  • 2289阅读
  • 10回复
[开心一刻]复印机是男人还是女人?(中英对照) [复制链接]
离线scientrans
只看楼主 倒序阅读 使用道具 楼主  发表于: 2007-11-06
复印机是男人还是女人?(中英对照)
来源:翻译的百科全书
编辑:语际翻译
  Ever wondered the gender of a photocopier? Wonder no more, the answers to all your gender questions are here.
  是否想知道复印机的性别?不用再苦恼了,所有关于性别问题的答案都在这里。
  You might not have known this, but a lot of non-living objects are either male or female.
  你可能不知道这点,但是很多没有生命的物体不是男性就是女性
  Below are some examples:
  下面是一些例子
                                                       免费订阅双语文章!迅速提高英语!
  FREEZER BAGS: They are male, because they hold everything in, but you can see right through them.
  冷藏袋:他们是男性的,因为他们能容纳所有东西,并且表里如一。
  PHOTOCOPIERS: These are female, because once turned off, it takes a while to warm them up again. They are an effective reproductive device if the right buttons are pushed, but can also wreak havoc if you push the wrong ones.
  复印机:复印机是女人,因为一旦关掉,需要花费一点时间才能让她再度暖起来,她是非常有效的复制机器,如果你按对了按钮的话,但是如果按错了按钮,她也会造成大破坏哦。
  TYRES: Tyres are male, because they go bald easily and are often over-inflated.
  轮胎:轮胎是男性,因为他很容易变秃,而且经常过度膨胀。
  HOT AIR BALLOONS: Also a male object, because to get them to go anywhere, you have to light a fire under them.
  热气球:同样也是男性物品,因为你想让他带你去任何地方的话,必须在他下面点个火才行。
  SPONGES: These are female, because they are soft, squeezable and retain water.
  海绵:海绵是女性,因为她们很软,可以挤压并且能保持水分。
  WEB PAGES: Female, because they're constantly being looked at and frequently getting hit on.
                                                       免费订阅双语文章!迅速提高英语!
  网页:女性,因为她们总是被人看,并且经常被点击。
  TRAINS: Definitely male, because they always use the same old lines for picking up people.
  火车:当然是男性的啦,因为他们总是在相同的老地方接人。
  EGG TIMERS: Egg timers are female, because, over time, all the weight shifts to the bottom.
  煮蛋计时器:煮蛋计时器是女性,因为一旦超时,所有的重量都会囤积在底部。
  HAMMERS: Male, because in the last 5000 years, they've hardly changed at all, and are occasionally handy to have around.
  锤子:男性,因为在过去的5000年,他们几乎一点没有改变,而且只是偶尔在身边可用而已。
  THE REMOTE CONTROL: Female. You probably thought it would be male, but consider this: It easily gives a man pleasure, he'd be lost without it, and while he doesn't always know which buttons to push, he just keeps trying.
  遥控器: 女性,也许你可能认为它是男性,但是你想想看:它很容易就给男人带来快乐,如果没有遥控器,男人会迷失,并且男人并不总是知道他要按哪个键,他只是不停地尝试而已。
..........更多精彩中英对照文章请点击
离线dm1981
只看该作者 1楼 发表于: 2007-11-27
离线凤凰陧磐
只看该作者 2楼 发表于: 2007-12-18
很好 很强大
离线peter00923
只看该作者 3楼 发表于: 2009-12-29
离线frank1975
只看该作者 4楼 发表于: 2010-01-23
离线peter00923
只看该作者 5楼 发表于: 2010-01-25
离线g7713
只看该作者 6楼 发表于: 2010-01-29
大概我脑残,怎么没有看出来:复印机是人呢???
高老太爷
离线彩虹
只看该作者 7楼 发表于: 2010-01-29
呵呵,有见解!!
雨后彩虹
离线铁道兵
只看该作者 8楼 发表于: 2010-01-30
耐得住寂寞,拥得了繁华。
离线japher
只看该作者 9楼 发表于: 2010-01-31
很好,很强大
离线xlz92
只看该作者 10楼 发表于: 2010-02-03
