  • 3574阅读
  • 1回复
澳洲CGSE招收研究人员和博士研究生 [复制链接]
离线maydream163
只看楼主 倒序阅读 使用道具 楼主  发表于: 2011-08-24
  • 作者:m
  • 来自:CGSE
Australian Research Council Centre of Excellence for Geotechnical Science and Engineering Z?|\0GR+`5
10 Researcher V|xK vH
10 PhD Scholarships 0TK+R43_
`=^;q 6f
The newly established Australian Research Council Centre of Excellence for Geotechnical Science and Engineering (CGSE) is currently recruiting research staff. The CGSE will provide an international focus for geotechnical research, with particular emphasis on energy and transport infrastructure, and is founded on collaboration between the geotechnical groups at The University of Newcastle, The University of Western Australia, and the University of Wollongong (with additional support from several of Australia’s leading geotechnical consulting firms). j+NOT`&
The four major research themes of the Centre are geomaterials science, the modelling of multiphysics problems in geotechnics, the simulation of moving boundary problems, and the assessment of geotechnical risk using stochastic analysis. Tools for investigating these themes will include state-of-the-art numerical analysis, advanced physical modelling using beam and drum centrifuges, sophisticated laboratory testing, and full-scale field testing at Australia’s first national soft soil test facility (which will be established at Ballina, NSW). Engineering applications of interest include ground improvement techniques for soft and problematic soils, the analysis and design of deepwater oil and gas facilities, and the design of road and rail infrastructure. #`)zD"CO
A total of 10 Research Academic positions are available, 8 at The University of Newcastle and 2 at The University of Western Australia. There are also 10 PhD Scholarships available to work at one of the three Centre nodes. V6Ie\+@.\
The research academic positions are offered at the level of Associate Lecturer through to Senior Lecturer (termed Associate Professor at UWA). _]H$rf,Rc
The academic positions are available for a period of 5 years. Applicants must hold a PhD degree in Civil Engineering or a related field, posses advanced knowledge of computational or experimental geomechanics, have a good publication record, and exhibit excellent communication skills. -Wc'k 2oU
For the 10 Research Academic Positions d-nqV5
THE UNIVERSITY OF NEWCASTLE bS_fWD-
8 of the Research Academic Positions are available at The University of Newcastle and have salary ranges of: B;?)
Level A $67,463 to $72,417 per annum >u#c\s
Level B $76,229 to $90,523 per annum 1\t}pGSOeh
Level C $93,380 to $107,675 per annum, plus a generous employer superannuation contribution of up to 17%. S83wAr9T
Expressions of Interest for The University of Newcastle positions should be forwarded to ARC Laureate Professor Scott Sloan, Centre Director, The University of Newcastle by email to scott.sloan@newcastle.edu.au E$]7w4,n
Salary level within this range will be dependent on the qualifications and experience of the successful applicant. #FKo:id`K
THE UNIVERSITY OF WESTERN AUSTRALIA K0_/;a] |
2 of the Research Academic Positions are available at The University of Western Australia and have salary ranges of: 4^(u6tX5|+
Level A $74,713 per annum &NiDv
Level B $78,647 to $93,394 per annum nBv|5$w:
Level C $96,341 to $111,090 per annum, plus a generous employer superannuation contribution of up to 17%.
F-g(Hk|v
Salary level within this range will be dependent on the qualifications and experience of the successful applicant. =qiX0JT
Expressions of Interest for The University of Western Australia positions should be forwarded to Professor Mark Cassidy, Centre Deputy-Director, The University of Western Australia by email at: mcassidy@civil.uwa.edu.au i&\N_PUm[
For the 10 PhD Scholarships F`goYwA%
These Scholarships are available at all three nodes and are available for a period of three years, applicants are expected to hold a Bachelor or Masters degree in Civil Engineering or a related field. Each scholarship comes with a tax free allowance of up to A$40,000 per annum. 26un=
Application Details ;*ebq'D([
For the Research Academic and PhD Scholarship Positions direct applications must be made to the contact details listed below for your node of choice: @1ZLr
Laureate Professor Scott Sloan, Centre Director, The University of Newcastle by email at scott.sloan@newcastle.edu.au UO$z_ p]w
Professor Mark Cassidy, Centre Deputy-Director, The University of Western Australia by email at mcassidy@civil.uwa.edu.au v`evuJ\3
Professor Buddhima Indraratna, Node Leader, University of Wollongong by email at indra@uow.edu.au eU?SLIof[{
Note: Your application must include the email and/or fax addresses of at least three nominated referees. #aUe7~
Further Information \Tq Km
The University of Newcastle: http://www.newcastle.edu.au/research-centre/cgmm/ R}7>*&S:
The University of Western Australia: http://www.cofs.uwa.edu.au/collaborations/arc 4HEp}Y"}V
University of Wollongong: http://www.uow.edu.au/eng/research/geotechnical/index.html vk:@rOpl
Closing Date nf?;h!_7
Friday 16 September, 2011.
