  • 4032阅读
reset displacement to zero in abaqus [复制链接]
离线drimw
只看楼主 倒序阅读 使用道具 楼主  发表于: 2011-04-23
Hello dears
would you please explane if its possible to doing reset displacement to zero in abaqus? ( like plaxis )
the problem expalne in the below pic:
离线drimw
只看该作者 1楼 发表于: 2011-04-27
nobody has an idea to solve this problem?!
without solving this problem, we can not modeling many geotechnical problem with abaqus!
you can download a related article on this problem :
Download link (0.7 MB)
http://ifile.it/c1u428j
in this article , the authors mentioned that reseting the disp to zero before starting excavation
Please contribute in this topic to find a Solution together, and Iam sure this will be useful for all the abaqus users ( especially for geotechnical engineer )
离线judeq
只看该作者 2楼 发表于: 2011-05-08
正在学习 多谢分享
离线drimw
只看该作者 3楼 发表于: 2011-06-12
no one has an idea about this problem ?
离线ccytss
只看该作者 4楼 发表于: 2011-06-14
PLAXIS里面的位移重设定没有重新设定应力,相当于是PLAXIS正是工序开始前给你做了一下调整。在ABAQUS模型中,如果你只是关心在土体中的结构物的变形的话,即使不做重设也一样。在输出的时候,你自己做一下调整就好了。没有什么大不了的,模型还是有效的。有限元模型,一定程度上来说就是Accounting。
浮动的尘埃
