  • 1337阅读
  • 0回复
出错了 求高手帮助 [复制链接]
离线wanghaoja
只看楼主 倒序阅读 使用道具 楼主  发表于: 2011-09-03
                     **                              A FINITE ELEMENT PROGRAM FOR                              **
                     **                    AUTOMATIC DYNAMIC INCREMENTAL NONLINEAR ANALYSIS                    **
                     **                               --  S T R U C T U R E S  --                              **
                     **         AAAAAAAAAA    DDDDDDDDD      IIIIIIIIIIII   NN        NN    AAAAAAAAAA         **
                     **        AAAAAAAAAAAA   DDDDDDDDDD     IIIIIIIIIIII   NNN       NN   AAAAAAAAAAAA        **
                     **        AA        AA   DD       DD         II        NNNN      NN   AA        AA        **
                     **        AA        AA   DD        DD        II        NN NN     NN   AA        AA        **
                     **        AAAAAAAAAAAA   DD        DD        II        NN   NN   NN   AAAAAAAAAAAA        **
                     **        AA        AA   DD        DD        II        NN      NNNN   AA        AA        **
                     **        AA        AA   DD       DD         II        NN       NNN   AA        AA        **
                     **        AA        AA   DDDDDDDDDD     IIIIIIIIIIII   NN        NN   AA        AA        **
                     **        AA        AA   DDDDDDDDD      IIIIIIIIIIII   NN         N   AA        AA        **
                     **                            VERSION - 8.7.1  (build 09.27.2010)                         **
                           THIS PROGRAM IS IN ITS ENTIRETY PROPRIETARY TO, AND IS SUPPORTED AND MAINTAINED BY
                                                           ADINA  R&D, Inc.
                                         71 Elton Avenue                      Tel  (617) 926-5199
                                   Watertown, MA 02472, U.S.A.                Fax  (617) 926-0238
                                         USAGE  OF  THIS PROGRAM AND THE PROGRAM DOCUMENTATION IS
                                         SUBJECT TO THE CONDITIONS IN THE ADINA LICENSE AGREEMENT
       COPYRIGHT  ADINA R&D,INC., 1987,1990,1992,1994,1999,2000
                                  2001,2002,2003,2004,2005,2006
                                  2007,2008,2009,2010
       ADINA IS A REGISTERED TRADEMARK OF K.J. BATHE.
                        *** ADINA R&D INC. ***
       MAKES NO WARRANTY WHATSOEVER, EXPRESSED OR IMPLIED THAT
       THE PROGRAM AND ITS DOCUMENTATION ARE FREE FROM ERRORS
       AND DEFECTS. IN NO EVENT SHALL ADINA R&D BECOME LIABLE
       TO THE USER OR ANY PARTY FOR ANY LOSS, INCLUDING BUT NOT
       LIMITED TO, LOSS OF TIME, MONEY OR GOODWILL, WHICH MAY
       ARISE FROM THE USE OF THE PROGRAM AND ITS DOCUMENTATION.
       COMPUTER VERSION:   WINDOWS 98/ME/NT/2000/XP
                        RESTRICTED RIGHTS LEGEND
       USE, DUPLICATION, OR DISCLOSURE OF THE ADINA SYSTEM BY THE
       U.S. GOVERNMENT IS SUBJECT TO RESTRICTIONS AS SET FORTH IN
       SUBPARAGRAPH  (C)(1)(II)  OF  THE RIGHTS IN TECHNICAL DATA
       AND COMPUTER SOFTWARE CLAUSE AT DFARS 252.227-7013.
Initial ADINA memory allocation  -  1718.0 mb  (or  429.5 mw)
          *          THIS IS A    LINEAR   STATIC SOLUTION          *
1PROGRAM ADINA - VERSION 8.7.1 (build 09.27.2010)    *** NO HEADING DEFINED ***
S O L U T I O N    B Y    S P A R S E   S O L V E R
TOTAL SYSTEM DATA
     NUMBER OF EQUATIONS . . . . . . . . . . . . .(NEQ)  =      2480
     NUMBER OF NON-ZERO MATRIX TERMS. . . . . . . (NZC)  =     38871
     MEMORY AVAILABLE FOR STORAGE (in words). .(MSTORE)  = 404496500
     NUMBER OF PROCESSORS USED. . . . . . . . . (NPROC)  =         1
       M E M O R Y     R E Q U I R E M E N T   (in words)
  AVAILABLE MEMORY FOR THE ADINA PROGRAM (MSTORE)       =           404496500
  ESTIMATED MEMORY FOR IN-CORE STORAGE .......(IOPTIM=3)=              281989
  ESTIMATED MEMORY FOR OUT-OF-CORE STORAGE....(IOPTIM=2)=              281177
  NOTE: WHEN SPARSE SOLVER IS USED - ADDITIONAL MEMORY
        IS REQUIRED - PLEASE SEE BELOW INFORMATION
        RELATED TO SPARSE SOLVERS.
