  • 4166阅读
[求助]bishop的FORTRAN程序 [复制链接]
离线miya123
只看楼主 倒序阅读 使用道具 楼主  发表于: 2007-10-10
不知道有没人用过这个程序算过边坡的安全系数,我输入数值后,就是出不了结果,你哪位高手指点一下,输入数值时有什么需要注意的(以下红色部分为我输入的值),还有圆心的搜索范围是自己取的,大概多大的范围比较合适,拜托各位了,谢谢!
C
C      PROGRAM OF SLOP STABILITY(BISHOP METHOD)
C
C      FUNCTION---
C      AUTOMATIC SEARCH CRITICAL CIRCULAR SURFACE USE
C      OPTIMUM METHOD AND CALCULATED SLIDING FACTOR
C      OF SAFTY
      DIMENSION XX(5),YY(5),RA(5),FA(5)
      DIMENSION XU(24),YU(10,24),WL(24),QA(23),
    * C(10),T(10),GS(10),X(41),YW(41),Y(10,41),Q(41)
      REAL XA,XB,YA,YB,EQH,TOL1,TOL2,DS,DX
c      COMMON /NB/NB,NS,N/C/C,T,GS
c      COMMON /TOL/TOL1,TOL2/EQ/EQH/QA/QA
c      COMMON /XU/XU/YU/YU/WL/WL/DS/DS
c      COMMON /XA/XA,XB,YA,YB
C      INPUT DATA
C
      DATA XU/60.,135.,147.,159.,201.74,245.,267.,
    *        17*0.0/
      DATA YU/2*162.0,164.0,177.0,190.,5*0.0,156.497,162.0,164.0,
    *        177.0,190.,5*0.0,152.807,162.0,164.0,177.0,190.,5*0.0,
    *        150.99,162.03,164.01,177.0,190.,5*0.0,145.941,162.0,
    *        164.0,177.0,190.,5*0.0,146.0,162.0,164.0,177.0,190.,
    *        5*0.0,
    *        146.03,162.0,164.20,177.0,190.,5*0.0,170*0.0/
      DATA QA/23*0.0/WL/7*162.0,17*0.0/
      DATA C/1.960,78.3,7.843,2.941,6*0.0/T/35.0,4.93,25.0,30.0,6*0.0/
      DATA GS/20.5,11.515,18.,19.5,6*0.0/
      DATA NB,NS,N/8,4,20/EQH/0./
      DATA XA,XB,YA,YB/0.,200.,0.,200.0/DS/0.0/
      DATA TOL1,TOL2/0.02,10./
      OPEN(2,FILE='OUTPUT.DAT',STATUS='NEW')
C      OPEN(1,FILE='FDATA1',STATUS='OLD')
C      READ(1,*)XU
C      READ(1,*)YU
C      READ(1,*)WL
C      READ(1,*)QA
C      READ(1,*)C
C      READ(1,*)T
C    READ(1,*)GS
C      READ(1,*)NB,NS,N
C      READ(1,*)XA,XB,YA,YB
C      READ(1,*)DS
C      READ(1,*)EQH,TOL1,TOL2
C      WRITE(*,*)'IF RETURN HOME OR NOT'
C        WRITE(2,*)'*****XU(1)******',XU(1)
      WRITE(*,*)'Begining Calculation'
      DX=(XU(NB)-XU(1))/FLOAT(N)
      X(1)=XU(1)
      Y(1,1)=YU(1,1)
      IF(NS.EQ.1) GOTO 26
      DO 20 K=2,NS
      Y(K,1)=YU(K,1)
      IF(Y(K,1).LT.Y(K-1,1)) Y(K,1)=Y(K-1,1)
20    CONTINUE
26    YW(1)=WL(1)
      J=2
      N1=N+1
      DO 21 I=2,N1
          X(I)=XU(1)+DX*FLOAT(I-1)
23        IF(X(I).LE.XU(J)) GO TO 22
          J=J+1
          GOTO 23
22        A=(X(I)-XU(J-1))/(XU(J)-XU(J-1))
          Y(1,I)=YU(1,J-1)+A*(YU(1,J)-YU(1,J-1))
C        WRITE(*,701) Y(1,I)
C701      FORMAT(10X,'Y=',F8.2)
          IF(NS.EQ.1) GOTO 25
        DO 24 K=2,NS
          Y(K,I)=YU(K,J-1)+A*(YU(K,J)-YU(K,J-1))
24      CONTINUE
25      YW(I)=WL(J-1)+(WL(J)-WL(J-1))*A
        IF(YW(I).LT.Y(1,I)) YW(I)=Y(1,I)
        Q(I-1)=QA(J-1)
21    CONTINUE
C      WRITE(*,*)'IF RETURN OR NOT'
      WRITE(2,501)
501    FORMAT(//20X,'COODINATERS OF CIRCLE CENTRE')
      WRITE(2,208)XA,XB,YA,YB
208    FORMAT(18X,F7.2,1X,10H*** XO ***F7.2/18X,F7.2,1X,
    * 10H*** YO ***,F7.2)
      WRITE(2,502)
502    FORMAT(/,10X,60(1H+))
C      CALL CENTER
        WRITE(*,*)'Running Over!'
