32.  添加入标记条目中
文章
Local and Spatial Joint Frequency Uncertainty and its Application to Rock Mass Characterisation
Steinar L. Ellefmo and Jo Eidsvik
PDF (566.8 KB)HTML
  33.  添加入标记条目中
文章
Fragmentation during Rock Falls: Two Italian Case Studies of Hard and Soft Rocks
Nicola Nocilla, Aldo Evangelista and Anna Scotto di Santolo
PDF (1.1 MB)HTML
  34.  添加入标记条目中
文章
The Mechanical Behaviour of Clay Shales and Implications on the Design of Tunnels
M. Bonini, D. Debernardi, M. Barla and G. Barla
PDF (811.6 KB)
  35.  添加入标记条目中
文章
Visco-Plastic Behaviour around Advancing Tunnels in Squeezing Rock
D. Sterpi and G. Gioda
PDF (285.5 KB)
  36.  添加入标记条目中
文章
Elastic Solution for Deep Tunnels. Application to Excavation Damage Zone and Rockbolt Support
A. Bobet
PDF (1.1 MB)
离线qbzhang666
只看该作者 1楼 发表于: 2009-02-19
更新
1.  添加入标记条目中
文章
Analysis of Wave Propagation Through a Filled Rock Joint
Jianchun Li, Guowei Ma and Xin Huang
PDF (670.6 KB)HTML
只看该作者 2楼 发表于: 2009-02-20
good, 赞一个。
离线plotmod
只看该作者 3楼 发表于: 2009-02-25
我也喜欢看这里的文章 基本都有权限
凡人做一事,便须全副精神注在此一事,不可见异思迁
离线qbzhang666
只看该作者 4楼 发表于: 2009-02-26
目前我还可以下载到全文,有想要的文章可随时留言
离线sxcdream
只看该作者 5楼 发表于: 2009-03-09
能不能帮我找下下面的文章啊,不胜感激!
9.  添加入标记条目中
文章
PDF (1.1 MB)HTML
PDF (1.0 MB)HTML
13.  添加入标记条目中
文章
PDF (369.1 KB)HTML
  14.  添加入标记条目中
文章
PDF (1.7 MB)HTML
17.  添加入标记条目中
文章
PDF (840.8 KB)HTML
  19.  添加入标记条目中
文章
PDF (750.6 KB)HTML
  27.  添加入标记条目中
文章
R. M. Goktan
PDF (80.3 KB)HTML
  30.  添加入标记条目中
文章
PDF (89.3 KB)HTML
35.  添加入标记条目中
文章
PDF (285.5 KB)
  36.  添加入标记条目中
文章
A. Bobet
PDF (1.1 MB)
离线qbzhang666
只看该作者 6楼 发表于: 2009-03-10
Re:能不能帮我找下下面的文章啊,不胜感激!
引用第5楼sxcdream于2009-03-09 19:55发表的 能不能帮我找下下面的文章啊,不胜感激! :
9.  添加入标记条目中
文章
PDF (1.1 MB)HTML
请留邮箱,附件上传很麻烦且占用论坛空间资源!
离线香雪纳兰
只看该作者 7楼 发表于: 2009-03-11
顶!楼主太好了!!
不抛弃,不放弃,好好活着,做有意义的事!
离线guobh
只看该作者 8楼 发表于: 2009-03-12
PDF (1.3 MB)HTML
我要这个,
guobaohua@139.com
来学习的。
离线qbzhang666
只看该作者 9楼 发表于: 2009-03-12
引用第8楼guobh于2009-03-12 11:50发表的  :
PDF (1.3 MB)HTML
我要这个,
已发至你邮箱,请查收!
离线qbzhang666
只看该作者 10楼 发表于: 2009-03-12
更新
1.  添加入标记条目中
文章
Numerical Analysis of Block Caving-Induced Instability in Large Open Pit Slopes: A Finite Element/Discrete Element Approach
Alexander Vyazmensky, D. Stead, D. Elmo and A. Moss
PDF (1.3 MB)HTML
离线huweimin0426
只看该作者 11楼 发表于: 2009-03-14
楼主请问有没有钙质结核土,也就是calcareous concretion soil的文章,能不能给找一点,不甚感激!!!!!!!!!楼主请问有没有钙质结核土,也就是calcareous concretion soil的文章,能不能给找一点,不甚感激!!!!!!!!!
