TEXTMASK lpvZ[^G
. =yF
-------------------------------------------------------------------------------- tHgu#k0
3"!h+dXw
Places a mask object behind selected text or mtext. The rectangular mask is offset from the text by a specified value. o'+p,_y9Y@
S ( e]@
命令: TEXTMASK )O;6S$z9Y
Current settings: Offset factor = <default>, Mask type = <default> w&8N6gA14
Select text objects to mask or [Masktype/Offset]: Select an option or text or press ENTER to exit 5%Hw,h
mu@He&w"
^T2o9f
Text objects are grouped together with the mask objects so that they moved, copied, and erased together. To update the mask after editing the text, run TEXTMASK again, and select the text item to be updated. The previous mask object is erased and a new one is created. A companion command, TEXTUNMASK, removes masks from text. KP,#x$Bg
'I^3r~_
Masktype Options aQzx^%B1
R6eKI,y\"
命令: TEXTMASK 4L)#ku$jW
Current settings: Offset factor = <default>, Mask type = <default> Qu"zzb"k
Select text objects to mask or [Masktype/Offset]: Masktype ' d' Dlg
KW`^uoY$
Mask type currently set to <default> 3)cH\gsg9
Specify object type to use for mask [Wipeout/3dface/Solid] <default> __LR!F]=i
Wipeout Masks with a rectangular frame displayed in the graphics background color. 0 w Q'~8
3dface Places a 3D Face behind the text. +&bJhX
Solid Masks with a 2D solid in a specified color. rr~O6Db
L6<.>\^Z"
NhG?@N
Offset Option 8vRQ_
||yx?q6\h
命令: TEXTMASK 57@6O-t-
Current settings: Offset factor = <default>, Mask type = <default> z{$2bV
Select text objects to mask or [Masktype/Offset]: Offset w>S;}[fM
UZvF5Hoe+O
Mask offset currently set to <default> lrQNl^K}=
Enter offset factor relative to text height <default>: Specify a value, or select points to set the mask size ?gYQE&M !
'vCl@x$
= j)5kY`
Initial default values are Offset factor = 0.35 and Masktype = Wipeout. Subsequent default values are the last specified values. @-zL"%%dw'
X/Sp!W-H
Objects in paper space used to mask objects in model space are not displayed correctly in plots. The display may look correct but your plot will not. At plot time, AutoCAD processes the model space viewports before processing paper space objects. This makes it impossible for anything in paper space to be "on top of" anything in model space. [L(qrAQ2|z
wB'GV1|jL
Wipeout ^jhc(ZW"
i=3~ h Zl
A Wipeout is a custom object created by the WIPEOUT tool. Since the Wipeout object is like an image, it has the same requirements for plotting. You need a raster-capable plotter with an ADI 4.3 raster-capable driver or the system printer driver. Masking does not plot properly if the Hide Lines option is used while plotting. One advantage of using a Wipeout mask is that what you see on screen is what you get on your plot. HV2 1=W
KJ (|skO
3Dface uE E;~`G
c`,'[Q5(O
The 3Dface created by TEXTMASK has all of its edges set to invisible. This option is useful if you do not have a raster-capable plotter. The Hide Lines option must be used while plotting for the mask effect to work. With this option, masked text does not look masked on screen. }IJE%
'wyS9^F
Solid pz4lC=H%o
:#nfdvqm
If you are using an HP plotter, use the HPCONFIG command and make sure that the In Color option is selected in Print Colors. To make the mask invisible (that is, to hide all objects behind it,) press the pens button in HPCONFIG, and create a pen that uses a shaded fill. Then set the shade percentage to 0%. With this option, masked text appears masked on screen. Also, masks can be colored to highlight text. Masking does not plot properly if the Hide Lines option is used while plotting. $Iz *W]B!
vd{ban9
使用实例: y$$|_
l@
S(2_s,J^
Text over lines: D*0[7:NSO
TF_wT28AU2
7!sR%h5p
QzLE9
Masked text over lines: s$g3__|Y
80_}}op?8
E5iNuJj=f
&s^t~>Gpr
FHbyL\Q
-------------------------------------------------------------------------------- K]SsEsd
ET扩展工具 Text 工具栏图标: OV2/?
ET扩展工具菜单: Text Text Mask 5FMe &
命令行: TEXTMASK V
|cPAT%
文件: textmask.lsp :;Xh`br
