  • 2243阅读
初学数值模拟,大家帮我看看这个怎么不能平衡? [复制链接]
离线yuanlin0916
只看楼主 倒序阅读 使用道具 楼主  发表于: 2011-04-14
new
gen zone brick size 30 44 3  p0=(0,0,0) p1=(60,0,0)  p2=(0,220,0) p3=(0,0,6)  group meiceng
gen zone brick size 30 44 2  p0=(0,0,6) p1=(60,0,6) p2=(0,220,6) p3=(0,0,9) group niyan
gen zone brick size 30 44 3  p0=(0,0,9) p1=(60,0,9)  p2=(0,220,9) p3=(0,0,15)  group zhongxisha
gen zone brick size 30 44 3  p0=(0,0,15) p1=(60,0,15)  p2=(0,220,15) p3=(0,0,21) group niyan
gen zone brick size 30 44 5  p0=(0,0,21) p1=(60,0,21)  p2=(0,220,21) p3=(0,0,36)  group shazhiniyan
gen zone brick size 30 44 10 p0=(0,0,36) p1=(60,0,36)  p2=(0,220,36) p3=(0,0,66)  group fenshayan
gen zone brick size 30 44 3  p0=(0,0,-5) p1=(60,0,-5)  p2=(0,220,-5) p3=(0,0,0)  group xishayan
gen zone brick size 30 44 10  p0=(0,0,-35) p1=(60,0,-35)  p2=(0,220,-35) p3=(0,0,-5)  group fenshayan
pl add surf yellow
pl show
model m
call prop.txt
fix z range z -35.1 -34.9
fix x range x -0.1 0.1
fix x range x 59.9 60.1
fix y range y -0.1 0.1
fix y range y 219.9 200.1
ini szz -6.75e6  grad 0 0 2.5e4
;rh=25000*270=6.75e6
ini sxx -2.02e6 grad 0,0,1.25e4
;(u/(1-u))*rh=2.02e6
ini syy -2.02e6 grad 0,0,1.25e4
apply szz -6.75e6 range z 65.9 66.1
apply szz -9.15e6 range z -35.1 -34.9
;rh=25000*366=9.15e6
apply sxx -2.02e6 grad 0 0 1.25e4 range x -0.1 0.1
apply sxx -2.02e6 grad 0 0 1.25e4 range x 59.9 60.1
apply syy -2.02e6 grad 0 0 1.25e4 range y -0.1 0.1
apply syy -2.02e6 grad 0 0 1.25e4 range y 219.9 220.1
set gravity 0 0 -10
set large
hist id=1 unbal
solve
ini xdis 0 ydis 0 zdis 0 xv 0 yv 0 zv 0
model null range x 0 45 y 0 220 z 0 6
step 3000
离线yuanlin0916
只看该作者 1楼 发表于: 2011-04-14
没有人能够帮助一下新人的吗?大家帮帮忙啊。。。。谢谢啦
离线twgod
只看该作者 2楼 发表于: 2011-05-01
ini szz -6.75e6  grad 0 0 2.5e4 请问你这样的语句有何作用?你可能要设置初始应力变化梯度,后边没有设置范围,难道你设置的各层材料的密度都一样吗? 一般的用了apply 就不用ini ,反之亦然。
离线twgod
只看该作者 3楼 发表于: 2011-05-01
期待提供详细信息,帮你解答 共同学习!
