  • 7592阅读
  • 29回复
excel中撤消保护工作表(专门对付工作表加密) [复制链接]
离线20044115
只看楼主 倒序阅读 使用道具 楼主  发表于: 2011-04-25
1、打开您需要破解保护密码的Excel文件;
2、依次点击菜单栏上的工具---宏----录制新宏,输入宏名字如:aa;
3、停止录制(这样得到一个空宏);
4、依次点击菜单栏上的工具---宏----宏,选aa,点编辑按钮;
5、删除窗口中的所有字符(只有几个),替换为下面的内容;
Public Sub 工作表保护密码破解()
Const DBLSPACE As String = vbNewLine & vbNewLine
Const AUTHORS As String = DBLSPACE & vbNewLine & _
"作者:XXXXXXX"
Const HEADER As String = "工作表保护密码破解"
Const VERSION As String = DBLSPACE & "版本 Version 1.1.1"
Const REPBACK As String = DBLSPACE & ""
Const ZHENGLI As String = DBLSPACE & "                   XXXXXXX"
Const ALLCLEAR As String = DBLSPACE & "该工作簿中的工作表密码保护已全部解除!!" & DBLSPACE & "请记得另保存" _
& DBLSPACE & "注意:不要用在不当地方,要尊重他人的劳动成果!"
Const MSGNOPWORDS1 As String = "该文件工作表中没有加密"
Const MSGNOPWORDS2 As String = "该文件工作表中没有加密2"
Const MSGTAKETIME As String = "解密需花费一定时间,请耐心等候!" & DBLSPACE & "按确定开始破解!"
Const MSGPWORDFOUND1 As String = "密码重新组合为:" & DBLSPACE & "$$" & DBLSPACE & _
"如果该文件工作表有不同密码,将搜索下一组密码并修改清除"
Const MSGPWORDFOUND2 As String = "密码重新组合为:" & DBLSPACE & "$$" & DBLSPACE & _
"如果该文件工作表有不同密码,将搜索下一组密码并解除"
Const MSGONLYONE As String = "确保为唯一的?"
Dim w1 As Worksheet, w2 As Worksheet
Dim i As Integer, j As Integer, k As Integer, l As Integer
Dim m As Integer, n As Integer, i1 As Integer, i2 As Integer
Dim i3 As Integer, i4 As Integer, i5 As Integer, i6 As Integer
Dim PWord1 As String
Dim ShTag As Boolean, WinTag As Boolean
Application.ScreenUpdating = False
With ActiveWorkbook
WinTag = .ProtectStructure Or .ProtectWindows
End With
ShTag = False
For Each w1 In Worksheets
ShTag = ShTag Or w1.ProtectContents
Next w1
If Not ShTag And Not WinTag Then
MsgBox MSGNOPWORDS1, vbInformation, HEADER
Exit Sub
End If
MsgBox MSGTAKETIME, vbInformation, HEADER
If Not WinTag Then
Else
On Error Resume Next
Do 'dummy do loop
For i = 65 To 66: For j = 65 To 66: For k = 65 To 66
For l = 65 To 66: For m = 65 To 66: For i1 = 65 To 66
For i2 = 65 To 66: For i3 = 65 To 66: For i4 = 65 To 66
For i5 = 65 To 66: For i6 = 65 To 66: For n = 32 To 126
With ActiveWorkbook
.Unprotect Chr(i) & Chr(j) & Chr(k) & _
Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & _
Chr(i3) & Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
If .ProtectStructure = False And _
.ProtectWindows = False Then
PWord1 = Chr(i) & Chr(j) & Chr(k) & Chr(l) & _
Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
MsgBox Application.Substitute(MSGPWORDFOUND1, _
"$$", PWord1), vbInformation, HEADER
Exit Do 'Bypass all for...nexts
End If
End With
Next: Next: Next: Next: Next: Next
Loop Until True
On Error GoTo 0
End If
If WinTag And Not ShTag Then
MsgBox MSGONLYONE, vbInformation, HEADER
Exit Sub
End If
'Attempt clearance with PWord1
w1.Unprotect PWord1
Next w1
On Error GoTo 0
ShTag = False
'Checks for all clear ShTag triggered to 1 if not.
Next w1
If ShTag Then
With w1
If .ProtectContents Then
Do 'Dummy do loop
Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
If Not .ProtectContents Then
MsgBox Application.Substitute(MSGPWORDFOUND2, _
'leverage finding Pword by trying on other sheets
For Each w2 In Worksheets
w2.Unprotect PWord1
Next w2
End If
Loop Until True
On Error GoTo 0
End If
End With
Next w1
End If
MsgBox ALLCLEAR & AUTHORS & VERSION & REPBACK & ZHENGLI, vbInformation, HEADER
End Sub
6、关闭编辑窗口;
7、依次点击菜单栏上的工具---宏-----宏,选AllInternalPasswords,运行,确定两次;
等一到两分钟,就会出现以下对话框:这就是Excel密码对应的原始密码(此密码和原先设置的密码都能打开此文档。如果是别人的文档,你又想恢复密码设置,就可以用此密码进行保护,他就能用他设置的密码打开,你可以试试,很有趣的。字母一定要大写):
共2条评分 ,土币+4
清水流云 土币 +2 感觉高大上啊 2015-03-05
sxpm616 土币 +2 优秀资料,感谢! 2014-02-11
离线20044115
只看该作者 1楼 发表于: 2011-04-25
希望对大家有帮助。。。
离线huohuo592
只看该作者 2楼 发表于: 2011-04-25
有点复杂啊,研究一下试试
我为土狂
只看该作者 3楼 发表于: 2011-04-25
你确定可以,实践过的?   要是真的,哈哈,偶就可以走捷径了
厚积而薄发,大爱无疆
离线majunchun
只看该作者 4楼 发表于: 2011-04-27
貌似很复杂啊!
离线20044115
只看该作者 5楼 发表于: 2011-04-27
真的是很好用,不信一试!
离线aichong
只看该作者 6楼 发表于: 2011-04-29
能破解得到原始密码吗?
︱田︱田田 ╰--学习如逆水行舟,不进则退
离线林东云的
只看该作者 7楼 发表于: 2011-05-17
第一回看到 没试过
离线l333
只看该作者 8楼 发表于: 2011-05-30
很复杂啊!
离线lxq-333
只看该作者 9楼 发表于: 2011-05-30
有用,不错不错!1
离线sy100
只看该作者 10楼 发表于: 2011-07-07
学习了,谢谢!
离线cyf555
只看该作者 11楼 发表于: 2011-07-15
试过没 有没有用哦,,,,,