投稿或联系方式:william_bai@yantubbs.com
欢迎访问岩土在线资讯中心:news.yantubbs.com
更多更全更新的岩土界资讯等待您的浏览!
离线zbs9988
只看该作者 1楼 发表于: 2011-09-20
澳大利亚研究委员会中心卓越的岩土工程科学与工程   d[;=X.fZ2
10研究员    )TV4OT#
10博士奖学金   8_WFSF^
/Y|oDfv
新成立的澳大利亚研究委员会卓越的科学与工程的岩土工程(CGSE)目前正在招募研究人员。 这个CGSE会提供一个国际的焦点,岩土研究特别强调能源和交通基础设施,是建立在岩土工程组之间的协作,纽卡斯尔大学的大学和澳大利亚的西部、卧龙岗大学(更多支持从几个澳大利亚的主要岩土c * * * * * ulting公司)。   0]3%BgZ(a8
四大研究主题的中心,是科学的造型项问题multiphysics岩土模拟运动边界问题,和评估通过随机分析工程地质风险。 调查这些主题的工具将包括先进的数值分析,先进的物理模型,利用梁鼓离心机、复杂的实验室测试和全面的实地测试在澳大利亚的第一个国家软土测试设备(这将建立Ballina、新南威尔士)。 工程应用* * * * *的兴趣包括地改进技术和问题的软土,分析和设计深水油气条件、设计的公路和铁路基础设施。   OLpE0gZ.|`
总共10个研究学术职位是* * * * * 8是可行的,纽卡斯尔大学的大学,在澳大利亚的西部。 还有十博士的奖学金工作节点的三个中心。   6'd=% V
研究学术职位是* * * * *水平提供讲师的联想到高级讲师称为副教授(UWA)。   fbp6lE
学术职位是* * * * *可用于期为5年。 申请人必须持有一个博士学位在土木工程或相关领域,拥有先进的知识和实验力学的计算,有一个良好的出版记录,具有良好的沟通技巧。   `vWFTv
为10研究学术职位是* * * * *   c!"&E\F
纽卡斯尔大学的   3l"7$B
8研究学术职位是* * * * *可在纽卡斯尔大学的薪水范围,:   GW a_^
A级67463美元每年72417美元   ~yz7/?A)TS
B级76229美元每年90523美元   "QA <5P
C 93380美元水平每年107675美元,再加上一个慷慨的雇主养老金的贡献达到17%。   PW)XDo7
Expressi * * * * *对纽卡斯尔大学的职位是* * * * *必须送交桂冠教授斯科特·斯隆,电弧中心主任,纽卡斯尔大学的电子邮件 scott.sloan@newcastle.edu.au   p|VoIQY
在这个范围内的工资水平将依赖于qualificati * * * * *和经验的申请人。   UV8,SSDTV
西澳大利亚大学的   /]4[b!OTJ
2的研究学术职位是* * * * *可在西澳大利亚大学,薪酬介乎:   k6-.XW
A级每年74713美元   aW$( lf2;
B级78647美元每年93394美元   }l{r9ti
C 96341美元水平每年111090美元,再加上一个慷慨的雇主养老金的贡献达到17%。   (@Q@B%!!K
在这个范围内的工资水平将依赖于qualificati * * * * *和经验的申请人。   1!<k-vt
Expressi * * * * *对澳大利亚西部大学的职位是* * * * *必须送交中心副主任,教授马克·卡西澳大利亚大学通过电子邮件: mcassidy@civil.uwa.edu.au   (m|w&oA/
为十博士奖学金   7Wub@Mp
这些奖学金是提供在所有三个节点和可用的为期三年,预期申请人学士学位或硕士学位在土木工程或相关领域。 每个奖学金带有一个免税津贴的每年40000美元。   bj^YB,iSM
申请详情   b?`8-g
研究学术和博士奖学金职位是直接* * * * * * * * * *应用必须接触细节下面列出的为你的节点选择:   z OkUR9
教授斯科特·斯隆,中心得奖导演,纽卡斯尔大学的电子邮件 scott.sloan@newcastle.edu.au   z1A[rbe=4w
教授马克·卡,中心副主任,西澳大利亚大学的电子邮件 mcassidy@civil.uwa.edu.au   c`I`@Bed
Buddhima Indraratna教授,节点的领导者,卧龙岗大学通过电子邮件 indra@uow.edu.au   vB(tpki|
注意:你的应用程序必须包括电子邮件和/或传真地址至少三个提名的裁判。   <EKDP>,~
进一步的信息   eED Fm
纽卡斯尔大学的: http://www.newcastle.edu.au/research-centre/cgmm/   #7K&x.w$
西澳大利亚大学的: http://www.cofs.uwa.edu.au/collaborati * * * * * /弧线   +FiM?,G
卧龙岗大学: http://www.uow.edu.au/eng/research/geotechnical/index.html   \v.16obH
Closing Date A|p O