C      STOP
C      END
C      SUBROUTINE CENTER
C
C      FUNCTION--
C      SEARCH CRITICAL CENTER OF SLIDING RADIUS
C
C      DIMENSION XX(5),YY(5),RA(5),FA(5)
C      COMMON /NB/NB,NS,N/C/C(10),T(10),GS(10)//X(41),
C    *        YW(41),Y(10,41),Q(41),DX
C      COMMON /XA/XA,XB,YA,YB/TOL/TOL1,TOL2/DS/DS
      WRITE(2,90)
90    FORMAT(15X,2HXC,14X,2HYC,14X,2HRC,14X,2HFA)
      DXA=(XB-XA)/4.0
      DYA=(YB-YA)/4.0
      XX(1)=(XA+XB)/2.0
      YY(1)=(YA+YB)/2.0
C      WRITE(2,300)
C300  FORMAT(1X,'ERROR(1)')
c      WRITE(2,*)'%%%%%%%%%%XX(1),YY(1)%%%%%',XX(1),YY(1)
      CALL RADIUS (XX(1),YY(1),RA(1),FA(1),XU,YU,NB,NS,
    * N,C,T,GS,X,YW,Y,Q,DX,XA,XB,YA,YB,TOL1,TOL2,DS)
      WRITE(2,100) XX(1),YY(1),RA(1),FA(1)
100    FORMAT(1X,5HFA(1),1X,E15.7,1X,E15.7,1X,E15.7,1X,E15.7)
10    XX(2)=XX(1)-DXA
      XX(3)=XX(2)
      XX(4)=XX(1)+DXA
      XX(5)=XX(4)
      YY(2)=YY(1)-DYA
      YY(3)=YY(1)+DYA
      YY(4)=YY(2)
      YY(5)=YY(3)
      J=1
      FM=FA(1)
      FAMIN=FA(1)
      DO 14 I=2,5
      CALL RADIUS(XX(I),YY(I),RA(I),FA(I),XU,YU,NB,NS,
      WRITE(2,110) I,XX(I),YY(I),RA(I),FA(I)
110    FORMAT(1X,3HFA(,I1,1H),1X,E15.7,1X,E15.7,1X,E15.7,1X,E15.7)
      FM=FM+FA(I)
      IF(FAMIN.LT.FA(I)) GOTO 14
      J=I
      FAMIN=FA(J)
14    CONTINUE
      FM=FM/5.0
      AA=ABS((FAMIN-FM)/FAMIN)
      IF(AA.LE.TOL1) GOTO 16
      FA(1)=FA(J)
      XX(1)=XX(J)
      YY(1)=YY(J)
      DXA=DXA/2.0
      DYA=DYA/2.0
      GOTO 10
C      WRITE(*,*)'&&&&&&&&&&&&&&&&& *THE FIRST&************'
16    WRITE(2,55)
55    FORMAT(/,10X,60(1H+))
      WRITE(2,200) XX(J),YY(J),RA(J),FA(J)
200    FORMAT(/,10X,'CENTERS COODINATE OF SLIDING',
    *  'RADIUS XC=',F7.3/,46X,'YC=',F7.3/47X,'R=',F7.3/47X,
    *  'FACTOR OF SAFTY F=',F7.4/,10X,60(1H+))
C      RETURN
      END
      SUBROUTINE RADIUS(XC,YC,RC,FC,XU,YU,NB,NS,
C
C      FUCTION--
C      SURCH CRITICAL RADIUS
C
      REAL RB(3),FB(3),XU(24),YU(10,24),C(10),
