  • 6089阅读
  • 17回复
[论文写作]免费提供 Geotechnique 等著名岩土期刊的全部论文 [复制链接]
离线土博士
只看楼主 倒序阅读 使用道具 楼主  发表于: 2011-04-28
本人大连理工大学,学校现刊室藏有Geotechnique,soil and foundation 等著名国际国内的期刊,现刊收藏了从期刊建刊的第一期至目前的所有期刊论文,可免费提供,时间很早的只能拍照传送。
QQ158960717
离线phying
只看该作者 1楼 发表于: 2011-04-28
您好!因工作研究需要,想查找以下Geotechnique上的几篇文章,能否帮忙查找?非常谢谢! aht285@163.com
(1) Seismic bearing capacity of foundations on slopes
Authors: J. Kumar, V. B. K. Mohan Rao
Source: Geotechnique, Volume 53, Issue 3, April 2003, pages 347 - 361
(2) Seismic bearing capacity factors of shallow strip footings
Authors: S. K. Sarma, I. S. Iossifelis
Source: Geotechnique, Volume 40, Issue 2, June 1990, pages 265 - 273
(3) Upper-bound solution for seismic bearing capacity of shallow foundations near slopes
Authors: F. Askari, O. Farzaneh
Source: Geotechnique, Volume 53, Issue 8, October 2003, pages 697 - 702
(4) Bearing capacity failure of shallow foundations in earthquakes
Authors: X. Zeng, R. S. Steedma
Source: Geotechnique, Volume 48, Issue 2, April 1998, pages 235 - 256
(5) Bearing capacity of shallow foundations considering inclinations of load and bearing stratum
Authors: Y. Maeda, H. Ochiai, N. Yasufuku, Y. Yokota
Source: BGA International Conference on Foundations, January 2003, pages 569 - 579
(6) Seismic bearing capacity for embedded footings on sloping ground
Authors: J. Kumar, P. Ghosh
Source: Geotechnique, Volume 56, Issue 2, March 2006, pages 133 - 140
(7) Seismic bearing capacity of rough footings on slopes using limit equilibrium
Authors: J. Kumar, N. Kumar
Source: Geotechnique, Volume 53, Issue 3, April 2003, pages 363 - 369
离线kuyedie921
只看该作者 2楼 发表于: 2011-04-28
如果可以的话,麻烦楼主上传一下!
离线fhw123
只看该作者 3楼 发表于: 2011-04-28
虽然现在用不上,但还是谢谢楼主这样的好心人啊 !
在线buekwu
只看该作者 4楼 发表于: 2011-04-29
学习-_-!( ⊙o⊙?)不懂
学习( ⊙ o ⊙ )~\(≧▽≦)/~
离线土博士
只看该作者 5楼 发表于: 2011-05-01
如果需要,建议先加我QQ保持联系,因为图书馆在西山,而我住北山,路途遥远,一般论文不急用,我都是自己攒一些了一次性去拍照。有时去借书还书也会拍一些。
所以最好是保持联系了,便于我操作。下次过去时给你拍下来吧。不过能下载的最好自己先下载一部分。
离线zlt1988
只看该作者 6楼 发表于: 2011-05-03
羡慕啊,呵呵
生活的磨砺铸就明天的成功!
离线huangwg08
只看该作者 7楼 发表于: 2011-05-05
楼主真是好心人啊!!
互通有无,共同成长。。。
离线huangwg08
只看该作者 8楼 发表于: 2011-05-05
回 楼主(tubx) 的帖子
楼主真是好人啊!!!!
小弟写结课论文想读"方晓阳.台湾海峡隧道工程可行性研究.北京:清华人学出版社,2000.  1 1-44"或者是“清华人学21纪发展研究院.“台湾海峡隧道论证学术研讨会”论义集。北京:清华人学出版社。”但是在维普、CNKI、万方、超星上都没找着,不知楼主能帮忙不?或是指点一二也行啊!!呵呵,小弟感激不尽!!!!
互通有无,共同成长。。。
离线xukai
只看该作者 9楼 发表于: 2011-05-05
   顶楼主,好~~~~~
离线phying
只看该作者 10楼 发表于: 2011-05-06
回 5楼(tubx) 的帖子
谢谢tubx的帮助!
经过各种努力,除了上面的第5篇外,其余的都已经找到。
离线weakom
只看该作者 11楼 发表于: 2011-05-08
给好心人送上一颗红心
