  • 2043阅读
  • 1回复
请教贴:关于接触分析 [复制链接]
离线wangrui0371
只看楼主 倒序阅读 使用道具 楼主  发表于: 2010-12-05
网上找了一个和岩土相关的接触分析例子,命令流基本上是看懂了,问题是最后却不能求解,不知问题出在什么地方,高手帮看看,命令流如下,前面用了自由网格划分,有1个warning,应该没有问题吧。是因为不收敛么?如何调整。
/cle
/filname,diji11
/title,地基应力、应变的分布规律
/units,si
/PREP7
ET,1,PLANE42
KEYOPT,1,3,2    !平面应变模式
KEYOPT,1,5,0
KEYOPT,1,6,0
MP,EX,1,8e9 !岩石性质
MP,PRXY,1,0.29
MP,DENS,1,2600
MP,EX,2,5.0e7   !风化槽土体性质?
MP,PRXY,2,0.25
TB,dp,2         !采用DP模型
TBDATA,1,15e3,20,0 !输入粘聚力,内摩擦角
MP,DENS,2,2000
et,2,contac48,,,1
mp,mu,3,2.5       !定义摩擦系数
r,1,5.0e7,5.0e6,0.01,1.0,0.001,0.001
r,2,5.0e7,5.0e6,0.01,1.0,0.001,0.001
K,1,0,0,0,
K,2,2.5,-12,0,
K,3,6.5,-12,0,
K,4,13.5,-26.5,0,
K,5,20,-30,0,
K,6,24.5,-27,0,
K,7,31.5,-12,0
K,8,35.5,-12,0,
K,9,38,0,0,
k,10,-40,0,0,
k,11,-40,-60,0,
k,12,80,-60,0,
k,13,80,0,0,
K,14,6.5,-12,0,
K,15,13.5,-26.5,0,
K,16,20,-30,0,
K,17,24.5,-27,0,
K,18,31.5,-12,0
*do,i,1,8
lstr,i,i+1
*enddo
LSTR,1,10
*do,i,10,12
lstr,i,i+1
*enddo
LSTR,13,9
*do,i,14,17
lstr,i,i+1
*enddo
LARC,14,18,16,14.57
FLST,2,13,4
*do,i,1,13
FITEM,2,i
*enddo
AL,P51X
FLST,2,5,4
*do,i,14,18
FITEM,2,i
*enddo
AL,P51X
asel,s,area,,1
aatt,1,,1
asel,s,area,,2
aatt,2,,1
esize,4
asel,all
amesh,all
lsel,s,line,,3,4,1
nsll,s,1
CM,_TARGET1,node
lsel,s,line,,14,15,1
nsll,s,1
CM,_CONTACT1,node
lsel,s,line,,5,6,1
nsll,s,1
CM,_TARGET2,node
lsel,s,line,,16,17,1
nsll,s,1
CM,_CONTACT2,node
TYPE,2
mat,3
real,1
gcgen,_CONTACT1,_TARGET1
real,2
gcgen,_CONTACT2,_TARGET2
fini
FINISH
/SOLU
antype,static
nlgeom,on
nropt,full,,off
neqit,40
pred,on
autots,on
time,1
nsubst,100,1000,10
alls
LSEL,s,line,,10,12,2
CM,_Y,LINE
CMSEL,,_Y
DL,_Y, ,ux,0,0
allsel
LSEL,s,line,,11
CM,_Y,LINE
CMSEL,,_Y
DL,_Y, ,uy,0,0
alls
acel,,9.8
iswrite,on
lnsrch,on
outres,all,all
solve
离线yanjingfang
只看该作者 1楼 发表于: 2011-01-02
有时候出现警告不应定说你错了,可能系统自动给你提些好的建议呢。
请大家多多关照