    * T(10),GS(10),X(41),YW(41),Y(41),Q(41),DX,XA,XB,YA,YB,TOL1,TOL2,DS
C      COMMON /XU/XU(24)/YU/YU(10,24)/NB/NB,NS,N
C      COMMON /C/C(10),T(10),GS(10)//X(41),YW(41),Y(10,41),Q(41),
C    *          DX/XA/XA,XB,YA,YB
C      COMMON /TOL/TOL1,TOL2/DS/DS
C      WRITE(2,*)'ENTER THE FIRST RADIUS'
C      WRITE(2,*)'THE XU1=',XU(1)
        R1=SQRT((XC-XU(1))**2+(YC-YU(1,1))**2)
C      WRITE(2,*)'THE R1=',R1
        R2=SQRT((XC-XU(NB))**2+(YC-YU(1,NB))**2)
C        WRITE(2,901)R1,R2
C901    FORMAT(10X,2F8.2)
      RMAX=AMIN1(R1,R2)
      RMIN=RMAX
      DO 10 I=2,NB
          R1=SQRT((XC-XU(I))**2+(YC-YU(1,I))**2)
          IF(R1.LT.RMIN) RMIN=R1
10    CONTINUE
      WRITE(2,62) RMIN
62    FORMAT(/,4X,'***TO SUB-R 18 RMIN=',F8.3)
      DR=(RMAX-RMIN)/4.0
      RB(1)=(RMAX+RMIN)/2.0
C      WRITE(2,*)'THE ABOVE FIRST FACTOR'
      CALL FACTOR(RB(1),XC,YC,FB(1),X,Y,YW,N,NS,Q,C,T,GS,DX)
      WRITE(2,*)'***************THE FIRST FACTOR*********'
C      WRITE(2,40)XC,YC,RB(1),FB(1)
C40    FORMAT(1X,5HFB(1),1X,E15.7,1X,E15.7,1X,E15.7,1X,E15.7)
12    RB(2)=RB(1)-DR
      RB(3)=RB(1)+DR
      CALL FACTOR(RB(2),XC,YC,FB(2),X,Y,YW,N,NS,Q,C,T,GS,DX)
C      WRITE(2,42) XC,YC,RB(2),FB(2)
C42    FORMAT(1X,5HFB(2),1X,E15.7,1X,E15.7,1X,E15.7,1X,E15.7)
      CALL FACTOR(RB(3),XC,YC,FB(3),X,Y,YW,N,NS,Q,C,T,GS,DX)
C      WRITE(2,44) XC,YC,RB(3),FB(3)
C44    FORMAT(1X,'FB(3)',1X,E15.7,1X,E15.7,1X,E15.7,1X,E15.7)
      FM=(FB(1)+FB(2)+FB(3))/3.0
      J=1
      FMIN=FB(1)
      DO 14 I=2,3
      IF(FMIN.LT.FB(I)) GOTO 14
      J=I
      FMIN=FB(J)
14    CONTINUE
      IF(ABS((FMIN-FM)/FMIN).LT.TOL1) GOTO 16
      RB(1)=RB(J)
      FB(1)=FMIN
      DR=DR/2.0
      GOTO 12
16    FC=FMIN
      RC=RB(J)
C      WRITE(*,50)
C50    FORMAT(5X,'*END SUB-RADIUS*')
      RETURN
      END
      SUBROUTINE FACTOR(R,XC,YC,F,X,Y,YW,N,NS,Q,C,T,GS,DX)
C
C      FUCTION--
C      CIRCULAR SLIDING FACTOR OF SAFTY
C
      REAl X(41),Y(10,41),YW(41),Q(41),C(10),T(10),GS(10)
      DIMENSION DL(60),CA(60),SA(60),YR(61)
