  • 12378阅读
  • 14回复
关于隧道开挖的FLAC3D命令流 [复制链接]
离线guob07
只看楼主 倒序阅读 使用道具 楼主  发表于: 2011-09-02
关键词: 隧道开挖
关于隧道开挖的FLAC3D命令流,希望和大家共同分享
;建模
gen zon cshell p0 0 0 0 p1 7 0 0 p2 0 51 0 p3 0 0 5.5 dim 5 5 5 5 size 2 51 10
group 'concrete liner'
gen zon cyl p0 0 0 0 p1 5 0 0 p2 0 51 0 p3 0 0 5 size 5 51 10
group tunnel range group 'concrete liner' not
gen zon brick p0 0 0 -4.5 p1 add 7 0 0 p2 add 0 51 0 p3 add 0 0 4.5 size 7 51 3
gen zone radcyl p0 0 0 0 p1 27 0 0 p2 0 51 0 p3 0 0 25 dim 7 5.5 7  5.5 size 5 51 10 8 rat 1 1 1 1.3
gen zon brick p0 7 0 -4.5 p1 27 0 -15 p2 add 0 51 0 p3 7 0 0 p4 27 51 -15 p5 7 51 0 p6 27 0 0 p7 27 51 0 size 8 51 3 ratio 1.3 1 1
gen zone brick p0 0 0 -15 p1 add 27 0 0 p2 add 0 51 0 p3 0 0 -4.5 p4 27 51 -15 p5 0 51 -4.5 p6 7 0 -4.5 p7 7 51 -4.5 size 7 51 8 rat 1 1 0.7692307692307692
gen zon brick p0 0 0 25 p1 add 27 0 0 p2 add 0 51 0 p3 add 0 0 10 size 5 51 2
gen zon brick p0 27 0 25 p1 add 17 0 0 p2 add 0 51 0 p3 add 0 0 10 size 2 51 2 rat 2 1 1
gen zon brick p0 27 0 -15 p1 add 17 0 0 p2 add 0 51 0 p3 add 0 0 40 size 2 51 8 rat 2 1 1
gen zon brick p0 27 0 -40 p1 add 17 0 0 p2 add 0 51 0 p3 add 0 0 25 size 2 51 2 rat 2 1 0.5
gen zon brick p0 0 0 -40 p1 add 27 0 0 p2 add 0 51 0 p3 add 0 0 25 size 7 51 2 rat 1 1 0.5
group rock range group 'concrete liner' not group tunnel not
mo mohr
pro bulk 50e6 she 18e6 fric 20 coh 25e3 ten 0 dil 0 range z 25 35
pro bulk 4e8 she 1.5e8 fric 20 coh 50e3 ten 5e3 dil 3 range z -50 25
fix x range x -.1 .1
fix x range x 43.9 44.1
fix z range z -40.1 -39.9
fix y range y -.1 .1
fix y range y 50.9 51.1
set grav 0 0 -10
ini density 2200
ini szz -770e3 grad 0 0 22000
ini sxx -770e3 grad 0 0 22000
ini syy -385e3 grad 0 0 11000
hist unbal
hist gp zdisp 0 0 5.5
hist gp xdisp 7 0 0
hist gp zdisp 0 0 0
hist gp zdisp 0 0 35
hist gp zdisp 0 30 5.5
hist gp xdisp 7 30 0
hist gp zdisp 0 30 0
hist gp zdisp 0 30 35
hist gp zdisp 0 12 35
hist gp zdisp 0 18 35
hist gp zdisp 0 24 35
hist gp zdisp 0 36 35
hist gp zdisp 5 30 35
hist gp zdisp 10 30 35
solve
save geom1.save
离线guob07
只看该作者 1楼 发表于: 2011-09-02
def conc_parm
   bmc=20.7e9
   smc=12.6e9
end
conc_parm
def cab_parm
  array x_b(4,3),z_b(4,3)
  y0=-3
  x_b(1,1)=0.8
  x_b(2,1)=2.1
  x_b(3,1)=3.5
  x_b(4,1)=5.5
  z_b(1,1)=5.5
  z_b(2,1)=2.4
  z_b(3,1)=4.7
  z_b(4,1)=1.5
  x_b(1,2)=0.8
  x_b(2,2)=0.8
  x_b(3,2)=3.5
  x_b(4,2)=5.5
  z_b(1,2)=0.6
  z_b(2,2)=4.0
  z_b(3,2)=2.4
  z_b(4,2)=0.6
  x_b(1,3)=0.8
  x_b(2,3)=2.6
  x_b(3,3)=5.0
  x_b(4,3)=3.5
  z_b(1,3)=2.4
  z_b(2,3)=4.0
  z_b(3,3)=3.0
  z_b(4,3)=0.6
end
def inip
  x1=x_b(1,iidx)
  x2=x_b(2,iidx)
  x3=x_b(3,iidx)
  x4=x_b(4,iidx)
  z1=z_b(1,iidx)
  z2=z_b(2,iidx)
  z3=z_b(3,iidx)
  z4=z_b(4,iidx)
end
cab_parm
def ins_cab
   loop iidx (1,3)
      inip
      cab_seg=cab_seg_m-3*(3-iidx)
      y1=0
      y2=float(cab_seg)
      command
        sel cable id iidx begin x1 y1 z1 end x1 y2 z1 nseg cab_seg
        sel cable id iidx begin x2 y1 z2 end x2 y2 z2 nseg cab_seg
        sel cable id iidx begin x3 y1 z3 end x3 y2 z3 nseg cab_seg
        sel cable id iidx begin x4 y1 z4 end x4 y2 z4 nseg cab_seg
        sel cable pro emod 45e9 xcarea 1.57e-3 gr_per 1. yten 25e4 gr_k 17.5e6 gr_c 20e4 ran id iidx
     end_command
  end_loop
end
set cab_seg_m 15
ins_cab
sel shell id 10 group rock range cyl end1 0 0 -1.5 end2 0 1 -1.5 rad 7.4 cyl end1 0 0 -1.5 end2 0 1 -1.5 rad 6.7 not z -0.1 6
sel shell prop isotropic 10.5e9 0.25 thickness 0.3 density 2500
def monit
  ipt_surf=gp_near(0,30,35)
  ipt_crown=gp_near(0,30,5.5)
  ipt_spring=gp_near(7,30,0)
end
monit
solve
save m_ini.sav
离线shuanglin
只看该作者 2楼 发表于: 2011-09-06
这个很给力!
敬德修业  脩辞立诚
离线mahmutjan
只看该作者 3楼 发表于: 2011-09-07
离线yinjunhui
只看该作者 4楼 发表于: 2011-09-08
谢谢楼主,不收土币才是好人
离线mayanna0203
只看该作者 5楼 发表于: 2011-09-08
谢谢楼主.我好好看看,新手希望把软件写好
呵呵。
离线bjutchen
只看该作者 6楼 发表于: 2011-09-26
谢谢楼主啦,确实是个大好人
离线sense_2010
只看该作者 7楼 发表于: 2012-03-29
多谢楼主无私分享····
离线悦悦619
只看该作者 8楼 发表于: 2012-07-22
这里面锚杆三个样式,怎么理解啊,还有超前支护?
离线ynsjliujun
只看该作者 9楼 发表于: 2012-09-12
请问这个是怎么理解的?
离线297080039@qq
只看该作者 10楼 发表于: 2012-11-02
楼主是个好人啊!!!
离线pengzh
只看该作者 11楼 发表于: 2012-12-03
成功人士,在来“岩土在线”的路上!
