计算时一直不收敛,显示以下类似信息:
STEP 1 : FORCE NORM = 1.573E+10 TOLERANCE = 1.000E-03
RELATIVE OUT OF BALANCE FORCE = 2.255E-01 CHECK = FALSE
SPARSE: DIM=85413 NNZ(MAT)=1807198
SOLVE: REDUCTION RES=0.78E-12 (INIT. RES=0.35E+10) NI= 1
ETA-ENERGY DIAGRAM 0 0.000E+00 6.997E+09
ETA-ENERGY DIAGRAM 1 1.000E+00 -5.332E+13
LINE SEARCH LIMITED TO LOWER BOUND
ETA-ENERGY DIAGRAM 2 1.000E-01 -5.336E+12
LINE SEARCH CONVERGED ON INTERVAL
RELATIVE OUT OF BALANCE FORCE = 1.163E+01 CHECK = FALSE
SOLVE: REDUCTION RES=0.16E-13 (INIT. RES=0.18E+12) NI= 1
ETA-ENERGY DIAGRAM 0 0.000E+00 5.419E+11
ETA-ENERGY DIAGRAM 1 1.000E+00 -1.102E+10
最后弹出不正常中断的信息:
STEP 1 INITIATED:
LOAD INCREMENT: START STEPS * 1.000E+00
SEVERITY : ABORT
ERROR CODE: /DIANA/SO/SO41/0071
ERRORMSG.A: Insufficient memory for the linear solver. Try to use a linear solution method
that uses less memory. In order of decreasing memory usage:
GENEL - ILU - DIAGON.
Also substructuring may help to decrease the memory usage.
DIANA-JOB ABORTED
好像中断的原因竟然是内存不足!!我的电脑可有3G的内存啊。。。。