  MAXIMUM REQUESTED (TEMPORARY) MEMORY (in words)...... =              281989
     IN-CORE STORAGE FLAG . . . . . . . . . . . (IOPTIM)  =         3
Available total memory . . . . . . . . . . . . .    1618.0 mb
Memory used for storage of model data. . . . . .       1.4 mb
*          <<<<< SPARSE SOLVER INFORMATION >>>>>                            *
* NUMBER OF NON-ZERO TERMS IN FACTORIZED MATRIX......=              105853  *
* MEMORY USED BY THE SOLVER (in words)...............=              298276  *
* TOTAL MEMORY USED BY THE PROGRAM (in words)........=              652225  *
*             << IN-CORE SOLUTION >>                                        *
Memory used by the in-core sparse solver. . :       1.2 mb
Total memory used by the program. . . . . . :       2.6 mb
DIAG ELEMENT (WITH MAX ABS VALUE) OF THE FACTORIZED MATRIX =    0.21815E+09     NODE =      1001     DOF = Y-TRANSLATION
DIAG ELEMENT (WITH MIN ABS VALUE) OF THE FACTORIZED MATRIX =    0.12921E+08     NODE =       336     DOF = Y-TRANSLATION
Mapping Interface Error, Icode= 1033
*** ERROR NO. A1806 ***
Mapping Interface error, please contact ADINA R&D, Inc.
  S O L U T I O N   T I M E   L O G (IN SEC)
            FOR PROBLEM
INPUT PHASE  . . . . . . . . . . . . . . . . . .      0.06
SUBSTRUCTURES INPUT PHASE. . . . . . . . . . . .      0.00
INITIALIZATIONS. . . . . . . . . . . . . . . . .      0.00
ASSEMBLAGE OF LINEAR STIFFNESS,EFFECTIVE STIFF-
NESS,MASS MATRICES AND LOAD VECTORS . . . . . .       0.02
FREQUENCY (OR BUCKLING) ANALYSIS . . . . . . . .      0.00
INITIAL CALCULATIONS FOR MODE SUPERPOSITION
                      ANALYSIS . . . . . . . . .       0.00
TRIANGULARIZATION OF LINEAR (EFFECTIVE)
                      STIFFNESS MATRIX  . . . . .      0.02
STEP-BY-STEP SOLUTION (         1 TIME STEPS)
   CALCULATION OF EFFECTIVE LOAD VECTORS  . . .        0.00
   UPDATING EFFECTIVE STIFFNESS MATRICES
   AND RHS VECTOR FOR NONLINEARITIES  . . . . .        0.00
   UPDATING EFFECTIVE STIFFNESS MATRIX FOR
   CENTRIFUGAL DEFORMATION DEPENDENT LOADING. .        0.00
   MODE SUPERPOSITION . . . . . . . . . . . . .        0.00
   SOLUTION OF EQUATIONS  . . . . . . . . . . .        0.00
   EQUILIBRIUM ITERATIONS (TOTAL) . . . . . . .        0.00
   CALCULATION AND PRINTING OF DISPLACE-
   MENTS, VELOCITIES, AND ACCELERATIONS . . . .        0.00
   CALCULATION AND PRINTING OF STRESSES . . . .        0.00
   FRACTURE MECHANICS . . . . . . . . . . . . .        0.00
                               STEP-BY-STEP TOTAL. . .       0.01
CALCULATION AND PRINTING OF SUBSTRUCTURE
                 INTERNAL RESPONSES  . . . . . . . . .       0.00
T O T A L   S O L U T I O N   T I M E (SEC) . . . . .       0.11
以上是错误信息输出  新手看不懂  请大侠帮忙指点是什么错误 怎么解决 小弟在此谢过!
