  • 2558阅读
  • 1回复
[求助]新手求助,有一个FLAC3D的程序,请指出其中的错误 [复制链接]
离线nimuh
只看楼主 倒序阅读 使用道具 楼主  发表于: 2007-10-16
;开挖
new
;建模
gen zone brick &
p0 -8 0 -8 p1 16 0 -8 p2 -8 1 -8 p3 0 0 0  p4 16 1 -8 p5 0 1 0 p6 16 0 0 p7 16 1 0 &
size 8 1 4
pl sur
pause key
gen zone brick &
p0 4 0 0 p1 16 0 0 p2 4 1 0 p3 4 0 8 &
size 6 1 4
pause key
;开挖部分
gen zone brick &
p0 0 0 6 p1 4 0 6 p2 0 1 6 p3 0 0 8  &
size 2 1 1  group 1
pause key
gen zone brick &
p0 0 0 4 p1 4 0 4 p2 0 1 4 p3 0 0 6  &
size 2 1 1  group 2
pause key
gen zone brick &
p0 0 0 2 p1 4 0 2 p2 0 1 2 p3 0 0 4  &
size 2 1 1  group 3
pause key
p0 0 0 0 p1 4 0 0 p2 0 1 0 p3 0 0 2  &
size 2 1 1  group 4
pause key
;设置参数
; 定义模型材料参数
def modelMaterial
  ; 弹性模量(Pa)
  E1=10e6
  E2=20e6
  E3=40e6
  ;E4=200e6
  ; 泊松比
  poi1=0.3
  poi2=0.3
  poi3=0.3
  ;poi4=0.3
;粘结力(Pa)
  coh1=20e3
  coh2=22e3
  coh3=32e3
  ;coh4=200e3
  ; 容重(N/m3)
  weight1=16e3
  weight2=17e3
  weight3=19e3
  ;weight4=22e3
; 内摩擦角(度)
  fri1=18
  fri2=22
  fri3=24
  ;fri4=30
  ;抗拉强度
  ten1=4.3e6
  ten2=5.645e6
  grav0=-9.80            ; 重力加速度(N/kg)
dens1=-weight1/grav0  ; 密度(kg/m3)
  dens2=-weight2/grav0
  dens3=-weight3/grav0
  ;dens4=-weight4/grav0
K1=E1/(3*(1-2*poi1))  ; 体积模量(Pa)
  K2=E2/(3*(1-2*poi2))
  K3=E3/(3*(1-2*poi3))
  ;K4=E4/(3*(1-2*poi4))
G1=E1/(2*(1+poi1))    ; 剪切模量(Pa)
  G2=E2/(2*(1+poi2))
  G3=E3/(2*(1+poi3))
  ; G4=E4/(2*(1+poi4))
end
modelMaterial
model mohr
pro bulk K1 she G1 dens dens1 coh coh1 &
friction fri1 dilation 0.  range z 6 8
pro bulk K2 she G2 dens dens2 coh coh2 &
friction fri2 dilation 0.  range z 0 6
pro bulk K3 she G3 dens dens3 coh coh3 &
friction fri3 dilation 0.  range z -8 0
fix z range z 7.9 8.1
fix x range x -7.1 -6.9
fix x range x 15.9 16.1
fix y
set gravity 0 0 -10
solve
save initialm.sav
ini xdis 0 ydis 0 zdis 0
model null range group 1
solve
model null range group 2
solve
model null range group 3
solve
model null range group 4
solve
save excavation.sav
solve fos file excfosm.sav associated
这个里面有错误还望指出来
离线禾子
只看该作者 1楼 发表于: 2010-05-07
不好意思  看不明白啊
