  • 2407阅读
心墙土石坝分层填筑出现Math error问题 [复制链接]
离线411394017
只看楼主 倒序阅读 使用道具 楼主  发表于: 2011-06-10
心墙土石坝分层填筑,第一层就出现Math error问题,谁能指指问题。谢谢!!附件是Dancan模型Duncan模型 Duncan.rar (60 K) 下载次数:12
new
config cppudm
model load Duncan.dll
gen zone brick p0 0 0 0 p1 182.5 0 0 p2 0 10 0 p3 180 0 100 p4 182.5 10 0 p5 180 10 100 p6 182.5 0 100 p7 182.5 10 100 size 10 5 20 group rockfill
gen zone brick p0 187.5 0 0 p1 360 0 0 p2 187.5 10 0 p3 187.5 0 100 p4 360 10 0 p5 187.5 10 100 p6 190 0 100 p7 190 10 100 size 10 5 20 group rockfill
gen zone brick p0 180 0 110 p1 182 0 110 p2 180 10 110 p3 180 0 210 size 2 5 20 group transition1
gen zone brick p0 184.5 0 110 p1 185.5 0 110 p2 184.5 10 110 p3 184.5 0 210 size 2 5 20 group asphalt
gen zone brick p0 188 0 110 p1 190 0 110 p2 188 10 110 p3 188 0 210 size 2 5 20 group transition2
plot block group
initial x add 2.5 range group transition1
initial x add -2.5 range group transition2
initial z add -110 range group transition1 any group transition2 any group asphalt any
group transition range group transition1 any group transition2 any
fix x y z range z -0.01 0.01
fix y range y -0.01 0.01 z 0.0 100.0
fix y range y 9.99 10.1 z 0.0 100.0
set gravity 0 0 -10.0
model null
model Duncan range z 0.0 10.0 group rockfill
pro cohesion 0 friction 46 fricdel 3 ratiofail 0.7 &
    ke 400 ne 0.65 kb 250 mb 0.5 kur 700 range z 0.0 10.0 group rockfill
ini density 2200 range z 0.0 10.0 group rockfill
model Duncan range z 0.01 10.0 group transition
pro cohesion 0 friction 38 fricdel 4 ratiofail 0.7 &
     ke 200 ne 0.4 kb 150 mb 0.5 kur 400 range z 0.0 10.0 group transition
ini density 2150 range z 0.0 10.0 group transition
model mohr range z 0.0 10.0 group asphalt
pro young 1.5e8 poisson 0.49 cohesion 3.6e5 friction 18 range z 0.0 10.0 group asphalt
ini density 2420 range z 0.0 10.01 group asphalt
solve
离线dhw0075
只看该作者 1楼 发表于: 2013-02-27
同问!我也是出现了这种情况:
Math error:
invalid
File: .\solve.cpp
Line: 1276
离线zhzhjn
只看该作者 2楼 发表于: 2013-03-02
我觉得可能是模型网格的问题,在计算时候产生突变,产生过大的变形而不能进行计算