C      COMMON /EQ/EQH//X(41),YW(41),Y(10,41),Q(41),DX
        WRITE(2,901)R,XC,YC
901    FORMAT(10X,'R,XC,YC=',3F8.2)
      N1=N+1
      DO 10 I=1,N1
      IF(ABS(XC-X(I)).GT.R) GOTO 11
      YR(I)=SQRT(R**2-(X(I)-XC)**2)+YC
      IF(YR(I).GE.Y(1,I)) GOTO 10
11    YR(I)=Y(1,I)
10    CONTINUE
C      WRITE(*,*)'**** OUT OF QUESION********'
      DO 15 I=1,N
      DL(I)=SQRT((X(I+1)-X(I))**2+(YR(I)-YR(I+1))**2)
      CA(I)=(X(I+1)-X(I))/DL(I)
      SA(I)=(YR(I)-YR(I+1))/DL(I)
      WRITE(2,*)I,DL(I),SA(I),CA(I)
500  FORMAT(10X,'I=',I2,'DL(I)=',F6.3,'SA(I)=',F7.4,'CA(I)=',F7.4)
15    CONTINUE
      WRITE(2,*)'N TIME RECLE IS OVER'
      F=1.0
16    WS=0.0
      Z=0.0
      DO 20 I=1,N
      YRM=(YR(I)+YR(I+1))/2.0
      YM=(Y(1,I)+Y(1,I+1))/2.0
      YT=YM
      YEQ=(YT+YRM)/2.0
      YWM=(YW(I)+YW(I+1))/2.0
      IF(YT.GE.YWM) U=YRM-YT
      U=YRM-YWM
      IF(U.LT.0.0)U=0.0
C      IF(YRM.LE.YM)GOTO 20
      W=DX*Q(I)
      IF(NS.EQ.1) GOTO 25
      NS1=NS-1
      DO 22 J=1,NS1
      YM=(Y(J+1,I+1)+Y(J+1,I))/2.0
      IF(YRM.GT.YM) GO TO 22
      JA=J
      GOTO 24
22    W=W+GS(J)*DX*(YM-(Y(J,I+1)+Y(J,I))/2.0)
25    JA=NS
24    W=W+GS(JA)*DX*(YRM-(Y(JA,I+1)+Y(JA,I))/2.0)
      WQH=0.25*W*EQH
      WQV=WQH/3.0
      WS=WS+(W+WQV)*SA(I)+WQH*YEQ/YRM
      SIT=SIN(3.141592*T(JA)/180.0)
      COT=COS(3.141592*T(JA)/180.0)
      ZU=C(JA)*DL(I)*CA(I)+(W+WQV-U*DL(I)*CA(I))*SIT/COT
      ZL=CA(I)+SA(I)*SIT/(COT*F)
      Z=Z+ZU/ZL
20    CONTINUE
      WRITE(2,*)'TO THIS POSITION'
      WRITE(2,*)'  WS=',WS
      FA=Z/WS
250    FORMAT(1X,'FC=',E15.7)
      IF(ABS(FA-F)/FA.LE.TOL1) GOTO 30
      F=FA
      GOTO 16
30    F=FA
      IF(F.LE.0.0) F=100000.0
      RETURN
      END
共1条评分
sunjun 土币 +40 2007-10-10
离线miya123
只看该作者 1楼 发表于: 2007-10-10
我把这个程序放在FOR77和FOR90里运行时,出来的结果怎么不一样啊
FOR77可以算出,FOR90却出不了结果,这个又是什么问题啊,拜托知道的人解答一下!!
离线wenhua189
只看该作者 2楼 发表于: 2008-04-04
谢谢楼主!!
离线hust_liuhong
只看该作者 3楼 发表于: 2012-02-21
楼主可以交流一下么,我也在学这方面的
四海之内皆兄弟
